Show messages: All
1
2-5
Hi Fabien, maybe the AutoCAD LT spline to polyline conversion mechanism is sensitive to things like the parameterization of the spline.
It looks like there is a command in AutoCAD for converting a spline to a polyline, see here:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-convert-splines-to-polylines-in-AutoCAD.html
If that's available in LT could you try using it on your original imported spline and see if you can repeat the odd behavior? If so that would probably pinpoint the problem being AutoCAD's conversion mechanism.
A couple of possible solutions:
Try using Edit > Separate on your curves in MoI before exporting them to AutoCAD. That way AutoCAD will treat each one as an individual object and that might avoid the problem if it's the AutoCAD uses some kind of parameter space tolerance for the conversion which could make it think the arc is small if it has a small parameter space compared to the other segments.
The other thing is you could export from MoI using polylines at that point rather than relying on AutoCAD to do the polyline conversion.
Please let me know if those don't help.
Thanks for your prompt reply! I tried AutoCAD's 'convert to polyline' before, and it does work as expected - although even straight lines will get some subdivision.
However, I'm happy to report that your hunch regarding 'parameter space tolerance' was spot on! When I imported the separated curves from MoI it even brought in arcs correctly (not as splines), which already made a huge difference for these files. In addition, any free-form splines were now correctly handled as well.
I was able to join the (now) separate segments in AutoCAD and still export them to DXF R12 polyline format without any issues. The exported curves were either pure arcs/circles or finely segmented polylines.
One thing I noticed in AutoCAD is that I wasn't able to 'join' back all the lines without issues. Some parts refused to connect, whereas the same operation was performed without a hitch in QCad.
AutoCAD might be the standard in CAD, but it's those glitches (in addition the odd behavior I was seeing with the imported files) that will prevent me from ever becoming an actual user, I'm afraid. I'm currently using the trial to mimic the behavior my cutting provider was seeing, but looks like our ways will part forever in about 30 days from now ;)
Another solution that worked for me is using Rhino's DXF export using the 'CAM Metric' scheme. It automatically handled arcs/circles, while having control over parametrization of the free-form splines. I prefer this over having MoI handling the conversion, because I can take a completely annotated DWG into Rhino and then export it to DXF at once. That way, the splines and arcs are preserved as long as possible, so any edits can still be done and at the same time, the file size is kept low.
Thanks again for your help!
- Fabien
You can try Fusion 360 as converter format files! ;)
Hi all,
I send files to a laser cutter that can cant use splines I use the RHINO convert to ARCS you can specify the resolution much better than converting to polylines so you dont get stepping - not sure is this command exists in AUTOCAD offerings.
A Spline to ARC converter in MOI would be a fantastic addon.
Show messages: All
1
2-5
