15-34
35-54
55-73
Ok, hopefully the attached one has the proper rotations now.
It assumes the bottle is pointing upwards in the world z axis direction and is positioned around the start point of the helix, and that the helix/cylinder axis has its origin at the world origin and that the helix/cylinder axis direction is the world x axis direction as in Brian's InialFeedScrewTOP01.3dm file from above.
I think it should work ok if you substitute a variable pitch helix in but I did not test that. But it distributes the items by equal distance as traveled along the curve, so with a variable pitch helix trying to use an item count that's related to the number of helix turns won't place items only at the quadrant points of the helix as it would with a regular fixed pitch helix. I don't know if a sparse placement only at quadrant points is desired but it looked like some of the images had that.
BottleFeedArray2.zip
Well, the script seems to be working... (My superficial opinion anyway)
FALSE: I had to make the bottle hollow, otherwise got a helical ribbon with many bite marks on the edges.
(Using a solid bottle, the solid screw was formed by the booleans, but color of cuts matched the bottles, not the screw.)
Hollow bottle as cutter also worked...
Boolean difference is very slow. Several minutes for 50 bottles. 100 bottles taking "forever."
There is a lot of leftover surfaces after Boolean, but by selecting the screw, and hiding the "leftovers" the screw appears as a solid.
The Boolean difference needs to be done in smaller batches. 100 bottle screw, 180 degree rotation completed.
The engineering goes into setting up the variable pitch helix...
The bottle can be assumed to have its verticle axis intersecting the beginning of the helix.
If the bottle's axis is beyond the surface of the cylinder, a new, larger radius cylinder should be made. (?)
After the larger radius cylinder becomes a screw, it can have its radius shaved down later. (?)
About BottleFeedArray2
Does this result normal ? (50 steps - 12°)
Michael,
many thanks works just as needed.
Barry
It is if you don't have your helix positioned as required, it looks like your helix is going in the world z axis direction instead of the world x axis direction.
Hi Barry, you're welcome I'm glad that does the trick! And thanks to Brian and Burr for helping clarifying what was needed.
<< you don't have your helix positioned as required
Indeed! :)
@ Michael
Ok the random colors are fixed! ;)
And the little trick Menu Styles / Tool Styles / Add new Default Styles (by 7) + Random Colors
and repeat is perfect for make speedy big random colors' palettes!
http://moi3d.com/forum/index.php?webtag=MOI&msg=2987.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=3876.1
Well done Pilou!
I would like to see a Boolean applied sequentially for each bottle, which would be much faster, I think. (?)
There could be an option checkbox for this? Maybe I'll try after work...
An elliptical bottle has much faster Boolean dif, than the rounded rectangle bottle.
Maybe the MoI Boolean dif command could have a sequential checkbox?
For oval bottle, Lofting the cut edges seems promising?
Finding the midpoint dip line of the cut edges, and lofting might work for smoothing?
The Iso's do not follow the ridges of the cuts.
Bemfarmer,
Boolean issue?
What I would do is create a "profile" of my bottle (then run rebuild if it was segmented, like a rounded corner rectangle) then run the bottle array on the profile and choose a ridiculous amount of stations. Then loft those and do the Boolean diff with the new, single solid.
I have 1 question for Michael though.
Is there a way to set "an attachment point" to the bottle? If I have an elongated rectangle for a bottle for instance, and I want to set a "depth" of the bottles placement on the helix start point, the bottle "moves away" from the depth and helix as it rotates to the narrow side of the bottle/rectangle. So if I make a variable helix with a start radius of 5 and an end of 3, My resulting bottle at the minor radius' endpoint has moved out and away from the helix path.
Not sure if/how this could be done.
variable bottlefeed.zip
I have tried to run the script on a reverse twist helix and it does not seem to work.
The get around was to produce one scroll with a positive bottle rotation 90 degrees
and to produce another scroll ( same helix ) with a negative bottle rotation minus
90 degrees and then mirror the result.
The subtraction from shaft required careful attention as Moi struggled when all bottles
or groups of bottles where selected so as Brian as suggested it would be good if they
could be subtracted one by one as they are produced I think this the way the Autodesk
Feed Screw Generator plugin works.
An way Michael again many thanks for your help much appreciated.
Barry
Very interesting topic, it awakened my curiosity.
I reproduce the simulation of this screw conveyors in Algoryx Momentum.
https://www.youtube.com/watch?v=9OBpMFdMZ3g
I have one question, after the using this script, the result of the boolean operation generates many facets.
it's possible or not to generate directly one smooth profile for boolean operation?
I have TopSolid but not this function, it's seem generate one surface smooth with the profile cutting.
https://www.youtube.com/watch?v=U93EzIzA_Hk
Best Regards.
Nicolas.
This is still a rich topic with many permutations.
The screw seems to be a bit short on the left.
The screw/cylinder can be length extended to the left.
The helix and reverse helix can be copied to the left, and FLIP applied to reverse start point.
The bottle can be arrayed to the left, with a negative rotation of -90 degrees...
(If Unflipped, array to the left created an expanding conical-ish spiral...)
I have yet to grasp the reverse screw. The script will work if ...
Explicit videos!
So can we consider that BottleFeedArray2 is better than native Sweep ?
(Start and End caps are perpendicular in each case)
Caps in BottleFeedArray2 are not perpendicular to the helix!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/sweep_orientation.3dm
Bottlefeedarray2 is a step in creating the profiles cut in
the shaft as it travels along the screw.
If you produce a screw from just the bottle profile
by sweeping the bottle profile along the helix only
and then place a bottle in the thread and do a
Boolean subtract you will see it cuts into the thread.
That's because the bottle is vertical and not at the helix
Angle of the screw.
Barry
Replies to several people below:
@Brian,
Boolean diff does actually operate in a sequential manner internally, there's a loop and each cutting object is subtracted from the main object one at a time. It can be good sometimes to control the ordering specifically but probably in this case with each object being created in an array so all in that same order in the geometry database I'd think it would probably be the same as if the script did the boolean difference too.
@Burr,
Not currently, it's only currently designed to work on a fixed radius helix. The variable part that could be used currently is variable pitch where the spacing along the axis direction between each turn is not constant (like a changing "vertical step" in array circular) . You've got a variable radius one there, not variable pitch. It could be possible to make one that would work with variable radius, it just didn't sound like that was needed for what Barry was making, let me know if you need to manufacture one with variable radius.
@Barry,
Do you need this to be fixed in order to proceed or is the solution you came up with working ok?
Internally the regular boolean command already does subtract cutting objects one by one out of the base object, so I don't think there would be any change in doing it one by one in the script. It's just a lot of work doing so many booleans with pieces that are very close to one another, it's going to take some time to calculate. If it's getting a valid result instead of speed that you're worried about you may need to make it a little less dense so there aren't quite so many things barely grazing each other's edges and another possibility is to do a boolean union on all the bottles first before doing the difference. Actually doing the union in a controlled way in the script could have some potential to speed things up if say it unioned each sequential pair together first, then those pairs into quads, etc.. until it was done because that would do more boolean operations on simpler objects. But I think it might take a fair amount of development time to make that happen though.
@Nicolas,
I guess it's possible maybe with a couple months of work or so. It looks like TopSolid is generating profile curves to make cross sections for a loft to make one smooth surface. Unfortunately I just don't have enough time available myself to make such a detailed customized solution like that in MoI.
@Michael,
No need the variable radius. I just saw some screws made like that. I don't see that's what Barry is looking for.
@Others,
I see now why the bottle needs to be a solid, as opposed to my suggestion of just lofting profiles to solve a long Boolean.
Another way to get around it is to just do chunks. So I do an array with 400 bottles. I basically window select little "5ths" of the lot. Each Boolean only took about 15 seconds. If you try with all 1 go, it can make the calc take a long time.
Anyway.....
15-34
35-54
55-73
