Full Version: Looking for car modeling tutorials
Show messages:  1-19  20-39  40-48
2 Jul 2017   [#40] In reply to [#39]
Hi Ken,
> When you say Moi models are meant for rendering, which file format?
The best format depends on the particular rendering application that you're using. But the most generally used format for transferring to a rendering program is OBJ format, and it may be a good idea to set the "Export: Quads & Triangles" setting.
LWO is primarily used for transferring to Modo and LightWave, other programs may not read vertex normals smoothing information from it.
3DS is a very old and limited format and should only be used as a last resort if nothing else works, it can only contain triangles and has a 16-bit limit on mesh size and no support for vertex normals.
I added FBX support primarily for transferring into 3DS Max.
For SketchUp use SKP format.
For Vue, I'd recommend OBJ format with "Export: Quads & Triangles" set in the meshing options dialog.
2 Jul 2017   [#41]
A very cool free render is SimLab Composer Lite! (max 1920 * 1080)
Many files formats input!
http://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
4 Jul 2017   [#42] In reply to [#39]
Ken,
You'll want to export your models as OBJ for import into Vue. You can 'smooth' them more by dragging the slider, or using the advanced options. I would use settings something like:
Take note of the ALL setting and the relative density. Depending on scale you may want to change the 10 number-- but try and achieve a similar density for proper shading in Vue.
5 Jul 2017   [#43] In reply to [#42]
Hi
Re artifacts when importing into Hexagon.
I had similar problems when using Carrara and after searching some forums I found what I think is the answer. Carrara does not fully support obj files and looses smoothing data. I think this also applies to Hexagon. Daz seems to have given up on development of these applications. Oddly Carrara pro has an import option for nurbs that produces worse results than its obj import.
Although Daz Studio uses vertex averaging, like Carrara, it does a better job of importing obj from Moi but artifacts are still a problem. I know learning to use the various software is an investment in time an effort so its sometimes daunting to contemplate change but if think Rocket3f would be a good replacement for anyone using Hexagon.
Keith
22 Aug 2017   [#44]
Hello, I have made a tutorial, were I Show two ways to get seamless surfaces, hope you like it :-)
http://moi3d.com/forum/index.php?webtag=MOI
22 Aug 2017   [#45] In reply to [#44]
Hi, Zarkow...
You've posted the wrong link, did you not ?
22 Aug 2017   [#46]
Oh yes, but now:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8559.1
20 Mar 2022   [#47] In reply to [#46]
Not sure how I overlooked your reply. Will check it out. Thanks very much and sorry in being so late in replying....
11 Jan 2024   [#48] In reply to [#47]
I just stumbled upon this MOI3D timelapse video on modeling a Morris Military truck and thought some of you maybe interested.
https://www.youtube.com/watch?v=7HfLrMmGUgM
