11-30
31-50
51-70
71-90
91-95
Hi Chipp,
> You wrote : "My ideal concept modeling workflow would be a bit different from yours:..."
It's a very interesting workflow, but there's a thing that I don't understand.
The points 2 and 3 (Paint and Magically RETOPO) shouldn't be swapped ?
That is, I usually follow this workflow :
1) Create voxel/surface high poly models
2) Retopo
3) UVing
4) Paint and texture
5) Export all to Render software
> You wrote : "... I use the Hide Voxel mode as well. It's better than the Split..."
I agree with you. I have seen too that Split has that bad behavior.
P.S.
Just for an additional info, some minutes ago the InstantLight dev team has released the FIRST public beta of IL.
(Stable FREE TO TRY PUBLIC BETA DEMO V 1 . 97 E)
It is still currently in uploading and in a few minutes it will be available for downloading.
You can get it using this page :
http://www.instantlightrt.com/beta-demo.html
See you and best wishes for all your works.
Hi Chipp,
I'm a bit curious how come you have decided to go with 3DCoat instead of ZBrush?
Lately i am considering to learn either 3DCoat or ZBrush and i really just can't decide which one to choose
to learn since i kind of don't want to go through "just try both and see which one you like" process.
I know pros and cons of both software and what is the main differences between those but still, you know,
one day i see someone doing great stuff with 3DCoat, few days later something awesome in ZBrush again.
Or if happens very possible scenario where i start learning 3DCoat, buy licence and then few month later ZBrush 5 gets released
and who knows maybe with Voxels workflows, better painting tools (PBR), etc...maybe not, but i have that type of luck so it's
actually very possible. :)
So why did you decided to go with 3DCoat? Any very specific reason?
Thanks!
Hi klaudio,
First of, to be sure, I'm not a topology modeler expert. In fact, I'm not a 3D modeler expert-- and I say that so that you understand my purpose for using programs like MoI3D, SketchUp and now 3D Coat.
I also use Lightwave* as a SubD modeling tool-- but for different reasons. FWIW, I'm also now starting to play around with Unity and UE4. I like KeyShot as a main renderer, though Octane is fun, but not finished enough for me. )
The single most important point issue for me w/regard to modeling (and rendering) is simple:
It must have an easy to learn, easy to use, and fast to develop with UI. The purpose for this is I don't spend all my time in the 3D world. I use lots of other programs, (Pshop, Illustrator, AE, Muse, Videoscribe, etc.) and even spend time programming from time to time-- plus I am a business strategy design consultant and while sometimes this requires me to use 3D, it also requires lots of other skills as well.
So, if I learn a program, like MoI3D, it may be months before I use it again and I need to be able to jump back in without much help.** In order for this to work for me, the programs I choose to work with may in fact allow for trade-offs. For instance certainly MoI3D's major selling point is the acceptable trade-off of a great intuitive interface vs the ultimate power of other harder to use products, like Rhino (which I also have a license for but choose not to ever use).
Sorry for the long winded soliloquy, but IMO it's important to understand the reasons I use for choosing one product over the other.
So, in looking at both products, and my requirements for hard surface concept modeling and speed, 3D Coat eventually was the correct choice. But frankly, I originally started to look again at 3D Coat (via help at these forums) as
the fastest and best way overall to quickly create UV maps for MoI3D, while also providing a decent PBR mapping solution. It's like getting a great UV mapper with very basic PBR capabilities of Substance Painter (and Designer).
Even if you do nothing else but UV map MoI3D objects and texture them (a
good tute for that), 3D Coat is definitely worth the price.
I had actually tried hard surface modeling in 3D Coat years ago and concluded it just wasn't up to the task. Fortunate for me, Marco and others here on the forums pressed me to give 3D Coat a try for modeling. Just as going from the poly world of SketchUp and Lightwave to the NURBS world of MoI3D, switching over to voxels is a bit mind bending.
I spent a good amount of time researching workflows and purchased several tutorial video series, among my favorite ones include:
I pretty much viewed them all in that order. I would download them to my iPad and watch them on trips (I got a lot done on a trip to China!).
Jama pointed me to the potential of using 3D Coat as a sketch tool, like Photoshop. He also focused on
just enough detail where you don't need things perfect-- which is really hard for a NURBS person to grok. In fact, I saw some Zbrush KeyShot renders and thought they were a bit 'doughy' and wondered if tight models can be had in topology modelers. Jama's tutes showed using scale and complexity to fight 'doughy.' Plus he had some interesting KeyShot hacks as well. Sadly, Jama's 'basic teaching' of 3D Coat wasn't very good. Overall, I was quite satisfied with his tutorials, even though they were the most expensive.
Scott Turners tutorials are great for the basics. While not as exciting as Jama's, he did spend more time going over the tools and how to use them. Also good value.
A 3D buddy of mine on the west coast turned me on to
Fuad's tutes. They have no sound or captions, so aren't of great value other than watching and taking notes. At first I was quite disappointed, but then I did find some interesting techniques. I suspect his and Jama's will provide for more insight as I continue making progress.
You know the difference between voxels and pure topology, and I'm told 3D Coats voxels are superior for quickly sketching with geometry. I'm pretty sure those interested in creating cartoon figures, dinosaurs or other character modeling may wish to use ZBrush as I believe it can create even finer resolution maps (normal and distortion) but I think it's more of a Rhino solution than a MoI3D Solution.
One serious caveat for 3D Coat. You cannot UV map a voxel model. That means you can't use the great PBR shaders and UV map tools unless you RETOPO the voxel model-- which for a model like the one above is quite a problem. It has 8 million polys and no UV mapper I know of can auto map it-- including 3D Coat's own auto mapping routines. The same is not true for ZBrush with regard to KeyShot-- as they have a special KeyShot plugin so there can convert the high density models with PBR maps intact. This is a major PLUS for ZBrush. Plus smart PBR shaders can help hide surface defects of topology modelers. All that said, I really don't know how well any of this works in ZBrush and would be interested to learn more.
I'm still trying to figure out the simplest way to get from voxels to UV mapped polys in 3D Coat. The RETOPO function is fairly powerful, and I suspect I'll just have to dive in.
Lastly, one of the more important and new features of 3D Coat is it's
Live Clay feature. With this it's possible to create stunning levels of tiny detail which help fight off the 'doughy' look. Oh, and if you're into 3D printing, 3D Coat is really good with it as voxels are solid, unlike ZBrush polys.
Congrats if you've made it through this rather long-winded reply. I'm always looking for faster and easier ways to generate concepts. Below is a couple of concept models I created in only a couple hours today. Could never have done this with NURBS or Polys that fast. :-)
Lightwave is the exception as I learned it 20+ years ago. It's very complex, but I've put in enough hours to figure my way around when I need to!
An interesting way I do this is when I begin to learn a program (MoI or 3D Coat), I document some of the most important things I need to learn via YouTube which makes it easy for me to go back and learn them in case I forgot! MoI3D channel ->
https://www.youtube.com/playlist?list=PLnK-YGmMYI75_4Bn8HT4HNVkaMp3y1tSw
Chipp Walters said:
"One serious caveat for 3D Coat. You cannot UV map a voxel model. That means you can't use the great PBR shaders and UV map tools unless you RETOPO the voxel model-- which for a model like the one above is quite a problem. It has 8 million polys and no UV mapper I know of can auto map it-- including 3D Coat's own auto mapping routines. The same is not true for ZBrush with regard to KeyShot-- as they have a special KeyShot plugin so there can convert the high density models with PBR maps intact. This is a major PLUS for ZBrush. Plus smart PBR shaders can help hide surface defects of topology modelers. All that said, I really don't know how well any of this works in ZBrush and would be interested to learn more."
How about this: While in Voxel mode, export your high-res model under "export object" then start with an empty scene and import your high-res model with "import per pixel painting", which then creates an UV Map with the size of your choice and you can use then your PBR shaders. This should give you the results you are after, imho.
Hi Stephan,
Yes, I've tried that but for 8 million poly objects, it just won't work.
I'm trying a new workflow, where I'm decimating the OBJs (by 70%!) before exporting (using the Decimate command under Geometry Window). The biggest problem with this is I really don't know how this will effect my Live Clay topology.
I may consider adding in the really small details in PAINT (normal and diffuse) instead of using D Clay.
More tests...
UPDATE: Amazingly, even a DECIMATION of 86% and the very small detailed polys are kept well. Now this is a superb answer to the issue:-)
Hi Chipp and good morning.
I want to thank you for this HUGE sharing!!
It contains many very interesting points of view, and also the link to the tuts you bought are very useful.
I put your post into my list of preferred :)
Have a nice day,
Thanks Marco.
Here's what I've figured out so far>
You can just about retain perfect voxel resolution with a DECIMATE of 70-85%. The problem is you need to do this for each and every layer (shortcut key!) In the picture below are 3 of the same models at various levels of polygon reduction.
The closest part (far left) is the original 4.1M poly model. Notice the little parting line on the side of the top.
The next part is the model with a 70% DECIMATION equaling 1.2M polys.
The next part is the model with an 85% DECIMATION equaling 620K polys.
The last part is if you just EXPORT as SCENE and try and reduce polys then. It is set at 80% and is 831K polys.
As one can see, there's little change on the three on the left. The EXPORT as SCENE option with reduce polys is no good. So, each and every layer should be manually decimated somewhere between 70-85% (as they suggest).
This enables exports that can then be reimported and PBR mapped, then exported again.
Here's the model tests (rendered in KeyShot-- click to view full size)
And here's a quick proof of concept where I created a model, decimated it, then added PBR maps in 3D Coat and exported to KeyShot!
Hi Chipp!
> You wrote : UPDATE: Amazingly, even a DECIMATION of 86% and the very small detailed polys are kept well. Now this is a superb answer to the issue:-)
I tried myself and it works for me too!! Thanks a lot.
For the test I'm using both InstantLight latest public beta and Marmorset Toolbag 3 : All worked fine.
But I'm waiting next tutorials from InstantLight creators to see how to use their new "standard vertex shaders" to directly
render voxel/high-poly objects painted directly in 3DCoat.
I know that, like you said, InstantLight has a very "peculiar" and strange UI.
I don't like it at all and I said this to the developers team, but IL also present here a new Bridge to 3DCoat still undocumented and I'm really curious
to see how it works.
Realtime Global Illumination with IL seems to be much, much faster than Toolbag 3.
Anyway, it seems that all this new tools are helping me a lot to complete a very good and effective workflow that meets my needs :
Nurbs : Moi/Rhino
Poly SDS : NVIL/Rocket 3F and sometimes the old but ever green DAZ Hexagon 2.5
Voxels, High poly sculpt, retopo/uving, 3D paint : 3D-Coat
Realtime renderer : Beta testing of InstantLight while taking a look also at Toolbag 3
OffLine renderer : Thea Render
It seems that all these things are finally getting closer to square the circle!
Ciao !
Hi Chipp!!
Wonderful contribution!!! Thanks a lot!!
I suppose that prototype modelling has never been so fast before 3DCoat!!
The decimation quality is superb in most cases!
But I think that we can still do a BIG BIG step about the quality of the Hard Surface and the Hard edges.
3DCoat can do much better in that field and also I have to learn a lot to achieve this task.
I think that the 3DCoat forum and its Youtube channel can help us a lot.
Thanks again and have a nice day.
Just a quick render to see how the PBR textures in KeyShot 'take.' There's still work to be done there. I may try it in Octane.
Hi Chipp!
Here's another quick and dirt hard surface little different workflow with Moi->3DCoat->Toolbag 3
1) I did this versy simple hard surface obj in Moi
download at :
http://take.ms/5r67O
2) Export from Moi to obj
3) Import in 3DCoat for "Per pixel Painting"
This is the 3DCoat file :
http://take.ms/fLoOh5
4) Exported and quick rendered in Toolbag 3
This is a pseudo-turntable video :
http://take.ms/C8ilz
Ciao!
Hi Chipp,
First of all thank you VERY much for in depth reply! I read it all! ;)
Thanks also for all the suggestions! I already knew about those guys - Jama. J and Fuad Quaderi. I really like
Fuad stuff and he is big part why i want to go with 3DCoat too. I like the result of his helmet tutorial, looks really clean!
I guess i will also go with 3D Coat...just trow myself in and see what happens. I also wanted tool which will help especially
with initial concept then either make out of it nice polished model in Moi3D and Maya but also a fast concept "sketch" that can stand on it's own
by just work a bit more on it 3DCoat, some texturing, nice presentation and that's it.
Here it is, btw, my portfolio and stuff mostly did with Moi3D but also a lot using Maya booleans or/and subD workflows >
https://www.artstation.com/artist/klaudio2u
I just feel like i miss "sketching" part in both 2D (something i am working on currently) but also in 3D with, i guess, 3DCoat for now... :)
Once again, thanks for all!
Hi klaudio.
Congratulations for your portfolio!
Personally I don't like robots and/or weapons in general but technically speaking it's an awesome stuff!!
Hi Chipp and everyone.
Here's another very simple test done with Moi3D->3DCoat->InstantLight
Experimenting InstantLight features :
- RealTime GI (Global Illuminaiton)
- LUT Effects
- Dirty and noise effects
- Bloom and flare effects
All in real-time on my i7 4790K 4.4Ghz 32 Gb Ram Nvidia Quadro K3100M 4Gb Display resolution 1920x1080
I bet that with very powerful hardware (like the monsters owned by Chipp or Zarkov) the speed should be awesome!
Here's my screen video capture :
http://take.ms/kDjXA
On My DSL today the streaming is very slow, maybe you can watch it better if you first download.
Best,
Everyone is looking for the holy grail of retopo methods when doing Hard Surface modeling in sculpting apps.
Perhaps have a serious look at Houdini for this, because it supports OPEN VDB, and can work with voxels seamlessly, and from there use the polyreduce SOP which is pretty powerful with some advanced decimation features.
Hi marco,
Thanks for sharing. I'm waiting on a tutorial on how to use Instant Light!
Thanks 2byts for the Houdini info. I'll check it out.
Here are some more quick modeling exercises. These were all done in an hour or two of modeling, then a quick setup and render in KeyShot.
Hey Chipp
I found this course on retopo in 3d Coat
https://www.udemy.com/retopology/learn/v4/overview
At £15 (half price today) pounds it seemed worth a punt. I dont know when I will have time to have a go but if I learn anything useful I will share it here. The trouble with being a nurse is that I don't get much time to experiment with this software. The trouble with being 55 is I forget what I learn in between sessions;)
Best regards
Keith
Hi Keith,
55? Oh, to be young again! FWIW, I do have the same problem trying to remember all the stuff from various programs-- that's one reason why I make YouTube tutes.
Thanks for the iink-- bought the course and also bought one of Scott's AE courses (I have a video project due in the next couple of weeks).
Hi Chipp!
You're welcome.
> "... quick modeling exercises.."
Did you create all that "quick modelling" in 3D-Coat from scratch in two ours ?
Chipp, listen to me.....you're becoming a Master!!
I wait tuts from you!!
> "I'm waiting on a tutorial on how to use Instant Light!"
I've been practicing with this new very interesting brand new tools and it seems to be very very promising,
and me too I'm waiting new tuts from its developer :)
Thanks for your sharing and have a nice day.
Here's a random assembly made just to see how my actual config can handle with decent speed
high-poly count voxels in 3D-Coat.
Well...on my laptop (i7 4790K 4.4 Ghz 32Gb Ram Nvidia Quadro K3100M 4Gb) almost all modelling processes remains very responsive,
while only realtime rendering is very slow.
4 objects, 26Mil polygons.
Here's the render retouched with the great Affinity Photo.
Best,
11-30
31-50
51-70
71-90
91-95
