Full Version: Rocket 3F polygon modeling with bridge to MoI and 3D Coat
Show messages:  1-16  17-36  37-56  57-76  77-96  97-111
4 Dec 2016   [#37] In reply to [#36]
Will come back surely in next versions! :)
19 Dec 2016   [#38]
Rocket 3F crashes on my PC with i7 6700 and GTX 1060, but works on my old laptop. Any idea?
19 Dec 2016   [#39] In reply to [#38]
Go to Rocket forum! ;)
https://rocket3f.com/forum
Message 8092.40 was deleted
31 Dec 2016   [#41]
Hi everyone!
I intentionally deleted my previous post about Rocket3F because I'm not in the habit of place publicity of any software into forum of other software,
and I want to avoid any misunderstandings about that because I'm not linked in any way with its developers.
But I write these lines only for one reason :
Because I love every new software that like Moi is capable to break the barriers,
and i think that this newcomer into 3D modeler market can be a valid companion also for Moi's users
Well...with that said....
Finally the all brand new Poly/SDS modeler Rocket3F is on the market and the purchase should be activated soon.
It comes from Istonia, the creator of NVIL, and from Andrei Samardac for the streamlined workflow.
This is the web site : https://rocket3f.com/
And this is the official Youtube channel : https://www.youtube.com/channel/UCxJIYl9qcwyCSakhVC0vuvQ
I'm both an NVIL licensed user and a beta tester of R3F for a long time, and I must admit that it has won all my doubts about it.
It's ONLY a pure Poly/SDS modeler, that occupies a very small niche, nothing more, but what it does it does very well,
and it's especially focused on two things :
1) IMHO it has the best and fast workflow on the market (I have tried tons of Poly/SDS modeler right now from free to very expensive (in demo))
All the tools are designed for fast conceptual modelling
2) It has some absolutely unique features for Subivision Surface Modelling!
Look at this Youtube tutorials for its excellent Crease features : https://youtu.be/YhP784XnD-M
And it also have a very good built-in Bridge to :
- Moi : From <-> To. Look at this my very simple example : http://take.ms/iXgiO
For subdivision in Moi it leverages on the superb Max Smirnov SubD script.
- 3D-Coat : From <-> To
- KeyShot : Never tested because I haven't KeyShot
I think that now Moi has a valid counterpart about the best workflow :
Moi for Nurbs and R3F for Poly/SDS conceptual modelling.
Best,
Message 8092.42 was deleted
1 Jan 2017   [#43]
With the 1.43 bridges are come back! :)
(not for me because I have a little problem with my antivirus)
Else program works fine ! :)
Some tricks
1 Jan 2017   [#44]
Version 1.0 Released!
4 Jan 2017   [#45]
There is a free version with infinite month renew!
4 Jan 2017   [#46]
Funny that you promote so much Rocket3D here on the MoI forum.
I remember when you posted almost every day on the Silo Forum about MoI.
Maybe you should start also on the Rocket3F Forum a MoI thread, so that Andrej can appreciated it... :-)
4 Jan 2017   [#47] In reply to [#46]
I promote generally only that it's free and complementary! :)
4 Jan 2017   [#48] In reply to [#47]
Thank you Pilou:happy new year :)
4 Jan 2017   [#49] In reply to [#48]
@Mauro
Thanks and happy new year for you too! :)
8 Jan 2017   [#50]
Hi everyone !
Here's my latest test involving both Moi and Rocket3F in order to gain skill in modelling some mathematical
and mechanical objects that I'm going to modify in R3F to obtain more organic models.
https://rocket3f.com/forum/showcase/115-experiments-and-epic-fails?start=135#2239
Have a nice day.
8 Jan 2017   [#51] In reply to [#50]
Using Max Smirnov's DistortCurves you can have this "organic" shape in few click in MoI.
8 Jan 2017   [#52] In reply to [#51]
Hi PaQ!
Oh yes....I already knew DistortCurves and things like that, and how to do almost all these kind of stuff using a Nurbs environment,
but now I want to dig more in depth Poly/SDS modelling, because it can offer a greater degree of freedom in some situations,
especially for organic modelling.
I'm learning how to use both worlds in an effective way.
But anyway thanks a lot for your reply :)
See you.
9 Jan 2017   [#53] In reply to [#52]
Marco, thanks, I second that, perhaps we can get the best of both worlds,
MoI for hardedge and Rocket3F for organic shapes.
9 Jan 2017   [#54] In reply to [#53]
Best of the 2 worlds is cool, but it's even better when both approach co-exist in the same application.
T-Splines, and Cyborg3D for instance have some very nice functions that mix curves, nurbs surfaces, and subdivision surfaces.
https://www.youtube.com/watch?v=Gf1lNAGEalQ
10 Jan 2017   [#55] In reply to [#54]
Caging NURBS is a great way to go for those that like to push and pull.
It gives you the ability to "monitor" what doesn't really JIVE with a NURBS surface and what's working.
So you can finish all the bending and twisting while NURBS, then go out to poly and not bring it back!
10 Jan 2017   [#56]
Hi PaQ and BurrMan and good morning.
Oh yes....T-SPlines is a great thing and, although Fusion 360 has a downgraded version of it, it's very useful and powerful when properly used.
And yes, I already knew and in my recent past I've used and experimented a lot with Cage/CageEdit in Rhino V5/V6 WIP.
Also these tool are very powerful in some situations.
But, for what I want to experiment and create in this period, I think that the agility and and easy of use and the speed of working
directly with mesh's vertices/edges/polygons can give me a very good and fast way to create good organic modelling with SDS,
because, when properly used, this technique can offer a degree of freedom that actually can't be reached by T-Splines or other pseudo-Nurbs
technology.
Nowadays, for what I know and I have read, Poly/SDS is still the best and fast and easy way to freely model organic things.
Many engineers and software houses have invented their own technology to make possible the "marriage" between Nurbs and true organic modelling,
for example SolidThinking Evolve and many others (T-SPlines, Clayoo) but for what I have read in many technical articles written by many experts,
all these technology for the moment, are incomplete or too heavy, and still the "plain and dirt" Poly/SDS approach is still the best.
But anyway all these stuff are very interesting things.
See you,
