Show messages: All
1
2-9
Hi Pierre - MoI exports AI files using the AI v8 format. The AI file format changed a lot around AI v10 or so, I think Inkscape only supports reading the newer kind which are actually PDF files.
For going into Inkscape, I would recommend using PDF format, since Inkscape does not support reading in the type of AI file that MoI exports.
thank you
hi grandpi
i owned Inkscape 0.48 and MOI 3.0 ( with WINDOWS XP )
it works for me.
I export from M.O.I in .ai file
I import in Inskape using Adobe Illustrator 8.0 and .... ( take a look on the following pictures )
Chri
Hello Christian,
Thank you for your reply.
Inkscape 0.91 (last version) cannot import MOI 3.0 .Ai export. : Back to the past (or use .PDF)!
Regards,
Pierre
works fine under OS X.
Don't work with windows for me ? Strange ...
Pierre
Don't work for me too (Windows 10)
If it can be of any help, when exporting from MoI Mac version, I first open the file in Illustrator for Windows and save it (Converted). Then I'm able to open it with Inkscape .91 Windows version.
Michel
Show messages: All
1
2-9
