Full Version: Spiral script 2D for setting out Corinthian capital scrolls
Show messages:  1-10  11-30  31-36
30 Mar 2016   [#11] In reply to [#8]
Sorry Andy, IonicVolute is not written yet. Those were the numbers and formulas needed.
It may take an hour or three to code, after work.
Have you tried a relaxed PolySkelion script?
There are also the Galaxy spiral script and the GalacticSkelion script, but they have limited range until they make a bunch of stray lines.
-B
30 Mar 2016   [#12]
Here is an alpha version for IonicVolute.
It works, but still needs some improvement or corrections.
I'm guessing atan may be a problem.
10 minutes to code, 10 minutes to debug, 30 minutes to fiddle.
Edit: See post 7903.16 for updated, corrected IonicVoluteAlpha02.
30 Mar 2016   [#13] In reply to [#11]
Ok No problem Brian
Polyskelion looks good although the transition from one spiral to the next is not as smooth as I would want so may do manually for a clean S form, each of the individual spirals created are pretty good though
Your help with this is very much appreciated
Andy
30 Mar 2016   [#14] In reply to [#12]
Ok wow that was quick Brian
Can I make a donation for your time and effort ?
Possible improvements to the control the output
A) The spiral lines increase in distance apart smoothly, which is spot on :-) but can we control this increasing % in any uniform way ?
B) Also would it be possible to control the inner starting radius or diameter ?
The a & b values control in the script ? the size of spiral produced using the script seems to be about 25mm / 30mm - can this be increased if the maths allows or do I just need to scale up ?
atan - ? not sure what this refers to ?
This in effect will become the artist perfect set of french curves in MOI if you can devise a way to control A & B above
best wishes
Andy
30 Mar 2016   [#15] In reply to [#14]
Hi Andy,
No donations please, this is for hobby/ fun/ occasional utility ☺
The script can likely be improved. I do not feel that I have a good understanding of the math yet, including "a" radius, "b" radius, and eye radius.
-B
31 Mar 2016   [#16]
The IonicVoluteAlpha01 had a glaring error in the formula, bvalue instead of the correct beta.
The default parameters now re-create the volute with the "historic" proportions. The two end tangents are not horizontal.
Added a parameter for the eyeRadius, the inner end of the spiral. Renamed bvalue to bRadius.
In the event that the eyeRadius exceeds the bRadius, the bRadius is "inner" rather than "outer."
Negative values for Whorls or eyeRadius are strange. May add absolute value to them.
Next to do are sliders, counter clockwise, and start angle.
- B
_IonicVoluteAlpha02.zip
31 Mar 2016   [#17] In reply to [#16]
Brian
Hey great, its working just fine thank you :-)
Look forward to the final version
Andy
4 Apr 2016   [#18] In reply to [#17]
Here is the "final" version of the IonicVolute script.
After creating one spiral, making a second spiral, with the only change being the "offset" parameter, leads to an interesting surface or extrusion, which can be filleted.
The notes were modified, and are in the .js file. The tangent equation was substituted into the logspiral4 script, with additional modifications.
_IonicVoluteAlpha03.zip
4 Apr 2016   [#19] In reply to [#18]
The "inside" of the spiral:
IonicVoluteOffset04Inverse.3dm
5 Apr 2016   [#20] In reply to [#18]
Great thank you Brian
The sliders are a big help to get things looking visually right for my projects
and your offset spirals look good, looking forward to playing with the script properly
I have updated my LogSpiral script to version 4
Again many thanks for all your work on this
Best wishes
Andy
5 Apr 2016   [#21] In reply to [#20]
Thank you Andy.
- B
6 Apr 2016   [#22]
http://moiscript.weebly.com/geacuteomeacutetries-par-bemfarmer.html
French version
6 Apr 2016   [#23]
Awesome script
Thank you
James Elliott
9 Apr 2016   [#24]
This trial version adds a Z axis offset, for a 3D spiral, in 3D view.
-B
_IonicVoluteAlpha04.zip
9 Apr 2016   [#25] In reply to [#24]
Thanks Brian!
Off topic, sorry.
10 Apr 2016   [#26]
Ionic volute of Giuseppe Porta Salviati (1520-1575).
There is an excellent video here:
https://www.youtube.com/watch?v=HBh04ZtnLDM
The 3 "quarter circle" arcs in the upper left are actually slightly more than quarter circles.
Intersection with the eye is not quite tangent.
SalviatiVolute01.3dm
11 Apr 2016   [#27]
Hi Brian
Will it be possible to make the script use an other folder than the original "command" folder?
I am currently using a subfolder to the command folder containing the scripts i use often, here i also put new scripts for test so they are easy to find :-)
11 Apr 2016   [#28] In reply to [#27]
Hi hep - there are 2 different ways that scripts can be run, either as a "command" which has UI associated with it (like in this case), or as "immediate script".
For the command type those have to be located in MoI's command folder in order for MoI to run them.
11 Apr 2016   [#29]
Hi Michael
Thanks - i see.
that was a quick answer - I just love this program and it's forum :-)
11 Apr 2016   [#30] In reply to [#28]
...what about the "scripts" folder instead ?
I see that also this folder is a suitable place for scripts, that haven't a UI associated, in order to be executed.
Thanks and nice day,
Marco.
