818-837
838-857
858-877
878-897
898-917
918-937
938-957
1858-1859
Path animation
actually very easy with the existing nodes... but (sorry Karsten ich habs schon wieder gemacht... ;-) the quarz nod needed just a little tweak.. to sync the quarz with the path_array Div i added Min and Max as an input.
Max's new SWITCH got also i nice place in the CameraMacro (which now also follows pathes)
pathanim.3dm
pathanim.nod
r2d3.js
Hello Ralf,
Thumbs up!
Looks like you having fun! Every change is allowed here! Hauptsache wir haben Spass!
Have a nice evening
Karsten
can anybody tell me how to run the latest nodeeditor in moi V4 portable. i have tried the usual method and the latest as below.
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Barry
Hello Barry,
I've placed it in the standard UI folder with >>> moi.ui.createDialog( 'nodeeditor.v.0.99.2017.12.18/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); <<<<<
Should work also for you.
Have a nice day
Karsten
Hi Karsten,
did that to start with I am only getting a white window.Installing previous version of node editor same result.
There was some discussion between Max and Michael about the portable version not sure if it's been resolved.
Barry
Genau!
Lets have some funny nodeling !
Hello Barry,
please check your path in detail - if there is no fault, try a complete/absolute path e.g. moi.ui.createDialog( 'X:\MoI_V4 beta\ui\nodeeditor.v.0.99.2017.12.18/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Hope it helps
Karsten
Hi Karsten,
still no luck perhaps this discussion
http://moi3d.com/forum/index.php?webtag=MOI&msg=8704.48
as something to do with it.
I have looked at the index.html and it references the appdata path, if that means anything.
Barry
Hi Karsten,
this is the error from a direct path.
SyntaxError: \u can only be followed by a Unicode character sequence
line 1
1: >> moi.ui. createDialog ('D:\MoI V4 beta\ui\ nodeeditor.v.0.99.2017.12.18/index. html', 'resizeable,defaultWidth:680 , defaultHight:420',moi.ui.mainWindow );
Barry
Hi Barry,
In a JavaScript string the backslash \ character is used as an "escape" so you can make characters like \t meaning tab, or \uXXXX for a unicode character. If you want to make an actual backslash you need to put in \\ .
But it also looks like you may have some extra spaces in various places causing problems, especially "index. html".
I'd recommend trying 'nodeeditor.v.0.99.2017.12.18/index.html' - that should look for it in your MoI ui folder. Note there should not be any space in the middle of index.html
Hello Barry,
fits the path exactly to your configuration? Please open the file path to the index.html and post a screenshot of the explorer or dolphin or other file manager, depending of your OS. then we can have a look.
Until soon
Karsten
Hi Karsten,
here it is.
Barry
Hi Michael/Karsten,
sorted my typing leaving spaces seems to have been the problem.
Many thanks
Barry
Hello Barry,
sorry I have placed backslashs as slashs in my path example. But is it possible that there is a space in the relative path as Michael mentioned. I don't know how spaces are handled in js for a absolute path - in windows are used "x x " as I remember. So I don't have a solution:-(
Sorry
@r2d3
Does your file r2d3.js is the previous one increased with new functions or it's a totally new one at each time ?
Else!
(not yet translate all your new buttons! ;)
Hello Ralf!
...WOW !!!
Supercool!!!!
Congratulations :)
Hello Pilou,
the error comes typically up, when basicFunctions.js is missing in the nodes/extensions/libs folder. It contains some basic vector math functions. Pick it up from a previous installation and copy it to the folder.
Have a nice day
Karsten
<<<<Does your file r2d3.js is the previous one increased with new functions or it's a totally new one at each time ?
Hi Pilou, yes my r2d3.js is a work in progress... this time the quartz2 (with the new inputs) is in it.. so just override the existing one with the new one.
Hi Karsten,
just a nother question about your extensions.
I was looking into your intersectObj, and separateObj. There is a lot of "out commenting".. and i dont get what i expect from them..
I was playing with your msweep.nod and i was wondering if it is also possible to add the seemedEdge of the baseobject to the generatet IsoCurves.
With the separateObj i got access to the faces with the intersectObj i dont get anything...
Whats wrong?
Ok with the missing files basics in Libs folder that works better! (very labyrinthic to follow! :)
But now...does this normal ?
What is your parameters Smoothness and Speed ?
818-837
838-857
858-877
878-897
898-917
918-937
938-957
1858-1859
