697-716
717-736
737-756
757-776
777-796
797-816
817-836
1857-1859
Thanks Max
That has fixed the problem.
I have attached "extension.zip"
with fixed infonodes.js included
Thanks again
PS Attempt to run "pentakisDodeca&TruncIcosa.nod" (attached)
gives the error message in red box, however does generate result
albeit with pentakisDodecahedron in default colour rather than red.
Generally, I get the main error alert showing when navigating in
NE interface.
Hope this helps!
About Truchet above
Seems it's these red nodes who give problem! (Windows 10, NE modified, Moi V 3)
<< Also requires most recent NE mod (Karsten's cleanup menu)
Hum hum ... so need them ? Give me a zip package! :)
If i have not an easy way (for me), how do you want i can help for other French people! :)
Hi Max & James,
> You need to set boolean parameter for getBoundingBox() function
> change this line to: bbox.pushPoint(input.item(i).getBoundingBox(false).center);
This is a bug where v4 has that marked as a required argument while v3 had it as optional with a default value of false. I've updated it so it will behave the same as v3 in the next beta.
Message 7777.760 was deleted
hum hum :)
After some reinstalls of all ! (Windows 10 - V3 ) with editor.js & last editor.css
I have that who works fine for the Penta node...but not for the truchet.nod !
Some different authors for differents trees for differents versions goes naturally to some mess! :)
I dont understand why each new node is not posted with its entiere nodeeditor folder ?
That avoid all this mess for simple user! Not ecologic but efficient! :)
OK Pilou, I've attached my NE directory.
Let me know if problems persist.
Hi Pilou
It's a bad idea to keep old files in extensions directory.
NE loads all extensions automatically. So it loads basicFunctions first, and then loads basicFunctionsOLD which replaces a new functions with old ones.
Hi Max & Pilou
<< It's a bad idea to keep old files in extensions directory.>>
Sorry, that's on me. I had already removed it before uploading complete NE folder.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.762
Pilou, did my NE folder work for you?
@James
Bravo!
Perfect and the magic is that : Nodes's titles & Functions (that I have yet translated) are preserved!
What is this prodigy ? You have a French version or Max put it inside it own code ?
Excellent! V 3 : Truchet & Dodeca & truncated... ok !
For V4 Truchet OK ! Dodeca & truncated...
a little bug! And only one volume calculated!
Ps A little graphic glitch "?" inside blue square ! (surely an image missing inside the data image of the V4)
Friends,
yesterday, November 23 was the Fibonacci
day (11/23 as the numbers contained in its progression),
with pride I can say a "Great Italian "
I send a small tribute to this ingenious mind-
File this link:
http://www.mediafire.com/file/loyv9703apml409/Fibonacci2.rar
To all script experts, I suggest you enter
a series of Fibonacci (see tool Progression ) -
Have a Great Weekend to all
alberto
Hi AL (Ciao AL!)
@You : "...with pride I can say a "Great Italian "..."
YES!!!!
Ciao a tutti! (Hi everyone)
Just playing with nodes i came to a funny thing....
This thing not only moves - it collects the incoming points to draw a curve...
Because i was not able to do this with a existing node i made my own... Stream2Array (just put stream.js into the extension folder and you will find it listed under ArraysExt)
it works on MoiV4 and @y@0.99
This is my first extension so HANDLE WITH CARE ;-)
Perhaps someone can add some physics to this :-)
Ralf
EDIT:WOW in 3D! Or is it 2.5D? >>pentagraf3D.nod
pentagraf.3dm
pentagraf.nod
pentagraf3D.nod
stream.js
Genious!
I will test the translation on an extension!
Seems perfect !
You must precise precise inside extensions/ Libs/...
Ok for the translation (not for the nodes because I believe that I have not used the last version of Max Smirnov! )
I have 2 red nodes! :)
SplitPts & ArrayLogger
Does these 2 nodes are from the nodeeditor modified and not from the native original?
Thanks a lot r2d3!!!
Huge...great...amazing contribution!!!
Thanks again :)
Merciii! You translate faster then i program... :-)
the splitPts and ArrayLogger are actualy in the 0.99 from MAX site... build in..
The logger you dont need > delete
the splitPts just takes the X and the Y from the bbox center - pretty sure ther is a similar one which can do it..
most important the "Trame flot2" is NOT red :-)
Just made a nice vase with the pentagraph....
Ralf
That's a really cool one Ralf! - Michael
<< the splitPts just takes the X and the Y from the bbox center - pretty sure ther is a similar one which can do it..
Sorry i don't see it! Have you renamed the tittle of this node ?
What is this mystery? :)
The only Split i see is this one! (and it's not SplitPts ! :)
The splitPts is in the point2 extension..
ore you can use the basic/extract node (two of them)
These are the newest extensions by MAX
Ralf
extensions.zip
I start to like vases... :-) made by pentagraf...
Ralf
697-716
717-736
737-756
757-776
777-796
797-816
817-836
1857-1859
