657-676
677-696
697-716
717-736
737-756
757-776
777-796
1857-1859
Hello Al,
good news! Please tell me: Are there problems to convert the files?
Thank's in advance
and have a nice day
Karsten
Hi Karsten (and others),
Attached is a file with macro that converts a Brep to Edges & points.
I have tried modifying your "Extract" node by making line 212 & 217-220 into comments so that it only outputs edge curves. It works perfectly however is no use for the sharing of .nod files, & hence convert.nod attached.
I wonder though, if it would be difficult to add an "Edges Only" option to your node.
Perhaps, if this could be included, it might be an opportune time for a name change (to let's say "Derive"), so as to remove the redundancy of 2 nodes of the same name & not be confused with Max's Basic/Extract.
Anyway, this was just a thought
Have a great weekend
EDITED:
Better still, might be for Max to fold this functionality into a Brep option in his "Exract" node
Hello James,
what a surprise. I didn't planed to use the node in this way. It is pure coincidence, because no names are stored in the node and no names are given to the input. Typically it should be used in combination with the brepNameSubObj. So the node stores pre-selected names and filters it while running. I think there are different possible ways to solve it. You have already shown a way. Nevertheless it would be great when Max would integrate it in the next release of his extract node.
Brep - option on RMB and a filter/switch for edges and faces.
Have a nice day
Karsten
p.s.: Geometrical world trip: Welcome to Bruxelles:-)
Hi Karsten
Thank you for getting back to me.
Can you tell me is Objects2/separateObj effectively identical to Objects2/Extract if it had a "Faces only" option?
Geometrical world trip: Welcome to Bruxelles:-) ??????
Hello James,
The seperate node is identical with the separate command in moi - same factory. It smashes objects. Joined curves in segments, solids and joined surfaces in single faces.
Bruxelles:
https://en.wikipedia.org/wiki/Atomium
Have a nice day
Karsten
Karsten
RE:Atomium...Ahh now I get you
RE: SeparateObj
Cheers, thanks for info
how can I enter an adjustable range ( from calcs using maths nodes ) into the points node other than with the range slider.
Barry
Hi Barry,
<<enter an adjustable range.... other than with the range slider>>
Use objects2/concat2 node, with RMB option Numbers
Let me know if you need further clarification
Hello Barry,
of corse, you can. Start and end value can be calculated independent from each other. Then you have to concate them together as input for the points node.
Concate2 node can take numarray, pointarray and objects as input (RMB).
Have a nice day
Karsten
Concat2.nod
Hi James,
thanks can't tell you how long I've messed about trying different permutations.
Not sure if my memory is correct but did Karsten do a spreadsheet with node definitions on it ?
Barry
Hi Barry
Spreadsheet can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.200
Hi James.
Thanks you very much!
This is a very useful nod file!
Ciao!
Hi Marco (& others),
<<This is a very useful nod file!>>
Assuming you are talking about "convert.nod",
you may prefer to do what I have done,
which is to include new node in "objects2"
called "ExtractEdges"
It is simply Karsten's "Extract" node minus a few lines of code.
It achieves the same effect as convert.nod edges output
without issues that arise with multiple inputs & poly-surfaces.
Maybe you could look at it's code.
It is at the very end of the script.
I suspect that several more unnecessary lines
may be removed (or made into comments)
Hi James.
Thanks a lot for the "ExtractEdges" new node !
I will be very useful also for my "2D workflows" :)
Asap I'm going to look at its code.
Thanks!
Hi All,
Attached is .nod file to produce result as shown.
(not exactly as pattern is randomly generated)
It is a requirement for execution that "object2.js"
attached to my earlier post replaces similar in
"nodeeditor/nodes/extensions".
Also requires most recent NE mod (Karsten's cleanup menu):
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
It appears to be robust, but rename original
so you may easily revert to it if problems arise.
Wow!
Wanderful node James.
You rock!!
Ciao!
Looks cool James.
Hi friends
This is my last Macro- Rhombic Grid,
I thought of it as my utility for
the creation of the Clifford Torus-
Anyway I think it can be a tool
of wide use ...
at least I hope ,
the exercise at this link:
http://www.mediafire.com/file/0lpo8m4fxsselje/M-Rhombic_Grid.rar
Have a nice day to all
alberto
Nice node Alberto.
(note, getting an error with MoIV4 NEv0.97)
Many thanks Brian....
I have not yet tried Elephant with the New Beta V4
just released, my philosophy is to wait
Max puts his hand to new versions making
compatible
Thanks again.....
Have a nice day
alberto
657-676
677-696
697-716
717-736
737-756
757-776
777-796
1857-1859
