638-657
658-677
678-697
698-717
718-737
738-757
758-777
1858-1859
Hi Marco, what performance improvements are you looking for specifically?
Do you have a case with poor performance that you can post?
Hi Alberto &, Barry
<<Surely I missed some will last update of Karsten>>
Have a read of Karsten's post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
Changing to new menu system breaks old .nod files,
but it is much more elegant and efficient.
And Karsten describes a method for updating with
minimum disruption (for windows users, at least)
I encourage you to update, if too, only so I can appreciate
your brilliant examples
Hi James,
I agree update to Karstens post is the best option but it should be noted that old/new nod files that contain nodes that have been relocated can easily be fixed by replacing from new/old location.
As I found when running old nod files and the iso node was in test and I was running latest Karsten extensions and it had been moved to construct2.
Hope this explains my reasoning.
Barry
Hi James and Friends
Thank you all for the support...
Now the Retopo and Tile files work perfectly ..
I wanted to ask if, rather than following the Method
driven by Karsten, they could coexist inside
of the same Folder both old tools and new ones ,
perhaps renaming Js new files-
In this case there would be maximum compatibility between old and new
with the only Handicap to have more Tool Labels
What do you say ... can you do it?
In each case again thanks to everyone
for support
best
alberto
Hi James,
my request for extrude or shell is not needed.(I need to plug my brain in before asking)
By starting with a solid its possible to scale it in the w direction by just adding the scale node.
This will allow thickening of tiles that cannot be extruded ie: more organic shapes.
Again thanks
Barry
Hello Michael.
Please, don't consider my previous post as a sharp criticism of your job!
You did wanderful and amazing things with Moi!!!
I have said this many many times on this and other forums :)
But I think that I'm not saying nothing strange when I say that current Moi's Api performance are unsatisfactory.
For example they are absolutely not comparable to Grasshopper performance.
This is very evident when you run complex NE nodes or even a bunch of middle-complex nodes that are chained together and you have simply to grad a slider.
Often you have to wait secs or dozens of secs to see changes, also on fast computer like my desktop PC.
Same operations in Grasshopper are many times faster.
I repeat, I think I'm not saying nothing "fake".
I hope I made myself clear.
Marco (mkdm)
Hello Alex,
the path-rotate-scale stuff should be possible also. Have a look to the attached files. Caused by a little bug it is necessary to replace the basicfunctions.js in libs with the attached one.
@Al: I don't think that's a good idea to have both menu structures in one. Maybe you can have two complete versions of V0.97 with different extensions. But the better way would to convert the node files to the new menu structure. It isn't difficult. Maybe you van use an editor - it is also interesting to see the file structure. And faster as doing it with the nodeeditor native.
Have a nice day
Karsten
3D ARRAY OVER CURVE(1).3dm
parray.nod
Hi Barry,
<<By starting with a solid its possible to scale it in the w direction by just adding the scale node.>>
Alternatively apply extrude node to tile prior to inputing. However, either way there is an issue with the W dimension/Extrude not being normal to the surface across the totality of a compound surface.
The only way to achieve this at the moment with NE as is, is with offset node to base surface to mFlow 2 layers of tiles, then loft between them. (see below)
Ideally, the goal would be some form of panelling tools like Rhino's or Dynamo's.
If Michael does implement "cage editing" then NE could do the rest: populating inner and outer point meshes. That would be a dream come true!
Hi Alberto,
<<rather than following the Method driven by Karsten, they could coexist inside of the same Folder both old tools and new ones , perhaps renaming Js new files->>
If I understand you correctly, I think this may be a little unwieldily.
Given that there is just a handful of us, I think it would be better if we all just bite the bullet, & all be using the most updated version. After-all,Moi V4 is just around the corner, and so NE v1 will soon follow, which will invariably include change that will not be compatible with earlier .nod files.
Any past work that offers utility will, no doubt, be resurrected
Hi All
I want to share with you
another exploration regarding Height Torus, (umbilic)
this time,
the file is heavy enough, it takes a while
for display to screen-
how many interested people find the file on this link :
http://www.mediafire.com/file/bd9lihbbtda4tjd/Height_Torus-Umbilic_-V2.rar
Have a nice day
alberto
Hi Karsten and James
<<@Al: I don't think that's a good idea to have both menu structures in one. Maybe you can have two complete versions of V0.97 with different extensions. But the better way would to convert the node files to the new menu structure. It isn't difficult. Maybe you van use an editor - it is also interesting to see the file structure. And faster as doing it with the nodeeditor native>>I WILL TRY
MANY THANKS
alberto
Hi Marco, well one difference is that Grasshopper is implemented in a more optimized language, C# I think.
Most of the Node Editor is not implemented by MoI's API at all, its entire base implementation is itself in JavaScript.
The main purpose of JavaScript in MoI's built in functions is to use it more as a high level glue code, not really for implementing more heavy duty calculations entirely in script. The primary API change to increase MoI's performance for a heavy duty plugin like this would be to have a C++ API so the entire plug-in could be written in C++ rather than having tons and tons of script code. There is a lot of work involved in doing that though, I'm not focused on implementing and supporting a C++ API currently. Really even the script API is not a big focus, I'm still in the process of primarily working on things for the bigger pool of regular users and not really on developers yet.
But in order to improve performance I'll need a lot more specific information than just such a general description, I'd need to have an actual running example that I could test with over here, that would then enable me to profile it and see where most of the time is going. You seem to be making an assumption that all the time is being taken in MoI API calls but unless you have done detailed profiling it is not proper to make that assumption.
Hello Michael.
Well, first of all I want to thank you for giving me such a detailed reply. Much appreciated!
And this gives me the chance to argue with you about what you have written.
@You : "...one difference is that Grasshopper is implemented in a more optimized language, C# I think..."
I think too that this is exactly the main and unique big difference between current Moi's Api and Grasshopper.
For what I now Grasshopper was written in C#. C# can offer great performance.
@You : "...The main purpose of JavaScript in MoI's built in functions is to use it more as a high level glue code, not really for implementing more heavy duty calculations entirely in script...here is a lot of work involved in doing that though, I'm not focused on implementing and supporting a C++ API currently. Really even the script API is not a big focus..."
I already knew this things but thanks for reminding me :)
It's always been clear that Moi's is focused primarily on "realtime" quick and easy modelling workflow and not on "developing" or "scripting" side.
But remember that I'm always thinking as a software developer,
and while I respect your choice about the main focus of Moi, at the same time it's a pity that Moi can't offer a more sophisticated programming interface.
@You : "...But in order to improve performance I'll need a lot more specific information than just such a general description, I'd need to have an actual running example..."
Ok. I understand. I will try as soon as possible to give you more precise information and/or a use cases.
@You : "...You seem to be making an assumption that all the time is being taken in MoI API calls but unless you have done detailed profiling it is not proper to make that assumption..."
Maybe you're right, maybe not.
Sometimes it's really hard to understand where is the bottleneck because, for example, when a filleting operation takes many seconds
or a loft or a network, it's really hard to attribute these delays to a "bad coding" of a script.
But, as you said, Moi is absolutely perfect for lightweight and realtime operation, not for heavy duty calculation.
Ok. This is perfectly acceptable.
No problem.
This was your developing choice at the time of the first creation of Moi and it was undoubtedly a winner choice :)
Thanks for sharing.
Ciao!
Marco (mkdm)
Hi Alberto,
<<another exploration regarding Height Torus, (umbilic)>>
Amazing, as always!
Have you adopted the new node extension menu?
I managed to substitute nodes (ptExt & mLoft2) to get this .nod file to work,
but try as I may, I could not get your previous example to run.
I hope with the release of v1, we will all be on the same page,
and we will wake up from this compatibility nightmare.
Again, great work
It will be great if you implement object instances in new version of MoI. At the moment we need to run Clone factory for each object instance. Unfortunately this method is not fast enough.
P.S. Double click on background to show execution times of nodes.
Hi Max.
Thanks a lot for this example!
Cloning it's just one of the things that I had in mind :)
If I remember correctly right from the very first days of V4 announcement these were the "cornerstones" we ever agreed on :
1) 64Bit
2) Instancing
3) Grouping
I'm confident that during the V4 beta period Michael will give us 2 and 3 also :)
Ciao!
Hi Marco,
At some point I'd like to focus more on that. But unfortunately there's a lot of work involved especially detailed and time consuming support work for focusing on that area. One of my biggest limits in being a single person company is how much support is required by what I'm trying to do.
I should be able to make some progress though.
Thanks Michael for sharing.
@You : "...being a single person company...I should be able to make some progress though..."
I'm confident that you're doing your best :)
Thanks a lot for your support and best wishes for all your things!
Ciao.
Hi Max, yes instancing should help with making larger numbers of copied objects.
There is a kind of lightweight instancing built into the Transform factories currently, but it will only kick in if the factory is generating more than 1000 curves or more than 50 (setting from ProxyGenerationNumFactories in moi.ini) faces total. Also it's built around the regular transform commands where there's only one factory generating stuff and so when the command finishes it wipes out all proxies and not just the ones it made.
But I think it would not be difficult for me to refine this mechanism a little bit to give you a way to do a type of "preview mode" where you'd be able to generate a display of a lot of object copies more quickly.
That would be able to happen pretty soon, the full instancing is a bigger chunk of work.
Hi James
from now on, I worked using updated Karsten's NE,
but I still have many files to share with you, all made with previous versions of the latest update ....
so the advice I give you is to create a double folder, one with them
Old Extension and One with NE ...
in this way, you can open it from time to time, compatible Elephant
with everything....
Thank you for appreciation
Have a nice day
alberto
Hello Al,
good news! Please tell me: Are there problems to convert the files?
Thank's in advance
and have a nice day
Karsten
638-657
658-677
678-697
698-717
718-737
738-757
758-777
1858-1859
