Show messages:  1-8  …  509-528  529-548  549-568  569-588  589-608  609-628  629-648  …  1849-1859
25 Sep 2017   [#569] In reply to [#568]
Hi Marco
File directory is as follows:
nodeeditor/nodes/extensions/libs/basicFunctions.js
Ciao James
25 Sep 2017   [#570] In reply to [#569]
Hi James .
Ok. But...the extensions/libs folder of the official new releases of P. Elephant is empty.
Could you please give me the correct basicFunctions.js file ?
Thanks a lot.
25 Sep 2017   [#571] In reply to [#570]
Hello Marco,
please take all files of extensions from this source and copy them to the extensions Folder of the new Version.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8197.7
Have a nice day
Karsten
25 Sep 2017   [#572] In reply to [#571]
Thank you very much Karsten for the support.
Have a nice day.
28 Sep 2017   [#573] In reply to [#571]
Hi Karsten
A while ago, I asked you about surface to point conversion.
I realised that we already have nodes for this, but to simply it I've compiled them into a macro: "Surface to Points".
It is going to be very handy when we can share macros between projects
28 Sep 2017   [#574]
Good Morning James ,
Cool result ........
Bravo , Your Macro work fine-
best
al
28 Sep 2017   [#575] In reply to [#573]
Hi James.
Thanks a lot! This is a very useful node.
Very useful for replicating an object over a surface with the help of a bunch of Max's node.
Bye.
28 Sep 2017   [#576]
Hi James,
great work!
Today or tomorrow I'll release a new version with macros import-export support
4 Oct 2017   [#577]
UPDATED: randomWrapNEW.nod attached
To run on new NE mod:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8628.1
Hi All,
Here's an example for randomised pattern on a surface.
Macros certainly make node circuitry more elegant!
I can't wait to see what's Max's next great leap.
4 Oct 2017   [#578] In reply to [#577]
Jelly-Fish nodes style! :)
4 Oct 2017   [#579]
Suggestion!
I suppose that can be adapted!
4 Oct 2017   [#580] In reply to [#577]
Hi James.
WOW! Amazing node!!
Thanks a lot.
4 Oct 2017   [#581]
Hi Friends
I did my first Macro, thinking of creating something he could
simplify drawing work ...
In this case, we can create a circle for two points and radius
I think it works, at least to me it works
files at this link:
http://www.mediafire.com/file/deqjawbt6qn7077/M-_Circle_2pt%26radius.rar
Have a nice afternoon to all
al
6 Oct 2017   [#582]
Hi Friends
this is my second Macro, a bit more complicated than the other,
returns a three-point circle or arc ;
how many interested people find the file at the following link:
http://www.mediafire.com/file/yz5hf7sfxmgvorh/Circle-Arch_to_3Pts.rar
Have a nice weekend to all
al
6 Oct 2017   [#583] In reply to [#582]
Hi AL2000.
Thanks a lot for sharing!
Very complex nodes but very interesting for learning.
6 Oct 2017   [#584] In reply to [#577]
Hello James,
Regarding your randomWrap7.nod
Your randomized pattern on a surface is both impressive and very interesting, particularly because it is seamless all the way around.
How might one create such a pattern on a plane and get the left and right matching to allow seamless tiling, at least laterally?
Suggestions welcome.
Many thanks,
-- MindSet
6 Oct 2017   [#585] In reply to [#584]
Hello MindSet,
The pattern will inherently tile seamlessly regardless of orientation.
The only alteration to surfConvert macro necessary was to make polyline not closed.
At present this cannot be switched dynamically, otherwise I would build it into the macro.
See attached "randomWrapPlane.nod" file. I have shown 2 repeats of a 10x12 matrix, but you may change
to any combination.
RMB click of "Random" then select "Update" to refresh random pattern generation
to get desired result.
Have a great weekend
UPDATE: Mobius Wrap added: "randomWrapMobius.nod"
7 Oct 2017   [#586]
Hello,
I want to share a draft or better a proof of concept for some new nodes. They work not stable, has bad performance and are critical to their parameters. So don't try to use it for creating something serious. I am at the beginning to understand the problem in detail. It's something for a boring rainy sunday.
A nice weekend to all
Karsten
double-hex.nod
hypervar.nod
7 Oct 2017   [#587]
Hi All,
I'm experimenting with animating a mechanism using the quartz node as the cycle actuator (time line).
Can anybody tell me how to have various start points for different movements .
As an example Quartz set to start at 0 and end at 250 how can I trip a start of a movement at 50 and stop at 200.
Any ideas
Barry
7 Oct 2017   [#588] In reply to [#587]
Hello Barry,
start Quartz from 0 to 150 and add 50 with a math node? I don't really know what You want to do.
- Karsten
