328-347
348-367
368-387
388-407
408-427
428-447
448-467
1848-1859
Please switch under infos to visible -> no
I tried out the Hide Edges node written by Karsten, and FINALLY got it to work, both with the Motor2 node, and also with Barry's bottle feed screw node,
and my model of a RH screw.
At first the node declined to work, when inserted right after get object.
The Hide Edges node needs to be inserted right before the final Output node.
Also, wire the input of Hide Edges, before connecting the output to the Output node, or a recoverable error results.
"Off" in the Node Info panel means that edges are turned off, or not visible.
Karsten, you have written a very nice node.
Hello Brian,
Sorry for the error - I didn't tested it already. It is only a fast draft that should show, how it is possible, to hide the edges.
Maybe someone can improve it - I haven't the time at the moment.
Have a nice day
Karsten
Probably, if Hide Edges is inserted just after getting the object, other geometry nodes downstream cause edges to be re-displayed?
So put Hide Edges just before Final Output node(s).
On/Off can be changed from the Info panel, while the script is running.
Karsten, the script is superb as is!
Hi fellow Noders,
I am attempting to construct a parametric weave.
Attached are 2 failed attempts:
WeaveProto1 starts with a 3 dimensional point array with variable U & V + 2 in the W dimension, while
WeaveProto2 offsets 2 dimensional array in Z direction and bundles both arrays into a 3 dimensional array.
In both cases it was possible to selectively index weave in the WARP direction. However I was less successful with the WEFT weave (better with WeaveProto2, first row but not repeated)
Also even if the WEFT weave could be successfully indexed, there remains the issue of snipping the threads so that each row in both directions, is distinct.
Any thoughts?
Karsten,
thanks works great and having the ability to switch on or off is a bonus.
Barry
Hello James,
I don't have access to Moi at the moment, but a look in the file with an Editor shows me, that you used Concat2 for the Points??? Concat2 doesn't support a internal organization/grouping of pointarrays. So in my opinion, it is easier to generate 2 curves for both directions and make then a pattern of the curves. Nevertheless I will try to find some time in the evening (CET) and have a deeper look in the files.
Have a nice day
Karsten
Hi Karsten,
Thank you for getting back to me.
<<used Concat2 for the Points???>>
I used Concat2 on num arrays only. The point arrays were interleaved with Test/BundleArray which works perfectly for the application.
<<it is easier to generate 2 curves for both directions and make then a pattern of the curves>>
Yes it is easier, but also more limited. Ultimately I plan to map point arrays to compound surfaces for topographic woven skin.
<<will try to find some time...and have a deeper look in the files.>>
Thanks Karsten, I greatly appreciate it.
All the best
Hello James,
I have tried to maipulate the internal organization x-length and z-length of the pointarray, but the PointExt-node seems that it not support this feature/inputs at the moment. So I have to improve the node first. It is also possible to integrate the feature in the concat2-node, but that would cause wiered results with inputs of different length and wouln't help here.
The picture shows what I wanted to do:
With the xLength and zLength informations, the polyLine node can seperate the pointsequences and produces independent segments.
I will try to solve this in the next days.
Have a nice day
Karsten
Hello James,
After a deeper look into the PointExt-Node I saw, that the feature is already supported - it was my fault. I've forgot to connect yLength. Find attached an example how to solve this issue.
Have a nice day
Karsten
weaveProto1.nod
Curve node may be used instead of polyline.
Hello Karsten,
Thank you for your help, it works perfectly.
To use the curve segments as discreet sweep rails,
it was necessary to alter your Construct2/Sweep node
changing processInOut to "Long" as shown below.
Nodes/Extensions/contruct2.js LINE 62
var data = this.processInOut("Long", this.multiProcess, null, null);
Will this adversely effect its functionality?
<<Curve node may be used instead of polyline.>>
Yes, polyline was only a stand in for the purpose of clarity.
Also, Points/InterpPts node before curve node gives a more pleasing result at thread ends.
Keep on Noding
Hello James,
Yes it will effect the functionality. The node is able to process also 2 or more profiles and 1 or 2 Rails. It seems that the sweep factory uses some internal autoplacement? to distribute the profile to the rail, if this change is working for you (Just a guess - would need more details). I tried to avoid this . To distribute the profile you can use something like that:
I've chosen this way to make it possible to place also individual profiles to each rail. I don't know if this way is the right one.
Have a nice day
Karsten
Hello Karsten,
Yeah, I had realised that it was not necessary to alter your sweep node;
but rather just use "Long" MODE on Max's original sweep node.
I've restored your node to "Short"
Also, it's not necessary to use getCurveSFrame, if sweep profile is remote from rails.
Please find nod file attached.
Now I need to index perpendicular threads.
Thanks for your help.
Yep! That's right! It's early in the morning here;-)
Hello All,
Weave in both direction and wrapped over curved surface
(nod file attached)
Works with most up-to-date mod which can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8197.7
Keep on Noding
James, you have written an interesting node!
I'll note that it took well over a minute to work on my Windows7 computer.
The result was 15508 kb.
(Reducing warp to 9 and weft to 13 ran faster, but with less detail in the result.)
Hi All MOI NODE-STERS
It would be great if some of the NODE developers could perhaps start a YOUTUBE channel taking beginners through the process of this tool set seems lots of development has gone in its functions expanding but little or no documentation other than forum drilling.
Could be a good new audience.
great to see the development.
Alex
Your point is well taken...so I have replaced weaveWrap.nod in my earlier post
with new version: WARP=13 & WEFT=19, as well as changing profile to hexagon.
This has greatly accelerated drawing to screen.
If fine mesh detail is desired, it is best to STOP the node running, change the inputs
and then press RUN.
You also reminded me that I should have mentioned that the WARP & WEFT input
need to be odd numbers to weave properly.
Thank you
I'm trying to create my own node but having studied existing maths node
still cannot get the input values into the formula I want to perform.(I am a novice )
Attached is my pathetic attempt any advice much appreciated.
Barry
XVarHelix.js
328-347
348-367
368-387
388-407
408-427
428-447
448-467
1848-1859
