314-333
334-353
354-373
374-393
394-413
414-433
434-453
1854-1859
attached is a simplified drawing showing the variable pitch helix and the nod file so you can see it work.
( the full drawing of the Screws is 2g so otherwise I would have posted it)
I have added an entry and exit pieces to show the areas I would like to include in my nod file.
These areas will not have any Bottle rotation.
I haven't any particular requirements for a screw at the moment but with this facility it will be easy to test.
Barry
Helix Only.3dm
VarPitchHelix.nod
Using the math from the .pdf with the _VarPitchHelix script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6697.1
For Barry's .3dm variable pitch helix:
The length of the variable pitch helix is 100 units of length.
The one turn startPitch is 10 units. (The pitch is actually variable over this 1st turn.)
The one turn endPitch is 30 units. (The pitch is actually variable over this 5th turn.)
The number of turns is N = 5.
Pitch1, the initial (instantaneous) pitch at the start, is 7.5 units. (vs 7.499808 calculated with 4 decimals, tangent lead angle)
Pitch2, the variable part, is 12.5 units.
Using tangent calculation, the ending "instantaneous" pitch of the screw is 32.4987 units ~= 32.5 units long.
The left constant pitch screw is of pitch 7.5 units, 2 turns.
The right constant pitch screw is of pitch 30 units, 2 turns, total length 60 units, which is OK, but does not match the ending tangent of the variable pitch screw.
To match up with the ending pitch of the variable pitch screw, it should be of pitch 32.5 units, 2 turns yielding 65 units long.
The x-axis displacement for the variable screw is X = N * (Pitch1 * t + Pitch2 * t * t),
where t ranges from 0 to 1, as the clock tick ranges from 0 degrees to 5 * 360 degrees, if one tick = 1 degree.
So the values used for t are = clock / (5 * 360)
When the center of the bottle reaches the start of the variable pitch screw, the x-axis displacement will need to switch to this equation,
from the motion equations of the constant sections. This range is x = 0 to x = 100.
If x < 0, constant speed equation 1. ( = 720 ticks )
If x>= 0 and x <=100, use variable speed equation. ( = 5 * 360 ticks )
If x> 100, use constant speed equation 2. ( = 720 ticks )
The original litegraph has a Selector logic node...
Hello Brian,
I don't have the time at the Moment, but in my opinion it should be possible to calculate every section of the Transport independent and concate the numarrays or pointarrays by concat2 -> RMB to choose the type.
Have a nice day
Karsten
Thankyou very much Karsten.
My understanding of how the various nodes work is very poor. Some study should help, (after Work:-).
I'm wondering if the logic Compare node would help, and about its inputs and outputs.
Could the Compare node substitute for the nonexistant Selector node?
Concatenate sounds useful, to combine the 3(+) Math nodes, but somehow the 3 speeds need to be switched between.
Didn't someone start a Wiki on Nodes?
Hello Brian,
my idea is to calculate all needed numbers ( Arrays for rotations and e.g. for Translation for the different sectors of the screw) and concate them together. Than pick the pairs of Rotation and Translation by the idxSelect- node. The idx can be controlled by a quartz node.
Only an Idea ...
Have a nice day
Karsten
Thanks Karsten,
I was unaware of idxSelect node, must be a mod node.
I see that the Compare node will feed into a math node.
I'll have to re-install the mod version, and clean up my directories.
I have multiple node versions and files in many various directories, subdirectories, SSD and Harddrive...
I have managed to get a working node file for my problem as follows.
As before there are 3 segments
1) entry constant pitch. 720 degrees ( 2 rotations ) 10 pitch
2) Variable pitch middle. 1800 degrees ( 5 rotations ) 10 start end 30 pitch
3) exit constant pitch. ( 2 rotations ) 30 pitch
I have a slider set max to 5 rotations same as the middle section.
There is a bottle for each section with its own move profile.
The slider or in my case the quartz node controls all 3 segments.
The bottles are positioned as if all 3 segments had 5 rotations so
bottle 1 is placed 5 x 10 pitch away from start of segment 2
bottle 2 at start of segment 2 and bottle 3 at end of segment 2
It's basically a relay race if that makes sense.
In the animation the bottle seams to travel the full length of the screw
but in fact it is each bottle for its own section.
It's not an elegant solution but it allows to animate the movement and
check for clashes using Karsten's Boolean intersect.
Barry
Hello Friends
Another exercise,
I managed to produce an interesting Texture,
applying some transformation to the Classics
Pyllotaxis ....
link:http://www.mediafire.com/file/bn1ewtm9a6c9gan/Pendant.rar
best
al
Hi All,
can someone tell me if this script can be made into a node.
script: /* Hide all edges */ var breps = moi.geometryDatabase.getObjects().getBReps(); for ( var i = 0; i < breps.length; ++i ) { breps.item(i).getEdges().setProperty( 'hidden', true ); }
Also how to add your own node folder and add to the Index as this as changed from the early versions.
Barry
Hi Barry,
For a partial reply, my setup in windows7 is as follows:
At C:\ProgramFiles(x86\MoI3.0\ui,
I have the following:
a. subdirectory customui, (contains Max's customui)
b. subdirectory nodeeditor, (contains Max's latest stock version, 0.93)
(I did make a few minor changes such as Quartz, Different cursor, and lighter background color.)
c. subdirectory nodeeditor.93Mod, (contains Latest Mod version, with more content)
Under customui, to access item b., I have 99 NodeEdit.htm (no - sign), which has as its last line:
command="moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );">NodeEdit</moi:CommandButton>
Also under customui, to access item c., I have 98NodeEdit2.htm (no - sign),
command="moi.ui.createDialog( 'nodeeditor.93Mod/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );">NodeEditMod</moi:CommandButton>
So either version of nodeeditor can be accessed through custom UI.
No comment on hiding edges.
thanks for the reply. My thinking is to add my own node file ie:MyBits which I can add
my experimental nodes to.
The script I posted is one of Michael's but with my novice skills in javascript am not sure
how or if it can be made to work as a node.
Anyway thanks
Barry
I think that that is the purpose of the nodes/extensions subdirectory, a place for "third party" nodes, but I have a lot to learn still:-)
Need to re-read Max's posts when he came out with version .85 (?)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.572
Hello Barry,
find attached a script file with comments as a object for your studies. Copy it to the extensions folder an restart moi and the nodeeditor - that's it.
Have a nice day
Karsten
Barrys.js
Hi Karsten,
thanks for the node it loads ok but doesn't hide the edges ?
I connect the selected object to it but no go.
Barry
Please switch under infos to visible -> no
I tried out the Hide Edges node written by Karsten, and FINALLY got it to work, both with the Motor2 node, and also with Barry's bottle feed screw node,
and my model of a RH screw.
At first the node declined to work, when inserted right after get object.
The Hide Edges node needs to be inserted right before the final Output node.
Also, wire the input of Hide Edges, before connecting the output to the Output node, or a recoverable error results.
"Off" in the Node Info panel means that edges are turned off, or not visible.
Karsten, you have written a very nice node.
Hello Brian,
Sorry for the error - I didn't tested it already. It is only a fast draft that should show, how it is possible, to hide the edges.
Maybe someone can improve it - I haven't the time at the moment.
Have a nice day
Karsten
Probably, if Hide Edges is inserted just after getting the object, other geometry nodes downstream cause edges to be re-displayed?
So put Hide Edges just before Final Output node(s).
On/Off can be changed from the Info panel, while the script is running.
Karsten, the script is superb as is!
Hi fellow Noders,
I am attempting to construct a parametric weave.
Attached are 2 failed attempts:
WeaveProto1 starts with a 3 dimensional point array with variable U & V + 2 in the W dimension, while
WeaveProto2 offsets 2 dimensional array in Z direction and bundles both arrays into a 3 dimensional array.
In both cases it was possible to selectively index weave in the WARP direction. However I was less successful with the WEFT weave (better with WeaveProto2, first row but not repeated)
Also even if the WEFT weave could be successfully indexed, there remains the issue of snipping the threads so that each row in both directions, is distinct.
Any thoughts?
Karsten,
thanks works great and having the ability to switch on or off is a bonus.
Barry
314-333
334-353
354-373
374-393
394-413
414-433
434-453
1854-1859
