Show messages:  1-7  …  248-267  268-287  288-307  308-327  328-347  348-367  368-387  …  1848-1859
23 Feb 2017   [#308] In reply to [#306]
It looks great Christian!
24 Feb 2017   [#309]
Hello Cristian
thanks for your file sharing;
Excuse me, but I thought the whole building
It had been carried out using only
Elephant " feature"
thanks again and have a nice day
best
al
24 Feb 2017   [#310]
Phylloz works with "Classic" Elephant or "Modified" ? ;)
28 Feb 2017   [#311]
Hi Friends
another exercise about building
a mathematical snail
link:http://www.mediafire.com/file/84a9gt81ksrbfe3/CP-Archim.Snail.rar
best
al
7 Mar 2017   [#312]
Hi Friends
Some transformation test and Morph on Surfaces
using isocurves which shows instability in maintaining
the name chosen-
So if you launched the file the result will look different from the one
which you can see in the attached images ,
you have to set the right edges in tool Isocurve -
The second file Morph 3 , and skied with only the result Polygon
because despite many efforts to apply Sub I could not
It closes the program-
Maybe it depends on the power of my computer
Have a nice day to all
al
link:http://www.mediafire.com/file/ln2cit3mi3z1dwy/CP-Mod-Surf-Morph.rar
14 Mar 2017   [#313]
Hi Friends
I want to share with us
this task :
an Helicoidal Staircase -
I hope it can help any of
you, as a start.......
best
al
file ( v.0.93 + Karst/tools)
link:http://www.mediafire.com/file/fsn5p48q33c7cao/CP_Helicoidal_Staircase.rar
16 Mar 2017   [#314]
Inspiration :)
16 Mar 2017   [#315]
Hi Pilou
What show in the video, in a future ,
not too far , I think we can succeed
to do even with Elephant-
The important thing is that Max and Companions
implement a " Cluster Node "
as in Grasshopper , which allows to group
a series of operations , made with traditional nodes
they accept as various inputs (Slider)
those delegates to make the changes.....
for instance......
Scale, n ° pt, etc etc-
The Cluster will have as output the result
of all the manipulations carried out
through inputs into Entrance-
Grasshopper did you implement this system
from long ago
and I must say it works perfectly-
So we hope that Max & Co
create something similar, maybe improving it
We just have to hope-
best
al
4 Apr 2017   [#316]
Hello Friends
I want to share with you, this......https://vimeo.com/66227736
I saw this video,very interesting, about the construction
Scenic for Dance, curated by architect, Calatrava
I rebuilt everything with Moi-Eleph-
I redid the same exercise with GH
aside the fewest number of nodes and the different
handling the result is the same-
I believe that the current level achieved despite
many improvements is remarkable.
Thanks again to Max, and others
are contributing to the improvement
of this fantastic tool-
best
al
File-http://www.mediafire.com/file/5oqw5ok25u6ffrd/Calatrava_Dance.rar
4 Apr 2017   [#317]
Excellent : i believe that you can make the same with LineWeb! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
else you can embeded the video! ;)
Architecture of Dance Santiago Calatrava Grasshopper Animation from qiaoqin on Vimeo.
4 Apr 2017   [#318]
Pardon me Pilou, for replication .......
of course, in normal use could Moi
lineweb used to build the structured wire-
But here , we are in the n the "Parametric World"
the construction thus realized (from a glance at File)
It has many parameters manipulated,
therefore everything can be reconsidered, correct, etc. etc.
And this is the TRUE POWER ...........
On the other hand no one has yet implemented
lineweb Node in Elephant
Have a nice day
al
4 Apr 2017   [#319] In reply to [#318]
Sure it's the power of the parametric world!
It was just a note! ;)
26 Apr 2017   [#320]
Hello Friends
Tired enough, but I succeeded
Low poly-giroid-
Minimal surf, obtained with Subdivide tool
best
al
http://www.mediafire.com/file/64v7y227uphe9nz/Minimal_Surf.rar
26 Apr 2017   [#321] In reply to [#320]
Hello Al,
thanks for sharing. You are shooting in the right direction!
http://news.mit.edu/2017/3-d-graphene-strongest-lightest-materials-0106
http://advances.sciencemag.org/content/3/1/e1601536/tab-pdf
Have a nice day
Karsten
26 Apr 2017   [#322]
28 Apr 2017   [#323] In reply to [#320]
Hi Al,
Your latest Gyroid nod file is brilliant.
However I can not get it to run.
I suspect it is my computer is hanging
because it cannot handle computational load.
I am confident that I have newer nodeeditor mod,
but just to check it is not a missing js file;
could you please upload your nodeeditor folder
zipped to mediafire.
Thank you
28 Apr 2017   [#324]
Yes because that is difficult to know if its the classic or modified Editor! ;)
30 Apr 2017   [#325] In reply to [#323]
Hello James, Hello Pilou,
it's a modified one - this should hopefully work ...
http://moi3d.com/forum/index.php?webtag=MOI&msg=8197.7
Have a nice day
Karsten
30 Apr 2017   [#326]
THX for the efforts!
30 Apr 2017   [#327]
Something to play ...
test.nod
