Show messages:  1-7  …  128-147  148-167  168-187  188-207  208-227  228-247  248-267  …  1848-1859
22 Nov 2016   [#188]
Hello Karsten Friends,
another test of new mpatharray-Node
there are several inactive output ,
activate them to see the different behaviors
shown in the attached picture...
<Karsten>
I think the changes to the existing Loft
they can be made at the entrance of the data in the
Node-
Just specify how to order
input ....
CP-mPath-Array.nod
22 Nov 2016   [#189] In reply to [#188]
Hello Karsten and Al,
>>changes to ... Loft...they can be made at the entrance of the data in the Node-Just specify how to order input<<
"Sweep" may be an easier node to update to multiple profile inputs , because pick order is irrelevant to operation.
"Sweep" can achieve the same result as "Loft" in many cases, and avoids the need of "BundleObj" functionality.
That said, an Extended "Bundle" node would be brilliant, especially if that was the fix to existing "Loft" issue.
.>>A new node or RMB option<<
Definitely RMB option. Your Concat2 node is so powerful due to it's versatility.
I look forward to seeing what you come up with!
-James
PS Image below: PanelShell with spikes of differential length and orientation.
22 Nov 2016   [#190] In reply to [#189]
Hello Al, Hello James,
I've tested Al's CP-mPathArray - very cool, but my 5 year lenovo G575, that I use for programming, is a little bit slow for such things. Anyway - I've tried to include the RMB option into the mLoft, but I have some problems with the locking mechanism of the input slots - I have to take a deeper look in JS and Max code. So there is a little bug in the new node, that I have attached (in "normal" mode it is possible to remove the target slot ..). So it's a draft, that I have to improve. When I understand the code, I will fix it and post a new one. And we have to think about the compatibility of your posted examples, it is possible that some of them have to be reworked in the future.
It would be a pity, if they wouldn't run in newer versions.
Have a nice day
Karsten
221116.nod
23 Nov 2016   [#191] In reply to [#190]
Hello Karsten,
The new mLoft2 node is brilliant.
It does exactly what I asked for.
Despite what your wife may think,
you are indeed, a man amongst men.
Thank you
23 Nov 2016   [#192]
Hi Karsten
I saw the new node and advances
occurred ....
You are truly priceless for the effort they monsters.
Unfortunately these days there it will be able to analyze
and understand the improvements occurred
patience.....
I hope to do next week
Have a nice day
al
23 Nov 2016   [#193] In reply to [#190]
Hello Karsten,
>>mLoft2....So it's a draft, that I have to improve<<
I was just wondering, when you return to revise coding of mLoft2
if it would be possible to include polyloft capability
(i.e. selectable separate facets).
Or if easier to create a new mPolyLoft.
The below image may clarify my request.
I want to be able to address individual quads.
I don't want to come across as someone who is never satisfied.
I hope I have already expressed my gratitude for all your early xmas gifts.
I couldn't be happier, with toys I have already!
-James
23 Nov 2016   [#194] In reply to [#193]
Hello James,
I will think about it, but at the moment I have also to play and experiment - here is another aspect:-)
https://youtu.be/q1vJo4QIWvI
Have a nice day
Karsten
23 Nov 2016   [#195] In reply to [#194]
Hi Karsten,
Camera node looks really cool!
RE: PolyLoft capabilities: >>I will think about it<<
Brilliant!
-James
PS I also have to play and experiment
23 Nov 2016   [#196]
Where is your survey list of new nodes ?
That can help Max...and us! ;)
24 Nov 2016   [#197]
Hi Karsteen, Burrman, AL, James and all the other smart guys of Project Elephant,
I post here my reply to this post of "wastzzz" where he said (http://moi3d.com/forum/index.php?webtag=MOI&msg=8192.1) :
"....I don't understand anything, where is the last version, what is nodebundles, there is no appropriate thread or instruction.
This forum organization is a pain. My head hurts. No offense"
Well, I totally agree with "wastzzz".
Although I have already played a lot with Project Elephant, now I'm really doing confusion...
Karsteen, Burrman, AL, James and all the other smart guys of Project Elephant, could you please, if you want,
follow the suggestion that I gave you some days ago ?
That is :
I think that would be a good thing if we put at the end of all our posts with nod files this annotation :
"These nod files requires <node editor version name.zip> downloadable at <url>"
For example : "These nod files requires "nodeeditor_0_85_mod6.zip" downloadable at http://take.ms/RfzWH"
This little extra annotation to our posts will greatly help us to understand and test all of your excellent experiments.
Best,
24 Nov 2016   [#198]
Suggestion: maybe not like all this animation but the concept!
Automatic folding paper surface with Valley/Montain given
24 Nov 2016   [#199] In reply to [#198]
Hi Pilou
the video shows the performance achievable
with Kangaroo Plug-in ,created by the genius of Daniel Piker for GH/Rhino ...
It is a simulator of movements, mass ,gravity ,acceleration,
etc etc applied mostly to the Mesh ....really amazing ..
Perhaps using mathematical data only (Algebric and Trigonometric)
It fails to do something like ...
personally I see it very difficult
best
al
24 Nov 2016   [#200]
Hello,
I want to post my last snapshot:
For those are interested in - extract the file in in a subfolder and copy the folder nodeeditor.v.0.85 to e.g C:\Programs(x86)\Moi\ui\. After that, start Moi and go to Options and Shortcut keys. Click the Add button. Enter a key e.g. F8 or Alt+N. Under command place:
moi.ui.createDialog( 'nodeeditor.v.0.85/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
Now press close - and enter your shortcut key. - Hopefully it works. In the attached file nodes_V0.85_mod8.xls is a short overview for the additional nodes.
To start working with the nodeeditor press the right mouse button. Hold down and chose a node. A double click on a node opens the info panel on the right side - same result as pressing the info button on the right upper side and click to the node. Most of the nodes have inputs and outputs. At the moment there are three datatypes:
numarrays -> for numbers and arrays of them
pointarray -> for points and sequences of points
objectlists -> geometrical objects like points, lines, curves, bodys ...
Boolean -> at the moment unused
The node is like a blackbox, which takes inputs of the mentioned datatypes and processes them to an output. Outputs can be connected to the input of another node. Outputs of type numarray and pointarray can be connected to multiple node inputs. Objectlists can only connected one by one. If you want to connect to multiple nodes, you can use a clone node for that. To connect outputs to inputs, press the left mouse button on the output and drag the cursor to the input you want to connect. Release the mouse button over the input and Output is wired to the input. The color of the wire depends on the data type which will "transported". Under the basic Menu item (RMB) is a Output node that brings the data to Moi. To start the processing, press the start button. The Apply button pushes the data/geometry permanently to Moi.
I'm not a native speaker, so maybe can take the infos and bring them back in a improved version.
Have a nice day/afternoon/night to all
Karsten
24 Nov 2016   [#201] In reply to [#200]
Remarquable!
I will translate all that the next week in French! (xls file)
(and the nodes itself inside the node editor inside the Moi program!
Seems you must say to save somewhere the actual Elephant Node editor! ;)
24 Nov 2016   [#202] In reply to [#200]
Hi Karsten and thank you very much for your post and your new "unofficial" version of Project Elephant!
I have seen that the archive contains also all my nodes and all the other nodes written so far.
That's a very good thing because it's exactly what I meant when I suggested to start to be more clear and plain
when we present new nodes to the community.
This is a good starting point for next unofficial versions of Project Elephant.
I think that this way will greatly help anyone to play with the Node Editor :
an updated zip file containing the new version and a .xls file for a basic documentation.
In the last few days, thanks to some sporadic spare time, I'm testing and coding a new node dedicated to PointArray elaboration,
and I think that soon I should be able to publish a new "unofficial" version of Project Elephant containing this new node.
Best,
24 Nov 2016   [#203] In reply to [#200]
Hello Karsten,
One small request: Planar node
It need only have a single input & single output
with no options. I can test for you & upload new mod files
Have a great weekend
-James
something like this:
// Planar
function Planar()
this.addInput("In","objectlist");
Planar.title = "Planar";
Planar.desc = "Planar";
Planar.prototype.onExecute = function()
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
var output = moi.geometryDatabase.createObjectList();
if ( inObj.length> 1 ) output = factory ('planarsrf', inObj);
LiteGraph.registerNodeType("Construct2/Planar", Planar);
25 Nov 2016   [#204]
Hello Karsten and Friends
I can not install this latest version
I attach some pictures ...
I think I did all right
in your opinion what's the problem
any help is extremely welcome
thank you
best
al
25 Nov 2016   [#205] In reply to [#203]
Hello James,
good idea. It looks like the planarsrf factory make a multiprocess by itself, but it dosen't work for non planar curves. We have also look to the UV configuration - depending on what someone want to do with it, we also need network or a two rail sweep with 2 profiles.
Have a nice day
25 Nov 2016   [#206] In reply to [#205]
Hello Karsten
Can you please have a look at the code and tell me what is missing or wrong.
I would really appreciate it
-James
25 Nov 2016   [#207] In reply to [#204]
Hello Al,
My italian is very limited, but it seems that the folders are empty. Something went wrong with the copy or the extraction of the files. I downloades and checked the zip file and here it seems to be ok.
Please check and give a feedback.
Have a nice day
Karsten
