1733-1752
1753-1772
1773-1792
1793-1812
1813-1832
1833-1852
1853-1859
The other Readme file in elephant-0.1-alpha, refers to a third patch file,
git am --ignore-whitespace elephant.patch
It is confusing.
Will try again tonight...
The second readme also has Win instructions...
Hi, I think following the video should be best, I'm still working on the README
Fantastic project nkallen, thank you for your hard work!
(I edited my prior posts a bit.)
By following nkallen's video I was able to install the node graph. The program seems to work.
Also I had to put in my email address, and my username.
Unfortunately I did not understand about trial/, so do not have a backup of MoI, just the altered "master". Edit incorrect statement.
I guess I'll have to reinstall MoI4...
MoI4 successfully reinstalled.
Edit, so trial\ refers to MoI 4.0 beta, not to the git "backup".
Does the result of this "new" NodeGraph is just modified Folders / FIles ?
So will be fine if we can just copy past these new Folder / Files
because this "Git" is very painful! Not yet success! Too much syntax errors, spaces, / , \ etc... a nightmare!
You lost me at video 3.2 minutes! :)
The purpose of git is to keep copies of documents and manage different versions of them.
In the video when we do “git commit -m ‘Initial commit’” we make a backup of your moi folder before any changes are made. You can always go back to your initial commit no matter how many changes you make afterwards.
Yep but for old eyes like me it more easy to make something like this :)
for any Folders / Files who are changed by the nodegraph
NodeEditor_oldMax (so will not called by the program)
Nodegraph will called by the prog
and when i have finished I just rename
NodeEditor (so will called by the program
Nodegraph_old_nkallen (so will not called by the program)
that takes 3 seconds and not headaches! and no need to use Git :)
Of course if this sort structure is accepted by your "nodegraph" Folders / Files modified ...
and if you can provide the Folders/ Files modified!
I see that this is more painful than anticipated...
In the software industry / in open source/ among hobbyists, we almost always distribute source code using a version control system like git. It allows us to safely keep backups of files, and also easily upgrade to new versions. I would strongly encourage the moi community to consider using Github or something similar rather than passing around .zip files without any version history. There is a learning curve but it is a life-saver - I swear. You can ALSO produce easy-to-install zip archives, but code is happiest (and safest) when its in version control first.
Around 3.20 in the video, what I type is just to go to different folders on your hard drive. You can type:
cd /c
cd "Program Files"
cd "MoI 4.0 trial"
(Presumably you're not using the trial but I don't know the name of the non-trial folder on windows)
I have to ask Michael if I can distribute my changes as a .zip. For example, does the license permit me to distribute a modified version of Fillet.js? So far I'm using a .patch file which allows me to share my changes without ever distributing Moi3d's original source code.
I understand your point of view...so wait and see :)
during the video we have on begin Git line "1s" or "ls"... or ...other what is it exactly?
ps No trial is that in no Roaming folder
C:\Program Files\MoI 4.0
I type "ls" a lot which is lowercase LS
It means "list the files in the current directory".
I'm looking around and it seems like there's a program called TortoiseGit which is popular on windows and it looks easy to use. No typing commands. I'll play around with it and investigate. In the meantime, I've asked Michael what the license permits.
I'll be around in discord to help with step-by-step instructions.
ok! And one mystery resolved! :)
Michael is ok with my distributing the source code via .zip file. (Thanks Michael!!)
I recognize this is easier than git. (But still -- git is awesome it's well worth learning even if you're not a programmer!)
https://github.com/nkallen/elephant/releases/tag/v0.1-alpha
You will need to download elephant.zip commands.zip and MainWindowLayout.xml
1. Unzip elephant.zip into AppData.
2. Unzip commands.zip into your main MoI executable folder (replacing the old commands/ folder BUT MAKE A BACKUP)
3. Replace ui/MainWindowLayout.xml with mine. BUT MAKE A BACKUP
This is I hope easier!
Hi Nkallen.
Thank you for your plugin, very interesting!
When cloning nodes from the widgets group through the context menu of the node, the program returns an error, the application screen shows which nodes cause the error.
Still, Git is primarily focused on programming, and it's easier for most people to use files in a folder.
Git resists ...
so take the install by ZIP! :)
BOTTOM PAGE!!!
https://moiscript.weebly.com/install-elephant.html
Everything is simple there, with Git there is a desire to understand:)
This bug should be fixed. If you're using git, you can execute "git pull origin master" in the AppData/elephant directory. Otherwise, I'll bundle a new zip in a few days
I recommend everyone using this to add the following keybindings:
script:moi.ui.getUIPanel("moi://appdata/elephant/index.html").graph.showPreviousHistoryItem();
script:moi.ui.getUIPanel("moi://appdata/elephant/index.html").graph.showNextHistoryItem();
and bind them UpArrow and DownArrow
Hi Nkallen.
When using the Extrude command, the program returns an error.
1.3dm
I was never able to install the patches through Git.
I used the usual file replacement. It's sad.
1733-1752
1753-1772
1773-1792
1793-1812
1813-1832
1833-1852
1853-1859
