1668-1687
1688-1707
1708-1727
1728-1747
1748-1767
1768-1787
1788-1807
1848-1859
So there is only one "loop", but the loop can be used for multiple cycles. (?)
Nesting of loops?
- Brian 3+ years
Hi, James.
Example of using the "Loop Start" and "Loop End" nodes.
animation.mp4
animation.nod
Message 7777.1730 was deleted
Hi WN,
Welcome to the forum.
Wayne
https://www.instagram.com/waynejhill/
Hi Wayne.
Thanks!
Wayne,
Yes exactly, but as I said
"only as a first step in exploring recursive patterns"
I have updated my earlier post with link to your posted image.
Brian,
Yes exactly!
"Nesting of loops".
WN,
Welcome & thanks for the attachments.
They are not what I'm looking for, but I hope these are the first of many posts
of your node experiments -
playing with nodes.
Thanks to all of you,
Have a great weekend,
Hello Karsten,
This may not help with my particular requirements, but as a first step in that direction,
if "LoopEnd" node was inline with the "Output" node rather than branched off prior
with "clone" node, then each iteration could be recorded and if the option selected, outputted.
Does that make sense?
Hello James,
yep! Maybe a solution for the problem not to loop all data again. The loop stuff is only a q'n'd' draft and it took a year that someone was asking for. So I've never thought about it in the past again. I had to look twice to understand what I have done here;-)
Maybe we need a second array to store and push collected data? I'm not sure how we can realize it.
Any idea is wellcome!
A nice day to all
Karsten
NE -> Gordians_Knot_Puzzle.
Hello James,
I'm trying to find a solution at the moment for the loop stuff - difficult, because no time and written no code since one year. By the way - Could someone explain me nested loops??? Loops in loops?
Not finished, but a first step for an experiment. Only one loop at the moment (think about a solution), but a cumulated output.
Only for experiments!
A nice day to all
Karsten
p.s.: @WN -it seems you have fun!
basicFunctions.js
loop.js
loopTest.nod
Karsten,
Thank you for getting back to me.
The new loopEnd node looks promising.
It was clever to use splitPt - ptExt to strip out the rotational data from the point instances.
I repurposed your wiring to do a "drunken walk" (a staple introductory exercise in computer graphics).
A video can be found here:
https://www.instagram.com/p/CDi5Uw1J_5s/
nod file attached
Nested Loops
Nested loops are loops within loops...this video gives a clear description:
https://www.youtube.com/watch?v=1c1_TMdf8b8
I'm not sure how this may work with nodes. I'll see if I can build something.
Thanks again,
https://www.instagram.com/nodeology/Attachments:
drunkenWalk.nod
Hello James,
loop in a loop, not really a surprise - but I didn't know that it is called nested loops:-)
The Problem here:
- I have to use global variables that LoopEnd and LoopStart can exchange informations - at the Moment only one with a fixed Name is present
- I'm not sure what I should use for multiple ones (Maps, sets, or named ones)
- I'm not sure how the NE reacts to multiple timers? Is it neccesary?
Some experiments have to be done the next time.
And thank you for the example - I will try it in the evening!
Thank you
and
have a nice day
Karsten
Fun start fun!
A cool one is this
Karsten,
"not sure how the NE reacts to multiple timers?"
There is no issue with multiple timers
"Is it neccesary?"
In most cases the same timer could be utilised for multiple loops.
There would need to be a triggering of second loop after first has met end condition.
Perhaps logic/compare a=0 (end condition for earlier loop) initiates new loopStart (trigger).
"global variables"
There does need to be a means of having unique variables for each loop.
Ideally, NE would recognise multiple loopStart/loopEnd pairs and attribute unique designators. Alternatively users could manually name each node pair, which would serve as the variable name. This approach though could be fraught with difficulties in terms of UX.
Would it be possible to have direct wire link between pairs, so loopStart get a randomly generated numerical designator on placement on the canvas, & then it is sent to LoopEnd via green wire?
Another alternative would be to introduce a txt string data type wire. It could also be used to externalise text inputting into “text” node. It may well have over uses.
Please let me know
Hello James,
wireing is my favorite to exchange the variable names by UIDs. I don't think that we need an additional text type for that. It would also need a lot of work in the base system. Furthermore I'm thinking about time stamps as an internal critera to trigger/reset loops.
How to store and manage the loop data isn't clear for me at the moment also.
One loop is simple, multiple loops not.
Have a nice day
Karsten
I was puzzling over the German "mit -KGV(n,m) * PI <= t <= KGV(n,m) * PI".
So, in English math the German KGV(n,m) is the Least Common Multiple of m and n.
LCM(n,m) is lcm(n,m) in Javascript. (n and m are integers in this example.)
German ggt(n,m) is the Greatest (Largest) Common Divisor, (Javascript gcd(n,m).
https://de.wikipedia.org/wiki/Kleinstes_gemeinsames_Vielfaches
(Translatable to English.)
(I do not speak German.)
In Max's latest version of nodeeditor, unused node dot circles are NOT colored.
I prefer them all to be colored, pink gold and teal.
Does anyone else have this behavior?
I've re-installed different versions of nodeeditor several times...
Brian,
AFAIK the Current NODE EDITOR folder has this behaviour.
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
1668-1687
1688-1707
1708-1727
1728-1747
1748-1767
1768-1787
1788-1807
1848-1859
