1636-1655
1656-1675
1676-1695
1696-1715
1716-1735
1736-1755
1756-1775
1856-1859
Hi All,
Attached is a node circuit containing a macro for generating geodesic spheres
of variable resolution (0 = icosohedron up to 4 subdivisions*) with all vertices at equal distance from origin. Essentially, it subdivides an icosohedron, then spherizes the result.
* If you want to reduce or increase limit on allowable subdivisions, you can go into macro and change MAX.subDivs node shown in RED. Beware that a number higher than 4 however will likely hang your computer.
It's false simplicity! :)
You must click on the middle node for see the entiere Macro! ;)
(no place for put it here! :D
Well yes, I only posted the .nod file because I thought the macro within may be of use to others.
It is easy enough to cut & paste the nodes out of the macro and on to the canvas if you so desire.
I did not think that the result was worth posting, only the macro, but here is an image posted to instagram that uses similar node wiring to that found in the macro, and the subsequent images shows the node circuit for generating geometry.
Seems there is a little glitch somewhere in the geodsic...
As soon as the up Knob is decreased/ increased there is new a sphere who is drawn inside
and that calculate for a moment...etc ...and that blocks all things! ;)
And i believe it's more prudent to put Curseurs because Knobs are very sensible to the direction of rotation
with the mouse so increase can be not wished and too late for take back in the case above!
It is not really a glitch, it is just an artefact of the multiple steps in processing.
The
"new sphere who is drawn inside" is not spherical, but a Catmull–Clark smoothed subdivided icosohedron which persists on the canvas only while the vertices are spherized.
"that calculate for a moment...etc ...and that blocks all things"
To limit the computation time I have restricted the number of subdivisions to 4 despite the numerical "subDivs" input.
Being locked out while calculating occurs generally for tasks that draw heavily on computational resources, and although it can be frustrating it is something that we must live with.
"i believe it's more prudent to put Curseurs because Knobs are very sensible to the direction of rotation"
I've only used a knob, to illustrate that macro will accept a range of numerical inputs (0-4). My purpose of posting the file was solely to distribute the macro within.
Many thanks for the infos and bravo for the creativity!
A simple fractal for the Node Editor.
Wayne
the ".js" must be \Moi\nodeeditor\nodes\extensions\
Cool !
+ Fat lines by Max Smirnov & Extrude!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
Here's a node circuit for the generation of a interlinked woven screen.
Be warned that it may take a minute or so for geometry to generate.
Requires most current extension nodes, found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
TripleHexWeave.nod
It's unbelieveble what interesting geometry you can create via nodes.
Excellent!
Mik
Hi :)
New NE core build:
http://moi.maxsm.net/files/nodeeditor/nodeeditor.v.1.1.2020.07.14.zip
Minor interface updates, bugfixes etc.
Welcome back Max,
So good to hear from you.
I've downloaded... can't wait to see the changes
Thank you for your continued support of NE
Evergreen! :)
v.1.1 (14-07-2020)
Changes since v.1.0.rc3 version (03-10-2018):
index.html
added:
- utf-8 support
color.js
added:
- io_text_highlight and io_highlight variables
editor.js
fixed:
- open file dialog error
init.js
added command line parameters: file, step, run, close
examples:
open C:\NE\test.nod file
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html?file=C:\\NE\\test.nod', 'resizeable,defaultWidth:1,defaultHeight:1', moi.ui.mainWindow )
open C:\NE\test.nod file and run it
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html?file=C:\\NE\\test.nod&run=1', 'resizeable,defaultWidth:1,defaultHeight:1', moi.ui.mainWindow )
open C:\NE\test.nod file, run it, close window
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html?file=C:\\NE\\test.nod&close=1', 'resizeable,defaultWidth:1,defaultHeight:1', moi.ui.mainWindow )
lang.js
added:
- minor inprovements
main.js
fixed:
- open macro dialog error
added:
- more node colors
- macro inputs/outputs reorder (hold alt and drag input/output dot)
- select -> same type/color menu
- minor improvements
added ext.nodelist.js
nodes/interface.js
added:
- remapper widget
Max,
Thank you for the info.
I have a few suggestion that may be worthy of your consideration.
1) I think it would be operationally consistent with the menu logic for "Output" to be included in the first tier, just as "Input" "Output" & "Close" are in menu within a macro. See image below
This is a small thing; but I do think "output" is distinct from other nodes & deserving of first tier status.
2) I don't believe "Point" node is fittingly part of the "Basic" grouping, as it is a geometry node. It belongs IMHO within "Points" menu. To removed the inevitable confusion, I think, "points" would more appropriately be renamed as "pointArray".
3) Wayne made a minor but significant change to your curve nodes: "Rectangle", "Circle", "Star" & "Polygon" with the addition of a surface output option. I have attached below.
Although generally connecting to "construct2/Planar" node satisfied the requirement of generating surface shapes, it fails in some instances (with complex patterns), & in these cases, incorporating surfacing within the node has been a real improvement.
Please have a think about these suggestions and let me know.
Thanks again for your support,
https://www.instagram.com/nodeology/Attachments:
shapes.zip
Hi James
1) OK. Done.
2) You're right. I've moved Point node to Points.js and renamed Points to PointArray. Also I updated compatibility.js file. Old projects should work fine.
3)
Could you send me an example?
I'm new to Node Editor.
Just curious about the arrangement of items in the menus.
For instance why is there a "Points" item and a "Points2" item but they are not together, one right after the other?
For that matter why are there two menu items related to points as opposed to just one?
Not a big deal at all but was just wondering how things came to be the way they are.
Frederick
P.S. I do try to keep my OC nature under control.
If you go there you will see that Points is "Native Nodes" an Points 2 is "Extensions Nodes" ! ;)
That seems to be a matter of how the underlying code is structured.
From a user interface point of view that is really of no interest.
Frederick
Max,
Thank you for implementing those changes.
"3)....Could you send me an example?"
Regarding the inclusion of a "Srf" output on shape nodes ("Circle", "Rectangle", "Polygon" & "Star"),
the following shows the situation when this need first arose.
From Top down:
1) connecting directly to "circle" node gives the expected result in arrangement of circles & their colouring,
however the desired effect, is lost because the circles are outline only.
2) now connecting the "Construct2/Planar" fails to achieve the desired result because the order is lost.
3) attempting to go via "CloneToPts" does not work at all.
4) using Wayne's "Curves2/Circle2" node "Srf" output work perfectly!
I have since found that I use Wayne's shape nodes all the time. For example "Curve2/Rectangle2" has for me, made Karsten's "SubD/selCenterPane" obsolete. But perhaps the main application is with complex variegated screen images with hundreds of shape elements, where connecting to "Construct2/Planar" node after pattern articulation, will hang the computer for a long time while it calculates all the trimmed surfaces.
It seems to me a small change that would produce no backward compatibility issues & yet is very useful.
Is your resistance to this change because it somewhat invalidates these nodes from being grouped within "curves" menu? I don't see it as a serious contravention of UI logic, but if so perhaps there could be a "Shapes" menu.
I am happy to continue using wayne's versions, but I do think there needs to be a rationalisation of node hierarchies.
Thanks again for you ongoing stewardship of NE
https://www.instagram.com/nodeology/Image Attachments:
1636-1655
1656-1675
1676-1695
1696-1715
1716-1735
1736-1755
1756-1775
1856-1859
