Show messages:  1-13  …  1594-1613  1614-1633  1634-1653  1654-1673  1674-1693  1694-1713  1714-1733  …  1854-1859
21 Jan 2020   [#1654]
Sorry what should do Corner 's parameter in the Node Rectangle of the Voronoï example above ?
Seems make nothing...
In the Node Voronoï itself works fine but in rectangle... ???
Message 7777.1655 was deleted
21 Jan 2020   [#1656] In reply to [#1655]
No problem i will be sure i don't miss something! :)
21 Jan 2020   [#1657] In reply to [#1655]
Pilou/James,
In Max's original script, the value of the voronoi corners range from 0 to 100.
Wayne
21 Jan 2020   [#1658] In reply to [#1657]
Good to know!
Message 7777.1659 was deleted
20 Feb 2020   [#1660]
Hi All,
Here is a little tip for wire management when working on complex node circuits.
2 macros with inputs connected directly with outputs can be used to channel multiple wires converging into a conduit and diverging at the other end. See below
Obviously, the example above would not need measures to simplify the wiring, but some circuits can become overwhelming, especially if some time has elapsed since working on them.
Have a great weekend
22 Feb 2020   [#1661]
Here is a Macro which combines four Extract nodes.
The Macro may be placed in the nodeeditor Macros folder, for easy Canvas right click selection.
Do not Load the Macro to the screen.
ps, Three+ Clone nodes in a Macro create a Clone4 Macro, (or more), so no need for the Clone4 node.
Extract_XY.nod
29 Feb 2020   [#1662]
I have been trying to understand the multiProcess command in the Node API.
Max has a detailed explanation of the process in this post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.395
When should it be used and what circumstances?
What could be other uses for the multiProcess?
Wayne
Discord server:
https://discord.gg/zNTasYd
29 Feb 2020   [#1663] In reply to [#1662]
When dealing with multiple entities?
I will be outputting a pointarray with many circle centers, and numarray with corresponding radii, to one circle (or sphere) node, to display a Doyle spiral.
11 Mar 2020   [#1664]
It's been a while, so here's a post using Wayne's recent node contribution: Objects2/PerlinNoise node to generate a field of wave forms
(wave_Field.nod attached)
15 Mar 2020   [#1665] In reply to [#1664]
James,
Your node design is great. Made a sample on my CNC router.
Wayne
15 Mar 2020   [#1666] In reply to [#1665]
Wayne,
Looks Brilliant!
I was planning to use the design 3dCNC routered into birch ply as doors to a cabinet (sideboard).
I will take this image along to machine shop, as a proof of concept.
Can I post your image on Instagram with link to your instagram page
and a caption stating something to effect of "CNC routing by Wayne Hill"?
15 Mar 2020   [#1667] In reply to [#1666]
James,
Bonitum.com has some examples. And yes, there was a plywood version going on the machine soon. Saw a desk out there somewhere with mirrored 3d door designs that is great.
Yes, you can reference my Instagram page. I have other images and a short video of it being made on my Instagram page.
Thank you,
Wayne
28 Mar 2020   [#1668]
There seems to be a BUG with Vector in nodeeditor in MoI 4 beta.
After running the attached VectorExamples.nod file in nodeeditor, and clicking on Apply, and clicking on Stop,
the three vectors Cannot be erased from MoI4 screen, even if nodeeditor window is closed.
Clicking Run again, and toggling Clear on an Output node then seems to show 1 instead of 0, and vice versa.
(A test circle node seemed to work fine.)
VectorExamples.zip
29 Mar 2020   [#1669] In reply to [#1668]
Could be that those objects have their hit testing flag turned off. See here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1595
The fix would be at some step .setHitTest(true) needs to be called on those objects.
29 Mar 2020   [#1670] In reply to [#1669]
Thank you Michael.
Rotate, Move or Copy create new copies of the 3 vectors in another area, which are delete-able,
but the original 3 vectors remain, and still cannot be deleted.
It seems like a flag for "keep original objects" is set.
I'll do some more experimenting.
Hitting Stop, then Apply, doubles the number of Vectors. The extra set CAN be deleted, but not the original set.
Running the .nod file, then hitting Apply, without hitting stop, then closing nodeeditor, just makes one set of vectors, still not delete-able.
I want to get nodeeditor working (again) in MoI3 and try the vectors there.
VecBy2Pts does the same thing, so probably vector.js is doing or not doing something it should...(?)
Using your Set Hit Test true shortcut key script does not seem to do anything.
29 Mar 2020   [#1671] In reply to [#1670]
The results are the same for nodeeditor in MoI3.
29 Mar 2020   [#1672] In reply to [#1670]
Hi Brian, what about if you run this, does it have any effect on those objecst? :
moi.geometryDatabase.getObjects().unlockSelection();
29 Mar 2020   [#1673] In reply to [#1672]
The unlockSelection();
script appears to have no effect.
There is a difference in selectability between MoI3 and MoI4beta.
After running the vectorExample nod file, the arrow cones are NOT mouse click selectable in MoI3, but are mouse box drag selectable. In
MoI4beta, the arrow cones ARE mouse click selectable, and mouse drag box selectable also.
In MoI4beta, there is another strange effect.
Running the shortcut key script on a selected arrow cone:
script:/*!Select edges v1.2 */ var gd = moi.geometryDatabase; function sl(o) { for ( var i = 0; i < o.length; ++i ) { o.Item(i).selected = 0; var e=o.Item(i).getEdges(); for ( var j = 0; j < e.length; ++j ) e.Item(j).selected = !e.Item(j).selected;}} gd.selectLoop(); var so = gd.getSelectedObjects(); var e = so.getEdges(); sl(so.getFaces()); sl(so.getSolids()); so.getBReps().setProperty('selected',0); e.setProperty('selected',1);
does NOT show the two arrow cone edges, UNLESS the mouse is hovering over the arrow cone, and then the mouse pointer is moved. (In MoI3, just moving the hovering mouse does NOT get the edges to show, but a mouse drag does get the edges to show.)
Creating a new cone with the MoI cone command and running the Select edges shortcut key results in the two cone edges immediately showing up on the screen.
If the mouse pointer is not on the selected arrow cone, and Select edges shortcut key is run, the two edges do not show up until left or right drag is done elsewhere on the screen, or if the mousewheel zoom is done.
Another strange effect is that if the arrow cone, and the new cone are BOTH selected, and the Select edges shortcut key is pressed, both cones immediately show the edges.
(A polygon with planar can also be used instead of the new regular MoI cone.)
Hopefully someone else can reproduce this effect?
I thought that this problem might be helpful?
I imagine that vector.js is doing something wrong, or incompletely, and it is not a MoI3 or MoI4 bug?
ps Line 23 of vector.js has the code: dV.item(i).hidden = true;
Maybe the handling or cleanup of bVec() is incorrect?
