1589-1608
1609-1628
1629-1648
1649-1668
1669-1688
1689-1708
1709-1728
1849-1859
Mik,
Thank you for your kind words, but I'm but a disciple...the true masters are the node creators.
In this regard, my contributions have been very modest. Max and Karsten have been very quiet of late; but a new champion has picked up the baton: Wayne.
Here's a exercise done with Wayne's latest contribution: "voronoi" node, as well as an illustration using "voronoi" in combination with his earlier contribution: "ImgSampler" node.
Very cool New Voronoi's Node! (and thx to Wayne for all ready made for the Repository! )
The green optic effect disapears at big size! :) Statue of Liberty?
Hi James.
@You : "...but I'm but a disciple...the true masters are the node creators..."
No. I disagree. Thinking abut the current stage of N.E. and Moi I think that the most exciting and awesome works are that made by you and the others great Noders :)
I think that what you're doing is AWESOME.
The student has become the master :)
Hyper cool!
All the guys, you are able to work with NE at such a high and creative level, have my sincere respect!
NE creators have my respect as well of course, I admire their work.
Mik
Sorry what should do Corner 's parameter in the Node Rectangle of the Voronoï example above ?
Seems make nothing...
In the Node Voronoï itself works fine but in rectangle... ???
Message 7777.1655 was deleted
No problem i will be sure i don't miss something! :)
Pilou/James,
In Max's original script, the value of the voronoi corners range from 0 to 100.
Wayne
Good to know!
Message 7777.1659 was deleted
Hi All,
Here is a little tip for wire management when working on complex node circuits.
2 macros with inputs connected directly with outputs can be used to channel multiple wires converging into a conduit and diverging at the other end. See below
Obviously, the example above would not need measures to simplify the wiring, but some circuits can become overwhelming, especially if some time has elapsed since working on them.
Have a great weekend
https://www.instagram.com/nodeology/Image Attachments:
Here is a Macro which combines four Extract nodes.
The Macro may be placed in the nodeeditor Macros folder, for easy Canvas right click selection.
Do not Load the Macro to the screen.
ps, Three+ Clone nodes in a Macro create a Clone4 Macro, (or more), so no need for the Clone4 node.
Extract_XY.nod
I have been trying to understand the multiProcess command in the Node API.
Max has a detailed explanation of the process in this post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.395
When should it be used and what circumstances?
What could be other uses for the multiProcess?
Wayne
Discord server:
https://discord.gg/zNTasYd
When dealing with multiple entities?
I will be outputting a pointarray with many circle centers, and numarray with corresponding radii, to one circle (or sphere) node, to display a Doyle spiral.
It's been a while, so here's a post using Wayne's recent node contribution: Objects2/PerlinNoise node to generate a field of wave forms
(wave_Field.nod attached)
James,
Your node design is great. Made a sample on my CNC router.
Wayne
Wayne,
Looks Brilliant!
I was planning to use the design 3dCNC routered into birch ply as doors to a cabinet (sideboard).
I will take this image along to machine shop, as a proof of concept.
Can I post your image on Instagram with link to your instagram page
and a caption stating something to effect of "CNC routing by Wayne Hill"?
James,
Bonitum.com has some examples. And yes, there was a plywood version going on the machine soon. Saw a desk out there somewhere with mirrored 3d door designs that is great.
Yes, you can reference my Instagram page. I have other images and a short video of it being made on my Instagram page.
Thank you,
Wayne
There seems to be a BUG with Vector in nodeeditor in MoI 4 beta.
After running the attached VectorExamples.nod file in nodeeditor, and clicking on Apply, and clicking on Stop,
the three vectors Cannot be erased from MoI4 screen, even if nodeeditor window is closed.
Clicking Run again, and toggling Clear on an Output node then seems to show 1 instead of 0, and vice versa.
(A test circle node seemed to work fine.)
VectorExamples.zip
1589-1608
1609-1628
1629-1648
1649-1668
1669-1688
1689-1708
1709-1728
1849-1859
