Show messages:  1-4  …  1585-1604  1605-1624  1625-1644  1645-1664  1665-1684  1685-1704  1705-1724  …  1845-1859
12 Jan 2020   [#1645]
A variation on Max's dot-screen portrait of Che: http://moi3d.com/forum/index.php?webtag=MOI&msg=7547.55
incorporating the use of 2 of Wayne's node contributions:
ImgSampler & Spiral nodes.
12 Jan 2020   [#1646] In reply to [#1645]
Pop years 60 revival!
12 Jan 2020   [#1647] In reply to [#1645]
Why Che though?
He was a terrible person.
16 Jan 2020   [#1648] In reply to [#1647]
James, you are real NOD MASTER!
Mik
19 Jan 2020   [#1649] In reply to [#1648]
Mik,
Thank you for your kind words, but I'm but a disciple...the true masters are the node creators.
In this regard, my contributions have been very modest. Max and Karsten have been very quiet of late; but a new champion has picked up the baton: Wayne.
Here's a exercise done with Wayne's latest contribution: "voronoi" node, as well as an illustration using "voronoi" in combination with his earlier contribution: "ImgSampler" node.
19 Jan 2020   [#1650] In reply to [#1649]
Very cool New Voronoi's Node! (and thx to Wayne for all ready made for the Repository! )
The green optic effect disapears at big size! :) Statue of Liberty?
19 Jan 2020   [#1651] In reply to [#1649]
Hi James.
@You : "...but I'm but a disciple...the true masters are the node creators..."
No. I disagree. Thinking abut the current stage of N.E. and Moi I think that the most exciting and awesome works are that made by you and the others great Noders :)
I think that what you're doing is AWESOME.
The student has become the master :)
20 Jan 2020   [#1652]
Hyper cool!
20 Jan 2020   [#1653] In reply to [#1652]
All the guys, you are able to work with NE at such a high and creative level, have my sincere respect!
NE creators have my respect as well of course, I admire their work.
Mik
21 Jan 2020   [#1654]
Sorry what should do Corner 's parameter in the Node Rectangle of the Voronoï example above ?
Seems make nothing...
In the Node Voronoï itself works fine but in rectangle... ???
Message 7777.1655 was deleted
21 Jan 2020   [#1656] In reply to [#1655]
No problem i will be sure i don't miss something! :)
21 Jan 2020   [#1657] In reply to [#1655]
Pilou/James,
In Max's original script, the value of the voronoi corners range from 0 to 100.
Wayne
21 Jan 2020   [#1658] In reply to [#1657]
Good to know!
Message 7777.1659 was deleted
20 Feb 2020   [#1660]
Hi All,
Here is a little tip for wire management when working on complex node circuits.
2 macros with inputs connected directly with outputs can be used to channel multiple wires converging into a conduit and diverging at the other end. See below
Obviously, the example above would not need measures to simplify the wiring, but some circuits can become overwhelming, especially if some time has elapsed since working on them.
Have a great weekend
22 Feb 2020   [#1661]
Here is a Macro which combines four Extract nodes.
The Macro may be placed in the nodeeditor Macros folder, for easy Canvas right click selection.
Do not Load the Macro to the screen.
ps, Three+ Clone nodes in a Macro create a Clone4 Macro, (or more), so no need for the Clone4 node.
Extract_XY.nod
29 Feb 2020   [#1662]
I have been trying to understand the multiProcess command in the Node API.
Max has a detailed explanation of the process in this post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.395
When should it be used and what circumstances?
What could be other uses for the multiProcess?
Wayne
Discord server:
https://discord.gg/zNTasYd
29 Feb 2020   [#1663] In reply to [#1662]
When dealing with multiple entities?
I will be outputting a pointarray with many circle centers, and numarray with corresponding radii, to one circle (or sphere) node, to display a Doyle spiral.
11 Mar 2020   [#1664]
It's been a while, so here's a post using Wayne's recent node contribution: Objects2/PerlinNoise node to generate a field of wave forms
(wave_Field.nod attached)
