1583-1602
1603-1622
1623-1642
1643-1662
1663-1682
1683-1702
1703-1722
1843-1859
Intricated! :)
HI James,
WOW! Thats exactly what I meant looks great thanks very much for looking into it for me a great addition to the expanding node list. Will have a play with it and post any outcomes.
Very inspirational work keep it going.
Best regards
Alex.
A variation on Max's dot-screen portrait of Che:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7547.55
incorporating the use of 2 of Wayne's node contributions:
ImgSampler & Spiral nodes.
Pop years 60 revival!
Why Che though?
He was a terrible person.
James, you are real NOD MASTER!
Mik
Mik,
Thank you for your kind words, but I'm but a disciple...the true masters are the node creators.
In this regard, my contributions have been very modest. Max and Karsten have been very quiet of late; but a new champion has picked up the baton: Wayne.
Here's a exercise done with Wayne's latest contribution: "voronoi" node, as well as an illustration using "voronoi" in combination with his earlier contribution: "ImgSampler" node.
Very cool New Voronoi's Node! (and thx to Wayne for all ready made for the Repository! )
The green optic effect disapears at big size! :) Statue of Liberty?
Hi James.
@You : "...but I'm but a disciple...the true masters are the node creators..."
No. I disagree. Thinking abut the current stage of N.E. and Moi I think that the most exciting and awesome works are that made by you and the others great Noders :)
I think that what you're doing is AWESOME.
The student has become the master :)
Hyper cool!
All the guys, you are able to work with NE at such a high and creative level, have my sincere respect!
NE creators have my respect as well of course, I admire their work.
Mik
Sorry what should do Corner 's parameter in the Node Rectangle of the Voronoï example above ?
Seems make nothing...
In the Node Voronoï itself works fine but in rectangle... ???
Message 7777.1655 was deleted
No problem i will be sure i don't miss something! :)
Pilou/James,
In Max's original script, the value of the voronoi corners range from 0 to 100.
Wayne
Good to know!
Message 7777.1659 was deleted
Hi All,
Here is a little tip for wire management when working on complex node circuits.
2 macros with inputs connected directly with outputs can be used to channel multiple wires converging into a conduit and diverging at the other end. See below
Obviously, the example above would not need measures to simplify the wiring, but some circuits can become overwhelming, especially if some time has elapsed since working on them.
Have a great weekend
https://www.instagram.com/nodeology/Image Attachments:
Here is a Macro which combines four Extract nodes.
The Macro may be placed in the nodeeditor Macros folder, for easy Canvas right click selection.
Do not Load the Macro to the screen.
ps, Three+ Clone nodes in a Macro create a Clone4 Macro, (or more), so no need for the Clone4 node.
Extract_XY.nod
I have been trying to understand the multiProcess command in the Node API.
Max has a detailed explanation of the process in this post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.395
When should it be used and what circumstances?
What could be other uses for the multiProcess?
Wayne
Discord server:
https://discord.gg/zNTasYd
1583-1602
1603-1622
1623-1642
1643-1662
1663-1682
1683-1702
1703-1722
1843-1859
