1566-1585
1586-1605
1606-1625
1626-1645
1646-1665
1666-1685
1686-1705
1846-1859
Hello Brian,
you can find examples where to place "normal" functions in vector.js. If you want to create a lib of functions you can place it in the libs folder under extensions. Max has made an autoload for files placed in that folder. So no link.
Have a nice day
Karsten
That information is very helpful.
Thank you Karsten.
Maybe this can interest you! :)
https://nodevember.io
Hi All,
Surface Tweening Animations: interpolating z values between 2 point Arrays with randomised z values.
Have a great weekend
Cool!
Does exist a trick for see if the are Macros or not ?
And i see (1-a)*b how do you enter (1-a) ?
>> Does exist a trick for see if the are Macros or not ? <<
Yes, the macros are darker, but there are no macros used in example above.
>> And i see (1-a)*b how do you enter (1-a) ? <<
As well as preset functions, you can type custom functions into Math node's F field.
See image below
>> Cool <<
I must retry because this F case return me nothing! :)
After typing in an equation in the F field, press enter, otherwise the entry goes away.
(Slightly annoying). When typing a more complex equation, save a partly correct entry, then re-edit,
otherwise partial work could be lost.
Good to know!
Recursive subdivisions in NE
https://www.instagram.com/nodeology/Image Attachments:
Message 7777.1636 was deleted
WOW! Congrats!
Message 7777.1638 was deleted
Now with Wayne's latest update to ImgSampler node (
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57 ) it's possible to have 3 images of RGB channels (separated in photoshop) output to interleaving dot screens as shown.
Klaus Nomi ? (but i have not my glasses...
Happy new year!
Message 7777.1641 was deleted
Alex
In answer to your query :
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.106
please find .nod file for ImgSample to Hex Pattern.
A series of images showing node circuitry can be found here:
https://www.instagram.com/p/B7HZl5NJ_hp/
Let me know if this is not what you meant
https://www.instagram.com/nodeology/Attachments:
gandhi.nod
Intricated! :)
HI James,
WOW! Thats exactly what I meant looks great thanks very much for looking into it for me a great addition to the expanding node list. Will have a play with it and post any outcomes.
Very inspirational work keep it going.
Best regards
Alex.
A variation on Max's dot-screen portrait of Che:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7547.55
incorporating the use of 2 of Wayne's node contributions:
ImgSampler & Spiral nodes.
1566-1585
1586-1605
1606-1625
1626-1645
1646-1665
1666-1685
1686-1705
1846-1859
