Show messages:  1-12  …  1553-1572  1573-1592  1593-1612  1613-1632  1633-1652  1653-1672  1673-1692  …  1853-1859
6 Oct 2019   [#1613] In reply to [#1612]
For function loadDefaultNodes(), see lines 21 through 26 of the file init.js, located in core subdirectory of nodeeditor.
var node_output = LiteGraph.createNode("Basic/Output");
node_output.pos = [800,100];
graph.add(node_output);
6 Oct 2019   [#1614] In reply to [#1613]
Many thanks!
Cool : works like a charm! Will added in few times http://moiscript.weebly.com/node.html#addanodeselected
var node_selected = LiteGraph.createNode("Objects/Selected");
node_selected.pos = [400,100];
graph.add(node_selected);
6 Oct 2019   [#1615]
Ok i haved finished the Section Not Native Construct2 all English ;) Next will be Curve2
http://moiscript.weebly.com/construct2.html
...except these 2 little things where i am sucked! :(
if you have some ideas ?
19 Oct 2019   [#1616]
Hi All,
I am getting an error message when using curveLength node. (see below)
TypeError: undefined is not an object (evaluating 'this.outputs[1].label = len[0].toFixed(2)')
moi://appdata/nodeeditor/nodes/extensions/infonodes.js   line 74
70:               out.addObject(inObj.item(i).clone());
71:               }
72:             }
73:             this.setOutputData(0, out);
74: >>          if(len.length>0) this.outputs[1].label = len[0].toFixed(2);
75:             this.setOutputData(1, len);
76:         }
77:         crv_length.prototype.onPropertyChange = function ()
78:         {
I have attached a simple .nod file. Can someone please run it to see if problem is universal or specific to my setup. I have already tried reloading both my v4beta & nodeEditor folder without fixing this issue.
I would greatly appreciate any assistance
Have a great weekend
crvLenTest.nod
19 Oct 2019   [#1617]
You ask a curve's length of a Point ?
19 Oct 2019   [#1618] In reply to [#1616]
Hi James,
How did you get a gold output to connect to a green input?
Once detached, I cannot get this incorrect connection to reconnect.
The green output hooked to the green input shows the length as 57.38.
Gold output to an Output node draws the curve.
Its MoI length with unwrap curve script is 57.3800598.
19 Oct 2019   [#1619] In reply to [#1618]
Thanks Brian & Pilou,
Is is apparent now that my fiddling with the code is the issue.
I will overwrite with original code.
Thanks again
19 Oct 2019   [#1620] In reply to [#1619]
Hi James, also the new v4 beta has the arrowheads that rotate towards the viewer that you were asking about a while ago for showing directions.
They can be created like this:
	var startpt = moi.vectorMath.createPoint(5,5,5);
	var endpt = moi.vectorMath.createPoint(10,10,10);
	var f = moi.command.createFactory( 'arrow3d' );
	f.setInput( 0, startpt );
	f.setInput( 1, endpt );
	var arrow = f.calculate().item(0);
	moi.geometryDatabase.addObject( arrow );
	f.cancel();
That creates a Leader with its plane perpendicular to the arrow direction and sets the .rotateArrowheadPlaneTowardsViewer property on it.
20 Oct 2019   [#1621] In reply to [#1619]
@James,
Create a test directory for the Node Editor and call it with a shortcut. This way you keep the original directory and have a test area for playing with nodes.
moi.ui.createDialog( 'moi://appdata/nodeeditortest/index.html?scheme=Light', 'resizeable,defaultWidth:1000,defaultHeight:1000', moi.ui.mainWindow );
The original and test area node editor use the same MOI instance so the nodes are viewable in both the original and test area editors.
You can cut and paste nodes between the node editors and run them separately. How cool is that?
Wayne
20 Oct 2019   [#1622] In reply to [#1620]
Michael
Yes, thank you for the code to address new arrowheads. This will be a real boon for future development of vector nodes.
Wayne
Thanks for the tip of parallel NE for testing coding. This is indeed a "cool" technique.
Thanks again,
22 Oct 2019   [#1623]
Question about writing a new node.
The scripts in MoI often have Functions{} in their code.
The node programs do not seem to use such Functions{} very much.
Instead they use ...prototype...function().
So to use a function from a script, in a node, should they be written as ...prototype...function()?
Or,
I see that in the Lib folder under nodeeditor\nodes\extensions, there is a file called basicFunctions.js,
which is full of miscellaneous functions.
So when writing a node which uses a MoI script with functions, can or should I put the needed functions in a new lib file called, for example, basicFunctions2.js?
It seems that the functions in basicFunctions.js can be (re-)used in any new node?
22 Oct 2019   [#1624] In reply to [#1623]
Hello, Brian,
the prototype function gives the objects created by using the nodeeditor a uniform interface for the processing. Same method names for the various
Knots. So every code of the node creates a type. Later by using the node editor you create objects of these types with a uniform interface of functions.
You can of course use the functions in basicFunctions.js and also create a basicFunctions2.js. You can also write your functions to the same file as your nodes.
For more frequently used functions, it makes sense to store them in a library.
Have a nice day
Karsten
22 Oct 2019   [#1625] In reply to [#1624]
Thank you Karsten.
Two additional related questions:
1. Where would a function go in a node? Inside the .prototype.onExecute = function (), or
just before it?
I have not found any examples, as far as I know.
2. Is it necessary to "link" say basicFunctions2.js somewhere? Or is this already set up?
(I have not searched for an example useage of basicFunctions.js yet.)
23 Oct 2019   [#1626] In reply to [#1625]
Hello Brian,
you can find examples where to place "normal" functions in vector.js. If you want to create a lib of functions you can place it in the libs folder under extensions. Max has made an autoload for files placed in that folder. So no link.
Have a nice day
Karsten
23 Oct 2019   [#1627] In reply to [#1626]
That information is very helpful.
Thank you Karsten.
31 Oct 2019   [#1628]
Maybe this can interest you! :)
https://nodevember.io
8 Nov 2019   [#1629]
Hi All,
Surface Tweening Animations: interpolating z values between 2 point Arrays with randomised z values.
9 Nov 2019   [#1630] In reply to [#1629]
Cool!
Does exist a trick for see if the are Macros or not ?
And i see (1-a)*b how do you enter (1-a) ?
9 Nov 2019   [#1631] In reply to [#1630]
>> Does exist a trick for see if the are Macros or not ? <<
Yes, the macros are darker, but there are no macros used in example above.
>> And i see (1-a)*b how do you enter (1-a) ? <<
As well as preset functions, you can type custom functions into Math node's F field.
See image below
>> Cool <<
9 Nov 2019   [#1632] In reply to [#1631]
I must retry because this F case return me nothing! :)
