Show messages:  1-13  …  1494-1513  1514-1533  1534-1553  1554-1573  1574-1593  1594-1613  1614-1633  …  1854-1859
21 Jun 2019   [#1554] In reply to [#1553]
Hi Brian, well that scene browser thing returns a scene browser item, not a geometry object. A scene browser item is the UI element that makes up one line in the scene browser UI structure. There are functions you can call on it like alterStatus() which is like clicking on the eye icon in the scene browser or select() which is like clicking on the selection dot.
If you have a brep and you want to get its edges, there is a brep.getEdges() function that you can call which returns an object list with all the edges in it, does that do what you need?
21 Jun 2019   [#1555] In reply to [#1554]
Thank you Michael.
That brep.getEdges() function is used in Karsten's ExtractEdges and BrepNameSubObject, so I'll try some modifications to the code to find a matching Edge name...
21 Jun 2019   [#1556] In reply to [#1555]
Hi Brian, so looking through edges of a brep to find one with a particular name would look something like this:
var edges = brep.getEdges();
for ( var i = 0; i < edges.length; ++i )
    var edge = edges.item(i);
    if ( edge.name == 'thename' )
22 Jun 2019   [#1557] In reply to [#1556]
Thank you Michael.
I'll do more study in the next few days...
I finally located the existing "selectedEdges" node, which shows up in Objects2 (nodes) Menu, in the file r2d3.js.
It seems to be outputting the various types of edges as curves...
30 Jun 2019   [#1558]
Interwoven hexagonal meshes done in NodeEditor
Have a great weekend,
30 Jun 2019   [#1559] In reply to [#1558]
T-H-I-S I-S S-O C-O-O-L!!!
Congrats!!!
1 Jul 2019   [#1560] In reply to [#1559]
Node Editor together with James skills offers unbelievable possibilities.
Respect!
Mik
1 Jul 2019   [#1561] In reply to [#1560]
Thank you Mik & Marco,
I am buoyed by your gracious comments and support.
>> Node Editor.....offers unbelievable possibilities. <<
Yes, it really takes MOI3D to the next level. And great fun too!
Here's my latest experiment posted to instagram together with images showing node wiring.
There have been a number of insta-viewers intrigued as to the program used.
A number of those who have stated that they have since downloaded MoI,
and a least one has confirmed his purchase. Hopefully there will be many more!
Anyway, thanks again,
20 Jul 2019   [#1562]
For some training a very not refined and optimised thing! :)
Very rusted - not used that for a long time! :(
But can be used for some combinaisons :)
The 24 position of a dices in the space by step of 90°
Better for the moment to put your object at the origine in a box 5*5*5)
like this ...
PS I don't find the function Copy ??? only a "Clone" node...
Does it possible to add some letters to the list "a, b" ?
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/24poses.nod
20 Jul 2019   [#1563] In reply to [#1562]
Clone nodes can be chained or stacked.
Clone is contained in objects.js, a Max S. program.
A test mod was done, by mindlessly adding and duplicating a few lines, without full understanding of all the code, and seemed to work.
Darn, my lengthy post just vanished...
Often if I bump my logitech M510 mouse, some go_back is triggered, and work is lost. The mouse has too many buttons or something.
I think a mod should be added in the extensions folder, rather than messing up Max's code...
20 Jul 2019   [#1564] In reply to [#1562]
Pilou, Brian et al,
Ideally clone should be abandoned altogether. It is an impediment to workflow and incidentally responsible for excessive redundant node wiring. However, it seems we may be stuck with it until Michael delivers us with instancing (v5?).
Following is an excerpt from an earlier post ( http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.591 ) :
>>Also as I understand it, Javi Agenjo imposed a limitation on nodes
that they can receive only single inputs, but may have unlimited
multiple outputs. However in node editor, nodes with object outputs
are further limited to single outputs necessitating the "clone" node.
This limitation caused by MoI's geometry database architecture. We can't use same objects with multiple nodes. So let's wait until MoI V4 beta. I hope it will support instances.
>>However it would be better to deprecate the "clone" node altogether,
and introduce unlimited multiple outputs to object out nodes as well.
Is this something that is even possible?
It possible, but it can cause significant slowdown. Anyway I'll think about it.
Brian, >> A test mod was done, by mindlessly adding and duplicating a few lines, without full understanding of all the code, and seemed to work. <<
if it was possible to resurrect this node, it would go some way towards reducing the unnecessary bottleneck.
Fingers crossed,
20 Jul 2019   [#1565] In reply to [#1564]
So there is no direct Copy function ?
20 Jul 2019   [#1566] In reply to [#1565]
. >> So there is no direct Copy function ? <<
There would be no need for "Clone" node if object outputs (yellow wire)
behaved similarly to number and point outputs ( green and pink wires)
20 Jul 2019   [#1567]
Here is a simple Clone4 node, which will appear in the Objects2 menu of nodeeditor. (In MoI4Beta of course:-)
Copy/ paste clone4.js to your %AppData%/nodeeditor/nodes/extensions folder.
Also included is a simple node file "SimpleTestOfClone4.nod.
The code is 100% Clone code, with a few added lines which are slightly modified original code.
Added were "c" and "d" output pins.
Also added were two more objectlists, cloneObj2, and cloneObj3, with associated code.
After rudimentary testing, I see that color style is not preserved. Nor was color preserved in Clone node.
Due to being an amateur programmer, use at your own risk:-)
NodeEditorClone4_2019.zip
21 Jul 2019   [#1568] In reply to [#1567]
Thanks for the efforts!
21 Jul 2019   [#1569] In reply to [#1561]
@ James & others
I believe that you will love this artist! Joey Camacho
https://rawandrendered.com/projects
21 Jul 2019   [#1570] In reply to [#1569]
Hi Pilou!
@You: "I believe that you will love this artist! Joey Camacho "
Amazing creations!!!
Wonderful!
Saved into my bookmarks :)
21 Jul 2019   [#1571] In reply to [#1569]
Thanks for the link....Yery Cool!
Here's a new NE generated screen transition
22 Jul 2019   [#1572]
Hello
whith node random_obj i have this
For simulate different gaps: display random number of objects on their positions from a collection
Node random Obj is existing
not yet exactly that i wish :) the gaps 1 3 1 1 1 2 1 result must be on each object
but it's more like that i wish :)
A random gab between each object selected!
Classic Random
Move is existing
Display is existing
Not sure about the "one by one"...and the "loop / return"
Does this is possible ? A sort of random gab distribution between each object selected!
For make some variation of this follow where gabs are regular except on the front corner! ;)
https://rawandrendered.com/modularity
From a Camacho image above
22 Jul 2019   [#1573] In reply to [#1572]
lol, not studied yet:
http://paulbourke.net/papers/joc2013/paper.pdf
Simplex noise patent anticipated expiration is 2022-01-08.
This link looks interesting, but have no time to study it.
(grasshopper, anemone recursion mentioned...)
https://discourse.mcneel.com/t/subdivide-given-area-into-randomly-sized-blocks-with-no-gaps/58003/15
-Brian
