Show messages:  1-5  …  1466-1485  1486-1505  1506-1525  1526-1545  1546-1565  1566-1585  1586-1605  …  1846-1859
Message 7777.1526 was deleted
25 May 2019   [#1527] In reply to [#1526]
Eye pleasant and amazing as usual!!!
You keep very high your bar :)
26 May 2019   [#1528] In reply to [#1527]
Cheers Marco,
Thanks for your appreciation.
Here is a screen proposal done in NE with randomised curve attractors.
29 May 2019   [#1529] In reply to [#1527]
An another
3 Jun 2019   [#1530]
Another NE experiment with curve attractor rotating and scaling triangular cutouts
4 Jun 2019   [#1531]
Another woven pattern done with NodeEditor
4 Jun 2019   [#1532] In reply to [#1531]
Very complex and beautiful!
4 Jun 2019   [#1533] In reply to [#1532]
>> Very complex and beautiful! <<
Thanks Marco! I appreciate your appreciation.
The result may look complex, but it you look at the node wiring images on instagram
you will see that it was relatively simple tp define....
...while allowing for infinite manipulation of the resultant weave.
Such is the advantage of this methodology.
Anyway, thanks again
5 Jun 2019   [#1534] In reply to [#1533]
It's awesome !
but it is possible to map this texture on my own model and not just a sphere ?
Message 7777.1535 was deleted
5 Jun 2019   [#1536]
James or the Braidings' Master!
5 Jun 2019   [#1537] In reply to [#1534]
Finema,
>> it is possible to map this texture on my own model and not just a sphere ? <<
If your model is a 4 sided patch it will map. See attached. seamless texture on revolved surface.
If your model was a poly-surface it may be possible, however ensure seam map seamlessly may
be difficult.
UPDATED: more complex texture mapped form posted here:
Hope this helps.
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
triAxialWeaveSepColors.nod
5 Jun 2019   [#1538] In reply to [#1537]
Yes, it's very interesting. Too bad there are no scripts on your instagram.
6 Jun 2019   [#1539] In reply to [#1538]
Finema,
>> Too bad there are no scripts on your instagram <<
I've uploaded .nod file to previous post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1537
6 Jun 2019   [#1540] In reply to [#1537]
James this is really A-M-A-Z-I-N-G!!!
Simply...beautiful :)
It could be very very interesting to see some of your creations turned into reality with a 3D-printer or other kind of manufacturing process.
Listen to me, think about it James.
You could build stylish furnishing objects and decorative items for house!
Your creations deserve to be turned into reality!
6 Jun 2019   [#1541] In reply to [#1540]
Thank you so much Marco,
>> very interesting to see some of your creations turned into reality with a 3D-printer <<
I have a cheap 3d printer which I have used to print some of these designs, with varying degree of success. I do in the future plan though to send something to Shapeways or similar for quality print.
>> You could build stylish furnishing objects and decorative items for house! <<
I thought I once posted a woven pendant lamp example, but can't find the thread posting. Anyway I have attached another here
There are other examples of my work at www.jameshargraves.com
As it happens, I do plan to do something along these lines with this triaxial weave & the randomised bulbous forms.
Thanks again for your support
6 Jun 2019   [#1542] In reply to [#1541]
@You: "There are other examples of my work at www.jameshargraves.com"
Wonderful things. Congrats!
14 Jun 2019   [#1543]
Here's an amusing little experiment inspired by the work of Christian Bird (fellow noder)
as shown here: https://www.instagram.com/christianbirdnyc/
Latest NE folder can be found here:
dandelion.nod
14 Jun 2019   [#1544] In reply to [#1543]
It is amazing what can be done with MoI and Nodeeditor!
Seed count of a dandelion is on the to do list.
- B
14 Jun 2019   [#1545] In reply to [#1543]
In just one word: Poetry.
Hats off!
