1463-1482
1483-1502
1503-1522
1523-1542
1543-1562
1563-1582
1583-1602
1843-1859
Cool! There is not an artefact on the top ? Like a hole ...
Message 7777.1524 was deleted
Message 7777.1525 was deleted
Message 7777.1526 was deleted
Eye pleasant and amazing as usual!!!
You keep very high your bar :)
Cheers Marco,
Thanks for your appreciation.
Here is a screen proposal done in NE with randomised curve attractors.
An another
Another NE experiment with curve attractor rotating and scaling triangular cutouts
Another woven pattern done with NodeEditor
Very complex and beautiful!
>> Very complex and beautiful! <<
Thanks Marco! I appreciate your appreciation.
The result may look complex, but it you look at the node wiring images on instagram
you will see that it was relatively simple tp define....
...while allowing for infinite manipulation of the resultant weave.
Such is the advantage of this methodology.
Anyway, thanks again
It's awesome !
but it is possible to map this texture on my own model and not just a sphere ?
Message 7777.1535 was deleted
James or the Braidings' Master!
Finema,
>> it is possible to map this texture on my own model and not just a sphere ? <<
If your model is a 4 sided patch it will map. See attached. seamless texture on revolved surface.
If your model was a poly-surface it may be possible, however ensure seam map seamlessly may
be difficult.
UPDATED: more complex texture mapped form posted here:
Hope this helps.
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1Attachments:
triAxialWeaveSepColors.nod
Yes, it's very interesting. Too bad there are no scripts on your instagram.
Finema,
>> Too bad there are no scripts on your instagram <<
I've uploaded .nod file to previous post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1537
James this is really A-M-A-Z-I-N-G!!!
Simply...beautiful :)
It could be very very interesting to see some of your creations turned into reality with a 3D-printer or other kind of manufacturing process.
Listen to me, think about it James.
You could build stylish furnishing objects and decorative items for house!
Your creations deserve to be turned into reality!
Thank you so much Marco,
>> very interesting to see some of your creations turned into reality with a 3D-printer <<
I have a cheap 3d printer which I have used to print some of these designs, with varying degree of success. I do in the future plan though to send something to Shapeways or similar for quality print.
>> You could build stylish furnishing objects and decorative items for house! <<
I thought I once posted a woven pendant lamp example, but can't find the thread posting. Anyway I have attached another here
There are other examples of my work at
www.jameshargraves.com
As it happens, I do plan to do something along these lines with this triaxial weave & the randomised bulbous forms.
Thanks again for your support
https://www.instagram.com/nodeology/Image Attachments:
@You: "There are other examples of my work at
www.jameshargraves.com"
Wonderful things. Congrats!
1463-1482
1483-1502
1503-1522
1523-1542
1543-1562
1563-1582
1583-1602
1843-1859
