1459-1478
1479-1498
1499-1518
1519-1538
1539-1558
1559-1578
1579-1598
1859
Hi Friends
Reconnecting to James's Fractal file,
I tried to create a Fractal Macro
that could be applied to a Basic Polygon -
to get the iterations, you need to reapply
the Macro at its Out Curve n times ...
Unfortunately I was unable to apply the iterations
to a parameter ...
Perhaps, Karsten, whose recent Tools (Loop) I saw
I have to say, they are still quite mysterious to me
will be able to improve this iterative process
file to this Link:
http://www.mediafire.com/file/440cay7pld8o5xx/M-FRACTAL.zip/file
have a nice day to all
al
Message 7777.1520 was deleted
Message 7777.1521 was deleted
"BLOBBY FICTION!"
Cool! There is not an artefact on the top ? Like a hole ...
Message 7777.1524 was deleted
Message 7777.1525 was deleted
Message 7777.1526 was deleted
Eye pleasant and amazing as usual!!!
You keep very high your bar :)
Cheers Marco,
Thanks for your appreciation.
Here is a screen proposal done in NE with randomised curve attractors.
An another
Another NE experiment with curve attractor rotating and scaling triangular cutouts
Another woven pattern done with NodeEditor
Very complex and beautiful!
>> Very complex and beautiful! <<
Thanks Marco! I appreciate your appreciation.
The result may look complex, but it you look at the node wiring images on instagram
you will see that it was relatively simple tp define....
...while allowing for infinite manipulation of the resultant weave.
Such is the advantage of this methodology.
Anyway, thanks again
It's awesome !
but it is possible to map this texture on my own model and not just a sphere ?
Message 7777.1535 was deleted
James or the Braidings' Master!
Finema,
>> it is possible to map this texture on my own model and not just a sphere ? <<
If your model is a 4 sided patch it will map. See attached. seamless texture on revolved surface.
If your model was a poly-surface it may be possible, however ensure seam map seamlessly may
be difficult.
UPDATED: more complex texture mapped form posted here:
Hope this helps.
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1Attachments:
triAxialWeaveSepColors.nod
Yes, it's very interesting. Too bad there are no scripts on your instagram.
1459-1478
1479-1498
1499-1518
1519-1538
1539-1558
1559-1578
1579-1598
1859
