Show messages:  1-17  …  1458-1477  1478-1497  1498-1517  1518-1537  1538-1557  1558-1577  1578-1597  …  1858-1859
Message 7777.1518 was deleted
16 May 2019   [#1519]
Hi Friends
Reconnecting to James's Fractal file,
I tried to create a Fractal Macro
that could be applied to a Basic Polygon -
to get the iterations, you need to reapply
the Macro at its Out Curve n times ...
Unfortunately I was unable to apply the iterations
to a parameter ...
Perhaps, Karsten, whose recent Tools (Loop) I saw
I have to say, they are still quite mysterious to me
will be able to improve this iterative process
file to this Link:
http://www.mediafire.com/file/440cay7pld8o5xx/M-FRACTAL.zip/file
have a nice day to all
al
Message 7777.1520 was deleted
Message 7777.1521 was deleted
17 May 2019   [#1522] In reply to [#1521]
"BLOBBY FICTION!"
17 May 2019   [#1523]
Cool! There is not an artefact on the top ? Like a hole ...
Message 7777.1524 was deleted
Message 7777.1525 was deleted
Message 7777.1526 was deleted
25 May 2019   [#1527] In reply to [#1526]
Eye pleasant and amazing as usual!!!
You keep very high your bar :)
26 May 2019   [#1528] In reply to [#1527]
Cheers Marco,
Thanks for your appreciation.
Here is a screen proposal done in NE with randomised curve attractors.
29 May 2019   [#1529] In reply to [#1527]
An another
3 Jun 2019   [#1530]
Another NE experiment with curve attractor rotating and scaling triangular cutouts
4 Jun 2019   [#1531]
Another woven pattern done with NodeEditor
4 Jun 2019   [#1532] In reply to [#1531]
Very complex and beautiful!
4 Jun 2019   [#1533] In reply to [#1532]
>> Very complex and beautiful! <<
Thanks Marco! I appreciate your appreciation.
The result may look complex, but it you look at the node wiring images on instagram
you will see that it was relatively simple tp define....
...while allowing for infinite manipulation of the resultant weave.
Such is the advantage of this methodology.
Anyway, thanks again
5 Jun 2019   [#1534] In reply to [#1533]
It's awesome !
but it is possible to map this texture on my own model and not just a sphere ?
Message 7777.1535 was deleted
5 Jun 2019   [#1536]
James or the Braidings' Master!
5 Jun 2019   [#1537] In reply to [#1534]
Finema,
>> it is possible to map this texture on my own model and not just a sphere ? <<
If your model is a 4 sided patch it will map. See attached. seamless texture on revolved surface.
If your model was a poly-surface it may be possible, however ensure seam map seamlessly may
be difficult.
UPDATED: more complex texture mapped form posted here:
Hope this helps.
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
triAxialWeaveSepColors.nod
