Show messages:  1-16  …  1457-1476  1477-1496  1497-1516  1517-1536  1537-1556  1557-1576  1577-1596  …  1857-1859
13 May 2019   [#1517] In reply to [#1516]
oh awesome. thanks pilou. gifcam looks great. i used to use screencast-o-matic a long tiime ago. recently tried open broadcaster, but was having issues with that. i found my amd drivers to be the best option. i'm using that now for videos. but gifcam looks great for short uploads like you have been doing. i think this is really useful. thanks for sharing how you have been doing it.
Message 7777.1518 was deleted
16 May 2019   [#1519]
Hi Friends
Reconnecting to James's Fractal file,
I tried to create a Fractal Macro
that could be applied to a Basic Polygon -
to get the iterations, you need to reapply
the Macro at its Out Curve n times ...
Unfortunately I was unable to apply the iterations
to a parameter ...
Perhaps, Karsten, whose recent Tools (Loop) I saw
I have to say, they are still quite mysterious to me
will be able to improve this iterative process
file to this Link:
http://www.mediafire.com/file/440cay7pld8o5xx/M-FRACTAL.zip/file
have a nice day to all
al
Message 7777.1520 was deleted
Message 7777.1521 was deleted
17 May 2019   [#1522] In reply to [#1521]
"BLOBBY FICTION!"
17 May 2019   [#1523]
Cool! There is not an artefact on the top ? Like a hole ...
Message 7777.1524 was deleted
Message 7777.1525 was deleted
Message 7777.1526 was deleted
25 May 2019   [#1527] In reply to [#1526]
Eye pleasant and amazing as usual!!!
You keep very high your bar :)
26 May 2019   [#1528] In reply to [#1527]
Cheers Marco,
Thanks for your appreciation.
Here is a screen proposal done in NE with randomised curve attractors.
29 May 2019   [#1529] In reply to [#1527]
An another
3 Jun 2019   [#1530]
Another NE experiment with curve attractor rotating and scaling triangular cutouts
4 Jun 2019   [#1531]
Another woven pattern done with NodeEditor
4 Jun 2019   [#1532] In reply to [#1531]
Very complex and beautiful!
4 Jun 2019   [#1533] In reply to [#1532]
>> Very complex and beautiful! <<
Thanks Marco! I appreciate your appreciation.
The result may look complex, but it you look at the node wiring images on instagram
you will see that it was relatively simple tp define....
...while allowing for infinite manipulation of the resultant weave.
Such is the advantage of this methodology.
Anyway, thanks again
5 Jun 2019   [#1534] In reply to [#1533]
It's awesome !
but it is possible to map this texture on my own model and not just a sphere ?
Message 7777.1535 was deleted
5 Jun 2019   [#1536]
James or the Braidings' Master!
