Show messages:  1-11  …  1412-1431  1432-1451  1452-1471  1472-1491  1492-1511  1512-1531  1532-1551  …  1852-1859
26 Apr 2019   [#1472]
Hi All,
Latest exploration.
A great weekend to all
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
DiaHex.nod
27 Apr 2019   [#1473] In reply to [#1472]
Great things :)
Congrats!!
27 Apr 2019   [#1474] In reply to [#1472]
A web search of "dupin cyclide conformal map" brings up interesting papers.
- B
27 Apr 2019   [#1475]
Hi All,
Multiple random Point Attractors determine hexagonal Screen hole radii
Have a great weekend,
Message 7777.1476 was deleted
30 Apr 2019   [#1477]
Hi all Friends
I was a few days holiday, just now ,
I see the latest news in the Forum _
Brian - Thanks for the clarifications regarding the Centroid tool
James - Congratulations on your latest work;
I found a small inaccuracy in determining the reference surface (Flow tool) in your file (DiaPlanarFaces)
at this link:
http://www.mediafire.com/file/56jgl6gvgzg5a0m/Rev-DiaPlanarFaces.zip/file
the file with the revision
Have a nice day everyone
al
2 May 2019   [#1478]
Hi Friends
a nice example, at least I think, of a hypothetical and singular
mechanical clock
file at this link :
http://www.mediafire.com/file/4vm71yg0ad0565d/Mechanical_Clock.zip/file
Have a nice day to all
al
3 May 2019   [#1479]
Hi Friends
a striking effect on surfaces.
the file at this link:
http://www.mediafire.com/file/5elcgg2sgios82d/Louvre_Box.zip/file
Happy weekend to all
al
3 May 2019   [#1480] In reply to [#1479]
Nice Louver, Speedy.
Your Twist node comes up red ("missing" node).
Replacement with Twist node under Transform menu, in my nodeeditor setup, worked.
4 May 2019   [#1481] In reply to [#1480]
Many thanks, Brian
4 May 2019   [#1482] In reply to [#1479]
Hi Al,
Your louvred box was inspirational.
I have taken an alternative approach lofting profiles along axes, rotated (rather than twisted) in response to proximity to curve attractor.
It is shown here in an architectural context where it forms facade treatment to fully glazed curtain wall behind.
Keep up the good work
Additional images posted:
louvreCrvAttractor.nod
6 May 2019   [#1483] In reply to [#1482]
Hi All,
My latest NE experiment
hexRelief.nod
6 May 2019   [#1484]
What is the last evolution of a complete folder nodeeditor ?
Message 7777.1485 was deleted
6 May 2019   [#1486] In reply to [#1485]
thx but about the last node editor folder "nodeeditor" itself ?
it's the max one on its site ?
Ps very cool page!
6 May 2019   [#1487] In reply to [#1486]
OK Pilou,
My NE folder can be found here:
Hope this works for you
6 May 2019   [#1488]
I just started learning more about node editor and made some progress where i can see how could i use it in my own workflow.
There is a problem i have and i can't solve it no matter what i do. I can't use Macro at all. Whenever i RMB click in the work area and i click on "Macro" i just get Script Error message (image attached). I have seen someone a while ago having a similar issue, tried suggestions but no success.
Does the latest version on node editor support moi3d v3 or is it for v4 only?
I have also tried to copy the nodeeditor folder in "C:\Users\username\AppData\Roaming\Moi" and when i run the command in Moi i just get the blank window.
Now i have it in "C:\Program Files (x86)\MoI 3.0\ui" and it seems like everything works perfectly fine except that Macro problem.
Does anyone know what could be the problem?
Thank you very much.
6 May 2019   [#1489] In reply to [#1488]
Klaudio,
Welcome aboard! You are, I assume the same Klaudio I chatted to on instagram?
Have you tried replacing the nodeeditor folder in "C:\Users\username\AppData\Roaming\Moi"
with one found here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=9358.1
It should work for both, but V4, although technically still in beta stage, is rock solid; so there is no reason not to be using it. I'm on a mac so perhaps its a windows issue.
>> Please keep it up to date whenever you can......
Thank you for your appreciation of "Current NODE EDITOR folder" thread. I wonder if I might ask though if you could delete your post: http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.2 and keep correspondence in this thread, so that the other thread remains a single post of most current file directory.
I hope this helps you get up & running. I look forward to seeing what you get up to.
6 May 2019   [#1490] In reply to [#1489]
Hi James,
Yes, it's me. And thanks! ;)
>> Have you tried replacing the nodeeditor folder in "C:\Users\username\AppData\Roaming\Moi"...
Yes, just tried your version in both AppData and ProgramFiles folders but i still have the same problem.
Interesting is that i just get blank node editor window when i put it AppData folder. I am using this line bellow as shortcut in Moi which gives me that blank mode editor window. Is it correct?
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
>> I wonder if I might ask though if you could delete your post....
No problem at all! Deleted there.
6 May 2019   [#1491] In reply to [#1490]
Klaudio,
Have a look at the following:
http://moi3d.com/wiki/Troubleshooting
http://moi3d.com/forum/index.php?webtag=MOI&msg=9172.5
