Show messages:  1-5  …  1406-1425  1426-1445  1446-1465  1466-1485  1486-1505  1506-1525  1526-1545  …  1846-1859
17 Apr 2019   [#1466]
Cool start! :)
17 Apr 2019   [#1467] In reply to [#1464]
Wonderful job James!!
Congrats!
Message 7777.1468 was deleted
24 Apr 2019   [#1469]
Hi everyone, and in particular Brian
Attached the file in which the Centroid tool
does not give the expected result ... maybe it will be
the case to consider well what this malfunction derives ...
Logically, when you have time, and if you want to do it
every tool we put at our disposal is a gift ...
"few words to the wise"
file at this link:
http://www.mediafire.com/file/oq4olj4yz9ame4y/FelixCandela.zip/file
have nice day to all
al
25 Apr 2019   [#1470] In reply to [#1469]
Hi Speedy,
For the center 16 triangles, the centroid point is being found.
The remaining 32, 4 sided closed curves are not planar. This centroid node works for planar polygons.
(The Planar command does not work on the 32, 4 sided closed curves either.)
The center of mass of half of a solid sphere is at 3/8 of the distance from the sphere's center to the hemisphere's pole, as shown by Max's cVolume2.
For a hollow hemisphere, the distance is 1/2.
https://en.wikipedia.org/wiki/Centroid
The centroid node does not work for hemispheres either.
Wolfram gives a formula for center of mass for spherical caps.
Also Wolfram gives a formula for the centroid of a quadrilateral as the midpoint of the line between the midpoints of the diagonals.
Or "The centroid of the vertices of a quadrilateral occurs at the point of intersection of the bimedians."
http://mathworld.wolfram.com/GeometricCentroid.html
(Usually I find Wolfram math difficult to understand, and do not plan on doing integrals:-)
So the centroid for quadrilaterals, (4 line segments forming a closed quad), planar or non-planar, could be easily calculated.
The closed quads could be tested for planarity (somehow), and the calculation added to the centroid node. (I think.)
Is there a MoI method to test for planarity?
25 Apr 2019   [#1471]
Hi All,
Here's a texture of planar quad facets. It may not look like much, but it is a significant step towards structure that may be fabricated from cnc or laser-cut flat panels from board or sheet material. A multi panel image of node circuitry can be found at: https://www.instagram.com/nodeology/
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
nod file found here (Al made minor revision to my file & posted here):
http://www.mediafire.com/file/56jgl6gvgzg5a0m/Rev-DiaPlanarFaces.zip/file
26 Apr 2019   [#1472]
Hi All,
Latest exploration.
A great weekend to all
DiaHex.nod
27 Apr 2019   [#1473] In reply to [#1472]
Great things :)
Congrats!!
27 Apr 2019   [#1474] In reply to [#1472]
A web search of "dupin cyclide conformal map" brings up interesting papers.
- B
27 Apr 2019   [#1475]
Hi All,
Multiple random Point Attractors determine hexagonal Screen hole radii
Have a great weekend,
Message 7777.1476 was deleted
30 Apr 2019   [#1477]
Hi all Friends
I was a few days holiday, just now ,
I see the latest news in the Forum _
Brian - Thanks for the clarifications regarding the Centroid tool
James - Congratulations on your latest work;
I found a small inaccuracy in determining the reference surface (Flow tool) in your file (DiaPlanarFaces)
at this link:
the file with the revision
Have a nice day everyone
al
2 May 2019   [#1478]
Hi Friends
a nice example, at least I think, of a hypothetical and singular
mechanical clock
file at this link :
http://www.mediafire.com/file/4vm71yg0ad0565d/Mechanical_Clock.zip/file
Have a nice day to all
al
3 May 2019   [#1479]
Hi Friends
a striking effect on surfaces.
the file at this link:
http://www.mediafire.com/file/5elcgg2sgios82d/Louvre_Box.zip/file
Happy weekend to all
al
3 May 2019   [#1480] In reply to [#1479]
Nice Louver, Speedy.
Your Twist node comes up red ("missing" node).
Replacement with Twist node under Transform menu, in my nodeeditor setup, worked.
4 May 2019   [#1481] In reply to [#1480]
Many thanks, Brian
4 May 2019   [#1482] In reply to [#1479]
Hi Al,
Your louvred box was inspirational.
I have taken an alternative approach lofting profiles along axes, rotated (rather than twisted) in response to proximity to curve attractor.
It is shown here in an architectural context where it forms facade treatment to fully glazed curtain wall behind.
Keep up the good work
Additional images posted:
louvreCrvAttractor.nod
6 May 2019   [#1483] In reply to [#1482]
Hi All,
My latest NE experiment
hexRelief.nod
6 May 2019   [#1484]
What is the last evolution of a complete folder nodeeditor ?
Message 7777.1485 was deleted
