Show messages:  1-15  …  1396-1415  1416-1435  1436-1455  1456-1475  1476-1495  1496-1515  1516-1535  …  1856-1859
9 Apr 2019   [#1456]
CentroidNodeBeta003
The file is still in its own .js node wrapper, but has been moved to the Points2 menu. (not the Points2.js file, which could/should be done.)
So after placing beta003 in the extensions folder, if the node appears red in your .nod program, replace the node with the one from the Points2 menu.
Also fixed the raw centroid point(s) output (Pink) with the proper code, as shown in Objects.js/ObjtoArray node. (output2.pushPoint(cPtObj.item(0).pt);)
(Just use either the centroidObj point output, or the pink output, to avoid duplicate points...)
Note that Max's cVolume2 script finds centers of gravity for one extruded closed planar object, including extruded curved closed planar objects.
It seems to be a very long script.
Will look at FatLines.
CentroidNodeBeta003.zip
PolyCentroidNodeTest4.zip
10 Apr 2019   [#1457]
Just for a bit of Conic Relief
Node circuitry images post to: https://www.instagram.com/nodeology/
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
ConicRelief.nod
10 Apr 2019   [#1458] In reply to [#1457]
Cool image for Bees! (and for enlight users about subject of Nodes ! ;)
Sorry I have no times for the moment manage all nodes for a years! :(
10 Apr 2019   [#1459] In reply to [#1457]
Hi James,
Do you have a link to "WaveSurf"?
For your old ProjectSurf.nod, replacing red Project node with Construct1/ProjectMP enabled the .nod to run.
Your old paraSurf.nod has a couple of red nodes...in the copy I have.
10 Apr 2019   [#1460] In reply to [#1459]
Brian,
>> Do you have a link to "WaveSurf"? <<
"WaveSurf" is a macro. I have attached nod file to previous post, so macro can be found within.
I had not included before, because there was nothing really new here in terms of technique. It was done specifically to post to instagram, to keep the page fresh.>> Your old ProjectSurf.nod....[&]....paraSurf.nod has a couple of red nodes..<<
All these macro need to be reworked. I don't know that any of them are worthy of dissemination. I only used "WaveSurf" and "B-Hive Grid" for that matter, due to laziness.
,>> Will look at FatLines. <<
Did you get a chance to study Max's script?
Anyway, keep up the good work
10 Apr 2019   [#1461] In reply to [#1460]
James, thank you for WaveSurf macro.
I've looked at FatLines a little, and spread out, to line items, the functions shown scrunched into condensed paragraphs.
I see offset or flow, boolean union, scale1d, and still have to "decipher"/"understand" Max's code. :-)
Max is such a skilled programmer! There seems to be a lot going on...
I think that I will start converting bits of the code..., and fill in gaps in understanding...
Message 7777.1462 was deleted
12 Apr 2019   [#1463] In reply to [#1462]
Cool !
I suppose you know that : https://www.etereaestudios.com/docs_html/isfahan_htm/isfahan_index.htm
and this facinated site! http://www.tamabi.ac.jp/idd/shiro/muqarnas/default.htm
and other cool things https://www.ics.uci.edu/~eppstein/junkyard/penrose.html
http://www.dartmouth.edu/~matc/math5.pattern/syllabus.html (Click Art Part section)
http://www.protozone.net/AJinteractives1.html
16 Apr 2019   [#1464]
I was inspired by this image (top) to see if I could generate a buildable structure in NE.
All the plank elements are indeed straight (ie the bow from flow to surface has been removed).
However it is not quite there yet, because the plank thickness varies. They will need to be uniform thickness to make structure fabrication viable. Anyway it is a start.
hexPav.nod
16 Apr 2019   [#1465] In reply to [#1464]
wow very cool, useful, and ambitious. I hope you figure it out. Certainly a challenge.
17 Apr 2019   [#1466]
Cool start! :)
17 Apr 2019   [#1467] In reply to [#1464]
Wonderful job James!!
Congrats!
Message 7777.1468 was deleted
24 Apr 2019   [#1469]
Hi everyone, and in particular Brian
Attached the file in which the Centroid tool
does not give the expected result ... maybe it will be
the case to consider well what this malfunction derives ...
Logically, when you have time, and if you want to do it
every tool we put at our disposal is a gift ...
"few words to the wise"
file at this link:
http://www.mediafire.com/file/oq4olj4yz9ame4y/FelixCandela.zip/file
have nice day to all
al
25 Apr 2019   [#1470] In reply to [#1469]
Hi Speedy,
For the center 16 triangles, the centroid point is being found.
The remaining 32, 4 sided closed curves are not planar. This centroid node works for planar polygons.
(The Planar command does not work on the 32, 4 sided closed curves either.)
The center of mass of half of a solid sphere is at 3/8 of the distance from the sphere's center to the hemisphere's pole, as shown by Max's cVolume2.
For a hollow hemisphere, the distance is 1/2.
https://en.wikipedia.org/wiki/Centroid
The centroid node does not work for hemispheres either.
Wolfram gives a formula for center of mass for spherical caps.
Also Wolfram gives a formula for the centroid of a quadrilateral as the midpoint of the line between the midpoints of the diagonals.
Or "The centroid of the vertices of a quadrilateral occurs at the point of intersection of the bimedians."
http://mathworld.wolfram.com/GeometricCentroid.html
(Usually I find Wolfram math difficult to understand, and do not plan on doing integrals:-)
So the centroid for quadrilaterals, (4 line segments forming a closed quad), planar or non-planar, could be easily calculated.
The closed quads could be tested for planarity (somehow), and the calculation added to the centroid node. (I think.)
Is there a MoI method to test for planarity?
25 Apr 2019   [#1471]
Hi All,
Here's a texture of planar quad facets. It may not look like much, but it is a significant step towards structure that may be fabricated from cnc or laser-cut flat panels from board or sheet material. A multi panel image of node circuitry can be found at: https://www.instagram.com/nodeology/
nod file found here (Al made minor revision to my file & posted here):
http://www.mediafire.com/file/56jgl6gvgzg5a0m/Rev-DiaPlanarFaces.zip/file
26 Apr 2019   [#1472]
Hi All,
Latest exploration.
A great weekend to all
DiaHex.nod
27 Apr 2019   [#1473] In reply to [#1472]
Great things :)
Congrats!!
27 Apr 2019   [#1474] In reply to [#1472]
A web search of "dupin cyclide conformal map" brings up interesting papers.
- B
27 Apr 2019   [#1475]
Hi All,
Multiple random Point Attractors determine hexagonal Screen hole radii
Have a great weekend,
