Show messages:  1-17  …  1338-1357  1358-1377  1378-1397  1398-1417  1418-1437  1438-1457  1458-1477  …  1858-1859
13 Mar 2019   [#1398] In reply to [#1394]
Hello Brian,
could you please test this:
 if ( document.URL.indexOf("appdata") > 0 ) { docupath = document.URL.split("index.html")[0]+"nodes\/extensions\/Documentation\/"+lang.LANGUAGE + "\/"; }
					else { docupath = document.URL.split(/moi:\/\/(.*\/).*/g)[1].replace("ui","")+"nodes\/extensions\/Documentation\/"+lang.LANGUAGE + "\/"; }
Thanks in advance!
Karsten
13 Mar 2019   [#1399] In reply to [#1398]
Hi Karsten,
This version enables the doc dropdown in both "Light" and "default Dark" versions of nodeeditor. (It looks like you added [0] to your code.)
However it also creates a "mouse scroll/zoom wheel" "Hole" at the top center of the nodeeditor screen, Light or Default version.
14 Mar 2019   [#1400] In reply to [#1399]
Hello Brian,
I've changed to split and take the first part by [0].
The scroll wheel issue doesn't happenend here with Windows 7 64bit and MoI Beta V4. I've tested also on Windows 10 - also no Problem!?
Have a nice day
Karsten
14 Mar 2019   [#1401] In reply to [#1400]
Hi Karsten,
So far, no one else has reported having the "Hole", so ...?...
14 Mar 2019   [#1402] In reply to [#1401]
Hi Karsten,
It seems that snaggit13 was causing the "Hole", so your latest code seems to be just fine, and enables Light and Default Dark nodeeditor, along with the ne doc dropdown.
14 Mar 2019   [#1403] In reply to [#1402]
This world is too complicated for an old man like me.
Message 7777.1404 was deleted
18 Mar 2019   [#1405] In reply to [#1404]
Hi All,
Screen above lofted to fully open pattern to give variable aperture relief, mapped to a surface
18 Mar 2019   [#1406] In reply to [#1405]
Amazing James!
Great job!!
Message 7777.1407 was deleted
18 Mar 2019   [#1408] In reply to [#1405]
Much nicer than a recent stucco expanded metal purchase.
19 Mar 2019   [#1409]
Hi James
for what little it is worth ..
amazing result
alberto
19 Mar 2019   [#1410] In reply to [#1409]
Thanks Al
It is worth a lot,
22 Mar 2019   [#1411]
After 2 weeks of intermittent coding, study of many nodes, mostly by Karsten, and hundreds of corrections, a node for LineWeb was created.
There are many comments in the code, which could be removed.
In addition to the LineWeb node, a simple demo node program is attached.
Copy the LineWebNode.js file in the nodeeditor Extensions folder.
This will place the LineWeb node in the Construct2 menu.
(Construct2 could also be edited to include the LineWeb node code.) Maybe Karsten or James will do this, after the node is tested?
Testing has been minimal.
Input of other objectlist types has not be tested, nor is there any code to check for other types of objectlists.
LineWebNode.zip
LineWebNodeDemo04.zip
23 Mar 2019   [#1412]
For simple curve nodes such as Line, Circle, Star, Polygon, Curve/Interpcurve, ..., wired to an Output node, what color will the curve be drawn in?
If the Output node has "--" set for Style color, the color drawn will be the Style color currently in effect for MoI:
a. when the curve output is Wired to said Output node. And Run.
b. when the curve output is Rewired to said Output node.
c. when the node program is re-Loaded and Run.
If the Output node has a Style color set in it's Info box, that will be the color drawn, at Run, or during Run, over-riding a previously wired MoI Style color.
In the current session, Switching the Output node Style color set in it's Info box back to "--", reverts to the MoI Style color previously in effect, (even if MoI Style was changed, and there was no rewire.) (The previous wired color is "remembered" for the current MoI nodeeditor session.)
24 Mar 2019   [#1413]
Normal Distribution, Bell Curve.
NormalDistribution.zip
26 Mar 2019   [#1414]
UnwrapCurve node, with majority of the code from UnwrapCurve script of Michael, made compatible with nodeeditor.
Learned that script (sub) functions are located in nodeeditor basicFunctions.js. LengthSq was not in there,
but magnitude(vec) was, as well as normalizeVec(vec) and scaleVec(vec,factor).
dir.scale( 1.0 / magnitude(dir) ); code did not work properly, (Lines and curves had Unwrap length squared, but circles and stars yielded the correct Unwrap length.)
but, dir = scaleVec( dir,1/magnitude(dir) );, did work properly.
(Limited testing)
There is no code to restrict input to curves...
29 Mar 2019   [#1415]
2 Trivial questions just for concept! :)
Does Elephant can call an existing command like the last InsertCircle by Michael ?
http://moi3d.com/forum/messages.php?webtag=MOI&msg=9266.88
If by miracle yes, send it a wished radius value can be possible?
Of course i can make differently even without the InsertCircle (because you must click at each time) ;)
Array on Curve + Boolean Union made that very well! ;)
(about Array on Curve just (re) discovered that you can move the Base's & Offset's Points during the run of it! :)
29 Mar 2019   [#1416] In reply to [#1415]
No, not quite exactly - Elephant does not call a "command" in MoI its nodes call MoI's script functions which is also what commands call.
But it is possible to make a node that does the same thing that "InsertCircle" does though, by using the same script that the command uses. Basically it's packaged up differently.
29 Mar 2019   [#1417] In reply to [#1416]
Thx for explanations! :)
