Show messages:  1-17  …  1278-1297  1298-1317  1318-1337  1338-1357  1358-1377  1378-1397  1398-1417  …  1858-1859
28 Jan 2019   [#1338]
Hi All,
Here's a rather trivial example of Max's improved Remapper node being used to define tooth profiles of a cog/sprocket.
Requires Max's latest interface.js found here:
http://moi.maxsm.net/files/nodeeditor/interface.js
28 Jan 2019   [#1339] In reply to [#1338]
Hi James,
I'm getting an orange flagged output node.
None of the nodes are red
Test outputs are working elsewhere.
28 Jan 2019   [#1340] In reply to [#1339]
Hi Brian
Should have said "
". Does now!
Let me know if that does not fix issue.
28 Jan 2019   [#1341] In reply to [#1339]
Note:
Loading a node assemblage with an obsolete node, and then saving the node assemblage from the nodeeditor canvas, may result in a node assemblage which will not work, even after the updated interface.js node has been added to the nodeeditor nodes directory.
The defective node (and assemblage) may look exactly like the good node. Re-upload the node assemblage from its original source.
Thank you James.
I had not updated the interface.js on Home computer.
I'd saved your cog node, from the nodeeditor canvas, making my copy defective.
Updated interface.js.
Defective node still would not work.
Downloaded your cog node AGAIN, from your forum post.
Now the cog node works fine.
30 Jan 2019   [#1342] In reply to [#1341]
Hello Brian,
maybe caused by JSON. If the Infos for the node are not completly availiable while saving?
Have a nice day
Karsten
8 Feb 2019   [#1343]
Circles projected to sphere by stereographic projection are not closed. (Nor for conformal map to torus.)
Maybe an isclosed check, and if so a close command...
9 Feb 2019   [#1344]
The node "separateObj" seems to have a bug.
The node is blocking passage of circles and ellipses, which are closed curves, in a demo of ConformalMapT
It was fairly easy to get the conformal mapping of circles and ellipses to be closed.
9 Feb 2019   [#1345] In reply to [#1344]
The Separate factory only produces output for curves which can be separated.
The separate node needs to be altered, to pass on closed curves which are made up of only one segment, (including elementary circles and ellipses, etc.)
Closed polygons should be separated for the conformal mapping. (and stereo project?)
So test for isClosed, and also check for crv.getSubObjects().length ==1.
Is there a test to tell when a curve can be separated?
EDIT: Michaels previous answer from: https://moi3d.com/forum/index.php?webtag=MOI&msg=8818.8
"The segments of a curve are returned by the getSubObjects() method which is available on every object type in MoI. A curve always has at least one segment. To see if it's made up of multiple segments you could do crv.getSubObjects().length > 1."
Message 7777.1346 was deleted
13 Feb 2019   [#1347] In reply to [#1345]
After study of Karsten and James code from last December, here is my modification of the
"Separate" node. The code belongs in the objects2.js file of nodeeditor.
    function separateObj()
        this.addInput("In", "objectlist");
        this.addOutput("Out", "objectlist");
    separateObj.title = "separateObj";
    separateObj.desc = "separateObj";
    separateObj.prototype.onExecute = function ()
		var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
        var out = moi.geometryDatabase.createObjectList();
        if (inObj.length > 0)
            out = factory('separate', inObj); // Segments of Multi Subsegment curves.
        	for ( var i = 0; i < inObj.length; i++)
				if ( inObj.item(i).getSubObjects().length === 1)
					out.addObject(inObj.item(i)); // Single SubSegment curves.
        this.setOutputData(0, out);
    LiteGraph.registerNodeType("Objects2/separateObj", separateObj);
I think that the problem is that the Separate factory only works on geometry objects in the geometry database.
Separate will work on the InObj array of objects, as ONE entity, but not on each curve item in the array, (without more programming).
The above code outputs, to out_slot, the results of the Separate factory, consisting of the segments of curves with more than one sub_segment.
Each inObj object in the input slot is then tested to see if it has only one sub_segment, and if so, said curve is added to the output out_slot.
(This likely does change the order of the curves.)
The conformal mapping is now working well with various input curves. I'm back to Normals...
15 Feb 2019   [#1348]
is there a way of producing an isect node or a way of extracting the edges from the surface I have produced using
the intersection node.
Barry
15 Feb 2019   [#1349] In reply to [#1348]
Hello Barry,
objects2\extractEdges
objects2\intersectObj
Have a nice day
Karsten
15 Feb 2019   [#1350] In reply to [#1349]
Hi Karsten,
your faster than Usain Bolt.
Many thanks
Barry
15 Feb 2019   [#1351]
One of these days, an updated set of extension nodes, which can be found:-), would be nice.
I'm still doing some very minor "tweeking" on a few nodes...
16 Feb 2019   [#1352]
Hi All,
I've done a psy-code-lic little gyro to trip out to.
(with extra degree of freedom to anim below)
Bigger version at https://www.instagram.com/nodeology/
Haves a great weekend
17 Feb 2019   [#1353] In reply to [#1352]
Hello James,
That's a really cool effect, with only a few nodes - more or less. Good to see you are back!
Have a nice day
Karsten
17 Feb 2019   [#1354]
What I really need is a heated mouse, or a heated mouse box :-)
Maybe a mini heat pad...
Maybe the Gyro node could be modified to take as input "Get by Style" node, or similar node?
Message 7777.1355 was deleted
26 Feb 2019   [#1356]
Does it possible to make this sort of thing with Elephant ?
A bridge between 2 faces with a sort of variable adaptaion?
(and of course if the 2 faces are different that will be a must! !)
26 Feb 2019   [#1357] In reply to [#1356]
Hello Pilou,
no it's not possible. I've started some subD nodes in the past, but they are all outdated and dosen't work at the moment.
Furthermore the node Editor has not the Level of interaction like such a software.
Have a nice day
Karsten
