Show messages:  1-20  …  1241-1260  1261-1280  1281-1300  1301-1320  1321-1340  1341-1360  1361-1380  …  1841-1859
Message 7777.1301 was deleted
3 Dec 2018   [#1302]
Hi All,
I have for some time had small image attached as my desktop background image,
so I decided to model it parametrically in NE. See result below
At first glance it seem very simple, & well it is, but the pertinent issue is that for
facets to remain planar the major peak meeting of 6 faces must move opposite and
relative to the minor peak meeting of 3 faces. see .nod file attached
3 Dec 2018   [#1303] In reply to [#1302]
Looks like desert dunes viewed from the sky!
Cool!
Message 7777.1304 was deleted
5 Dec 2018   [#1305] In reply to [#1304]
Lapis-Lazuli! :)
5 Dec 2018   [#1306] In reply to [#1305]
@Pilou: "Lapis-Lazuli! :)"
LOL :) LOL :)
5 Dec 2018   [#1307] In reply to [#1304]
James...you and "speedy (AL2000)" are the best on Node Editor!!
M-A-S-T-E-R-P-I-E-C-E!!!
6 Dec 2018   [#1308]
Hi Friends
An holed egg rotating on an imaginary and unlikely axis .....
file and picture at this link:
http://www.mediafire.com/file/vovvdpidqxyockt/Holed_Egg_Rotation.zip/file
Have a nice evenig to all
alberto
7 Dec 2018   [#1309]
Hi All,
Just some instagram eye candy
(NE of course)
Have a great weekend
8 Dec 2018   [#1310] In reply to [#1309]
Super cool!
10 Dec 2018   [#1311]
Hello Friends
Lips ......
sometimes it's nice to follow your imagination ,
an image a perfume a memory can
connect worlds,and areas, apparently distant......
Those interested as the usual find this link:
http://www.mediafire.com/file/0zl8144l6703b55/Lips.zip/file
files and images
Have a nice start week at all
alberto
10 Dec 2018   [#1312] In reply to [#1309]
Hello James,
very cool -Reminds me of Richard Deacon.
A nice day to all
Karsten
Message 7777.1313 was deleted
14 Dec 2018   [#1314]
Hello Friends ,
today an exercise of tension and relaxation of the surfaces, obtained on the faces,
performed in a basic Icosahedron-
Files and images at this link:
http://www.mediafire.com/file/ga1znig2hhg07og/Inflate_Icosahedron.zip/file
Have a nice Week End to all
al
17 Dec 2018   [#1315]
Hi Friends
the repetition of structure with base
arc, rotated and scaled, can produce
an effect of considerable depth ....
files and images at this link :
http://www.mediafire.com/file/7d1jyywj4oxfpkv/VertigoArcs.zip/file
al
18 Dec 2018   [#1316]
Hi Friends ,
since I have not installed yet
the last Beta V4 x Moi,
and that the James's Shell command I do not have the possibility
to experiment it, I wondered if it could work
also for jointed Polysurfaces, quite complex
like the one resulting from my exercise squeezer .....
File and images at this link:
http://www.mediafire.com/file/qhu4emqt612vk1g/Squeezer.zip/file
attached a screnshoot of shell and fillet made in Catia (preview result for this modeler) ,
importing the stp file from the Nodeeditor ...
But if any of you can do it,
I'd be curious to know if you can solidify with shell in Nodeeditor
Have nice day
alberto
18 Dec 2018   [#1317] In reply to [#1316]
Hello Al,
shell has a bug - I will have a look the next days.
Have a nice day
Karten
18 Dec 2018   [#1318]
Hello Karsten
As usual, very kind and very helpful
thank you
I will wait to see the result...
Have a nice evening
al
18 Dec 2018   [#1319] In reply to [#1318]
Hi Al,
Did you try baking out model (clicking "Apply" button on NE Nav Bar)
from your NE setup? It also, cannot be shelled with manual "Shell" tool.
The model as it is constructed, is beyond the limits of Moi's geometry
tolerances for shell function to operate as expected.
It looks cool, though to get it to shell will require alternative approach.
(perhaps slicing into stepped curves for lofting prior to shell operation)
Good Luck!
Hi Karsten,
It would be great if you could have a look at shell node.
It generally works in "Normal" mode, but I could not get "Centerline" &
"flip" options to work, so I abandoned multi-mode, but it would be good
to have the options.
I've attached construct2.js with latest version
Have a nice day
23 Dec 2018   [#1320] In reply to [#1318]
Hello Al, Hello James,
please test the following code for the shell command:
    // Shell
function Shell()
	this.addInput("Surfaces","objectlist");
    this.addInput("Thickness","numarray");
	this.addOutput("Out","objectlist");
    this.properties = { mode:["Long","Long","Short"], thickness:[1], direction:["Normal","Normal","Flip","Centerline"] };
Shell.title = "Shell";
Shell.desc = "Shell";
Shell.prototype.onExecute = function()
    var surfaces = this.getInputData(0, moi.geometryDatabase.createObjectList());
	var data = this.processInOut(this.properties.mode[0], this.multiProcess, null, this.properties.thickness);
	this.properties.thickness = data.inputs[1];
	this.setOutputData(0, data.outputs[0]);
Shell.prototype.multiProcess = function(s, t)
	return [factory('shell', s, t, this.properties.direction[0])];
LiteGraph.registerNodeType("Construct2/Shell", Shell);
@James: Please test the code first, correct the construct2.js file and post/replace it. The problem was, that you had a look in the sometimes outdated API-Documentation - it's always a good idea to look also in Michaels code under the command folder.
A nice day to all
Karsten
