1185-1204
1205-1224
1225-1244
1245-1264
1265-1284
1285-1304
1305-1324
1845-1859
Hello James,
I can't test or Experiment with the code at the Moment, but I'm not sure that the curves are already members of the database.
Have a nice day
Karsten
Karsten's comment reminded me of Michael's help in the chain script, back in 2013, related to using a circle in a sweep:
// Next line is needed for sweep to work, per MG.
moi.geometryDatabase.addObject( circle );
(For what it is worth...)
Hi James, yeah like Karsten and Brian write above selectAll() will only get the objects if they are in the geometry database and not if they are "loose" objects.
Hi All,
Well, I have not manage to get "extractPt" node to work.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1248
After repeated failed attempts, I was feeling a little disheartened; and really needed a win, so I returned to a node I was confident I could solve.
So please find attached new arraysExt.js inclusive of new "reRange" node (shown in red) which performs an identical function to my "reMAPrange" macro (see output arrays X & Y in image).
There are a lot of applications for remapping the differential domain of an array, so it is deserving of a dedicated node rather than a macro.
A great weekend to all,
UPDATED:
ArrayExt.js has been moved to here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1251
I have also included a couple of simple utility nodes: "arrayRev" which reverses the order of an num array & "arraySort" which sorts an array into ascending order. see below
Hi all.
It was. Just another version of an unusual door.
Vladimir.
Hi Vladimir,
Great stuff! Very elegantly done.
You'll find playing in NodeEditor is fun & quite addictive.
I look forward to seeing more from you in the future :)
Hi All,
I have also included in ArrayExt.js a full* set of logic gates(based on Max's "Compare" node) :
AND(a,b)
OR(a,b)
NAND(a,b)
NOR(a,b)
XOR(a,b)
XNOR(a,b)
They perform boolean logic and hence are made to operate on 1 (true) & 0 (false) inputs,
however any number greater than 0 will be interpreted as a 1 and any number not will be interpreted as 0.
*There is no distinct NOT gate, however either NAND or NOR gates will perform this function by wiring input (whether 1 or 0) into both inputs.
These node options would allow the simulation of electronic circuitry, if one was so inclined.
Other than that they may be utilised for testing certain conditions to trigger events.
UPDATED: New ArrayExt.js attached with bug fix
Hello friends
I want to share this exercise with you
referring to the Brainstorming Confluence Park Pavillon
from the site _ Parametric House.com _
I recreated everything with EI and I added the Flooring ...
The compositions are two enough to properly switch
files and images at this link:
http://www.mediafire.com/file/7e6gshqle7qdrsv/Confluence_Park.zip/file
Have a nice evenig to all
al
Ps- James , nice work with the new Array Ext ,
congratulations.....
Hello James.
Thank you for your feedback and your contribution to the common cause.
It's really fun to do.
Vladimir.
Hi All,
Continued experimentation with interwoven patterns on surfaces. (nod file attached)
PS. Michael thanks for the V4 update. Everything is working great!
Knurl on diameter
Hi Friends
a simple umbrella .....
that you can close and open
Those interested find this link:
http://www.mediafire.com/file/rlo8fk7jcy6z69g/Umbrella.zip/file
images and files
Have a great weekend everyone
al
Hi All,
I have included a new "Shell" node in the attached construct2.js
ATM shell offset is parametric but only in normal direction. Flipping the direction is easily achieved by pairing with "Flip" node (also included)
At a later date, I will see if I can add "centreline" mode, but for now it suits my purposes.
By way of demonstration, I applied shelling to nod file previously posted (with coarser pattern and no subd smoothing) . Please also find attached.
UPDATED: another simple example of shell node attached
Hi All,
I have updated construct2.js to include additional new "Extend" node which performs analogous to "Constuct/Extend" tool: extending a curve to meet a boundary curve or surface.
Good morning James
excellent work with the New Extension Construct2
I have a problem, as you will see from the screnshot , opening your files
shell, I get an error message .......
Does it depend on some awkward setting in my program?
I simply replaced it in the UI / Nodeeditor folder
your new script to replace the existing one
image at this link:
http://www.mediafire.com/file/49654g68o20zgcf/Shell-problem.jpg/file
Thanks in advance
al
Hi All,
Al (Speedy 2000) has drawn my attention to the fact that shell node only works in V4.
I will endeavour to fix this issue, but it may be a while.
All the best to everyone,
Hello James,
please try this code. It seems there is sometimes a timing problem with the copy/paste stuff. Very untested.
// extractPts
function extractPts()
this.addInput("In","objectlist");
this.addOutput("ptarray", "pointarray");
extractPts.title = "extractPts";
extractPts.desc = "extractPts";
extractPts.prototype.onExecute = function()
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
var output = moi.geometryDatabase.createObjectList();
var selPts = moi.geometryDatabase.createObjectList();
var originXYZ = moi.VectorMath.createPoint(0, 0, 0);
var temp = moi.geometryDatabase.createObjectList();
var pts = new pointArray(false);
moi.geometryDatabase.selectAll();
var existings=moi.geometryDatabase.getSelectedObjects(); //Locking the database objects
moi.geometryDatabase.deselectAll();
if (inObj.length > 0 )
{ var tempname=getUID(6);
for(var i=0;i<inObj.length;i++){temp.addObject(inObj.item(i));temp.item(i).name=tempname;};
moi.geometryDatabase.addObjects(temp);
temp.setProperty('showPoints', 1);
temp.setProperty('selected', 0);
existings.setProperty('selected', 0);
moi.geometryDatabase.copyToClipboardCommand(temp);
moi.geometryDatabase.pasteFromClipboard();
//setTimeout( doNothing, 500);
selPts=moi.geometryDatabase.getSelectedObjects();
for(var i=0;i<selPts.length;i++)pts.pushPoint(selPts.item(i).pt);
if(selPts.length>0)output = factory('copy',selPts,originXYZ,originXYZ,true);
moi.geometryDatabase.selectNamed(tempname);
temp=moi.geometryDatabase.getSelectedObjects();
var delfac = moi.command.createFactory( 'delete' );
delfac.setInput( 0, temp );
delfac.commit();
delfac.cancel();
existings=moi.geometryDatabase.createObjectList();
this.setOutputData(1, pts);
LiteGraph.registerNodeType("Objects2/extractPts", extractPts);
Have a nice day
Karsten
p.s.: For V4 Michael will give us some new features in the API that will make a lot of things easier.
Message 7777.1262 was deleted
Thanks Karsten,
Work perfectly....I wish I had your skills. You're a champion!
Thanks again
Hi Karsten
this morning I saw a bit of light at the bottom
to the tunnel ..... I managed to insert your script
extrPts in Object2 -Alleluja
it works great, even with the V3 ,
you are a GREAT , and believe me ,
your "forced" absence has been very heavy
have a nice day
al
Ps:
Courage;
We say ... dead a pope it does another one
1185-1204
1205-1224
1225-1244
1245-1264
1265-1284
1285-1304
1305-1324
1845-1859
