1111-1130
1131-1150
1151-1170
1171-1190
1191-1210
1211-1230
1231-1250
1851-1859
Hi Karsten ,
How are you?
I hope everything is OK-
The new Extension import, just posted , is fine
at least I think, if Barry's goal was to create a Heklix
with variable radius .... thanks for your intervention ...
but I believe that if I post some examples
from which we can better understand how to manage
the points imported ... would be the maximum ..
thanks again , and have a nice day
al
Hi Karsten,
once again thanks for your help all's working well.
Barry
Hi All
an exercise, using M_Helix and the new M_1Blend,
revised and I believe improved ...
the file and some images at this link:
http://www.mediafire.com/file/dsrqyaj65okasi3/Bulb.zip/file
Have a nice day to all
al
Message 7777.1174 was deleted
Super AMAZING creation!!!
This is the beauty of math :)
James you're a "math painter"!
P.s. now only a background music is missing!
After that we could use Moi like a DJ in a dance floor :)
can someone help I am trying to get the inverse of sine for a calc within the node editor.
Is there away to do this to get the angle in degrees or radians ?
Barry
Got it used asin() function
Hi Karsten,
Your M_PathArray node is extremely useful, however I have a thought of how it may be be made even more powerful.
If the input is a single decimal number < 1 (e.g. 0.6 as shown in attached image)
then a point would be positioned at that percentage of the curve length.
I know that something similar can now be achieve with use 0 & 1 concatenated to either side of the number; but this becomes a problem with multiprocessing multiple curves with input numarray parametrically determined by say proximity to attractor point.
Hopefully, this makes sense.
Hi James, I agree with you, it would be extremely useful to be able to use
a single decimal or a decimal progression,
leaving out the concatenate with the No. 1
I hope Karsten can improve
the functionality of this Node, I do not think it's too difficult for him ...
at least I hope.....
Have a nice day
al
HI to All,
I send you Macro_1Gear
for creating toothed wheels...
file at this link :
http://www.mediafire.com/file/hitnvsas047hfsq/-GEAR.zip/file
good depth to everyone
best
al
Message 7777.1181 was deleted
Hi All,
Another experiment with performative screening.
WOW!!! Wonderful!
Hi All,
created this nod after reading this thread
http://moi3d.com/forum/index.php?webtag=MOI&msg=8986.1
Having originally done the calcs on a spreadsheet I wanted to see if it could all be done with the node editor and it's
a good way for me to learn how some of the nodes work ( still lot to learn )
I have been working on 2 options the first being the one posted which adds the helix to a core this gives the slot bottom a curved shape.
Option 2 which subtracts the helix to get the slot thus the slot bottom will be flat more like it would be machined.
Barry
.png)
Globoid Cam.nod
Hi All,
GEMERATOR: A fun little macro utility
Have a great weekend!
cool ! thanks
a test of this node with a keyshot render
Beautiful render! Thanks
Very very nice!
Message 7777.1190 was deleted
1111-1130
1131-1150
1151-1170
1171-1190
1191-1210
1211-1230
1231-1250
1851-1859
