Show messages:  1-7  …  1068-1087  1088-1107  1108-1127  1128-1147  1148-1167  1168-1187  1188-1207  …  1848-1859
26 Jun 2018   [#1128] In reply to [#1127]
"Hello - is it this you looking for - I can see it in your eyes - I can see it in your smile ..."
Not direct the closest distance, but more general. It is the project curve factory and it works also for points to curves. Please test and study. The direction mode takes the x-axis of the frame input. For closestpt it is not necessary.
        function Project()
	this.addInput("Objects","objectlist");
        this.addInput("Target","objectlist");
	this.addInput("Frame","pointarray");
	this.addOutput("Out","objectlist");
	this.properties = {ProjectMode:["closestpt","closestpt","direction"]};
Project.title = "Project";
Project.desc = "Project";
Project.prototype.onExecute = function()
        var obj = this.getInputData(0, moi.geometryDatabase.createObjectList());
        var target = this.getInputData(1, moi.geometryDatabase.createObjectList());
        var f = this.getInputData(2, new pointArray(true));
        var output = moi.geometryDatabase.createObjectList();
	//0 Object
	//1 Objects
	//2 projectmode
	//3 basePt
	//4 TargetPt
	//5 delete inputs
	//6 plane
	//7
	var frame = f.getFrame();
	var pFac= moi.command.createFactory( 'project' );
	pFac.setInput( 0, obj );
	pFac.setInput( 1, target );
	pFac.setDefaultDirection();
	pFac.setInput( 2,this.properties.ProjectMode[0] );
	pFac.setInput( 3, frame.origin );
	pFac.setInput(4,frame.evaluate( 1, 0, 0 ) );
	pFac.update();
        output = pFac.calculate();
	pFac.cancel();
        this.setOutputData(0, output);
LiteGraph.registerNodeType("Construct2/Project", Project);
A nice day to all
Karsten
project.nod
26 Jun 2018   [#1129] In reply to [#1128]
Hi Karsten,
Well there was hardly any time for impatience, you've done it....and it is just perfect.
Brilliant stuff as always
PS This is an application where reMapRange is useful: allowing greater controls of min/max radii and extrude height.
26 Jun 2018   [#1130] In reply to [#1128]
Karsten,
Your new node is a godsend.....which makes you a....?
Here, a ptArray is deformed with a curve, which makes for a delightfully simple way of generating a parametric surface.
PS Karsten, if you are now open for suggestions; this is a big one: it requires 2 nodes to work in unison. Firstly a image import node and secondly a node that converts greyscale values to numArray (à la Max's heightMap script). These num values may be z value for a ptArray, however they may alternatively be radii of circles (Che) or scale values or whatever............ Could Be Good!
This not even a request, just something to get you excited about. In the meantime there is no end of fun possible with your latest node.
Below image: using circle attractor
27 Jun 2018   [#1131]
Hi Karsten and James
One thing friends ...
the js file for the NE (Project)
where can I find it...
you've already posted it, and I missed ...
thank you
al
27 Jun 2018   [#1132] In reply to [#1131]
Hello Alberto,
>> the js file for the NE (Project)... where can I find it..<<
Copy the code (within grey rectangle) @
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1128
and paste into the bottom, but just above })(); of Construct2.js code.
Directory:
C:\Users\< user name>
\AppData\Roaming\Moi\nodeeditor\nodes\extensions\construct2.js
Hope this helps
PS If you have not already done so, also paste in code for railRevolve and Network.
Code found in posts below:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1085
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1086
27 Jun 2018   [#1133]
Hi James
I think I'm wrong
I'm in difficulty with the copy and paste operations
that step by step you showed me .. I think I did not understand well
how and where to paste the script ...
can not you send me (construct2.js) already updated with it
script project inserted in .....
like you did with Network and Rail revolve,
then I'll put it in the usual directory ...
Thank you
alberto
27 Jun 2018   [#1134] In reply to [#1133]
Hi Alberto
Please find attached.
Good Luck
27 Jun 2018   [#1135]
Many ,Many Thanks my Friends
have a nice day
al
27 Jun 2018   [#1136]
Hi All,
So here's ya 70's Prog Rock album cover right here
Click on CLICK ME. Click again to get new result......repeat.
28 Jun 2018   [#1137] In reply to [#1136]
So cool!!
28 Jun 2018   [#1138]
Hi Karsten,James and all Friends
A gold ring with a decoration Lapislazzuli paint;
a gift, which could be good for any woman,
mother, wife, friend, partner, lover, do you....
Don't make Jokes ....
the file at this link:
http://www.mediafire.com/file/pfrr7tzwz4crozg/Diamond_Ring.zip/file
have a nice day to all
alberto
28 Jun 2018   [#1139] In reply to [#1138]
Hello Alberto,
Wow, I was not expecting that...really amazing animation
Keep up the great work
28 Jun 2018   [#1140]
Good Morning James ,
I have to say the same thing for you ,
sincerely the Voxel file is "unsettling"
(in italiano , direi spiazzante)
Bravo, and original .....
have a nice day
ciao
al
28 Jun 2018   [#1141] In reply to [#1129]
Hi James,
I have downloaded your remap nod file but getting this error ( ReferenceError: Can't find variable: magnitude)
So not sure if I have all the latest additions to extensions. (I have added the one's posted by Karsten)
Any Idea's what I'm missing.
Barry
28 Jun 2018   [#1142] In reply to [#1141]
Hi Barry,
I just reviewed the reMapNode.nod file :
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1114
and there is no recent extension nodes that you might be missing. Though, I have only tried it with MoiV4, perhaps it has backward compatibility issues.
I'm sorry that I cannot more helpful
28 Jun 2018   [#1143] In reply to [#1141]
Hello Barry,
please check if basicfunctions. js is missing in extensions/libs.
Have a nice day
Karsten
28 Jun 2018   [#1144] In reply to [#1143]
Hi Karsten/James,
correct the basicfunctions.js was missing from my node editor version in Moi V4
All's working well again.
Many thanks.
Barry
29 Jun 2018   [#1145]
Hi Friends ,
a Torciglione whose execution
it is entrusted to the Macro Helix, and to the subsequent adaptation
to a reference curve-
As usual, the file at this link:
http://www.mediafire.com/file/s9mz17a6mp9z11x/TORCIGLIONE.rar/file
Have a nice Week-end to all
alberto
Message 7777.1146 was deleted
1 Jul 2018   [#1147]
Ocean's waves! :)
