993-1012
1013-1032
1033-1052
1053-1072
1073-1092
1093-1112
1113-1132
1853-1859
Hi Friends
I want to share with you my research in the field of "OpticalArt"
exploiting the potential of the Quartz node (truly amazing tool....
honor to Max)
A particular double propeller, as opposed moving creates the effect
looked for...
The propeller can be either a Polysurf or a Subdsurf
the file, for those interested at this link:
http://www.mediafire.com/file/3ply0jgng7xveb1/NewPropeller2.rar/file
Have a nice day to all
alberto
Message 7777.1054 was deleted
Hi All,
A new Node Editor derived pattern experiment: Equilateral Triangular grid with scale of individual triangles determined by 3 attractors.
Oh & Thanks Michael for the new update
Hi James
have you read my last message in this thread ?
Thanks a lot
Hi Finema,
>> have you read my last message in this thread ? <<.
Yes, but if I remember correctly an earlier version was working for you.
I'm sorry I didn't respond. I was developing a hopefully foolproof method
but am first awaiting for another's input. Stray tuned.
Have a great weekend
Hi James,
yes the V6 work correctly.
Thanks a lot and have a great WE too.
Hello James,
would you please check this code:
// RemoveDup
function RemoveDup()
this.addInput("In", "objectlist");
this.addInput("Tolerance", "numarray");
this.addOutput("Out", "objectlist");
this.properties = {Tolerance: [0.005]};
RemoveDup.title = "RemoveDupCrv";
RemoveDup.desc = "RemoveDupCrv";
RemoveDup.prototype.onExecute = function ()
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
this.properties.Tolerance = this.getInputData(1, this.properties.Tolerance);
var output = moi.geometryDatabase.createObjectList();
var temp = moi.geometryDatabase.createObjectList();
if (inObj.length > 0) {
var tempname = getUID(6);
for (var i = 0; i < inObj.length; i++)
inObj.item(i).name = tempname;
moi.geometryDatabase.addObjects(inObj);
var fac = moi.command.createFactory('removeduplicates');
fac.setInput(0, inObj);
fac.setInput(1, this.properties.Tolerance[0]);
inObj = moi.geometryDatabase.createObjectList();
fac.commit();
moi.geometryDatabase.selectNamed(tempname);
temp = moi.geometryDatabase.getSelectedObjects();
var originXYZ = moi.VectorMath.createPoint(0, 0, 0); //Helppoint for a identical copy
output = factory('copy', temp, originXYZ, originXYZ, true);
var delfac = moi.command.createFactory('delete');
delfac.setInput(0, temp);
delfac.commit();
this.setOutputData(0, output);
LiteGraph.registerNodeType("Objects2/RemoveDupCrv", RemoveDup);
Have a nice day
Karsten
Hi Karsten, if you put that inside of a <code></code> block here in the forum it should preserve the spacing/tab/indenting.
Otherwise HTML has the tendency to collapse white space.
Hello Michael,
thank you for the tip! Done:-)
I'm not familar with this stuff (CCS, HTML, PHP, ...)!
Have a nice day
Karsten
Hi Karsten
Thank you for the code. It does exactly what I wanted it to do, so cheers.
I cannot express how grateful I am for your efforts on my behalf.
Forever in your debt,
Thanks James
Hello James,
the removeduplicates factory uses a tolerance value to check if a curve is identical. I set the default value to the limit, what for MoI is identical in general (threshold 0.005 - someone should disagree, if I'm wrong). If you set it to 0, the factory can't find identical objects and the node gives everything back. The factory works only for curves and not for points, faces .... -please try the attached node file. If you need something for points as well - we have to program it.
Have a nice day
Karsten
p.s.: In my installation your example shows 3 points as result independent from the tolerance? What version of MoI you use 4.0Beta?
remdupcrv.nod
Hi Karsten,
Sorry for the confusion, my last example was different than my intention.
I thought the 3 points were all at the origin, and so I have removed the
comments & attachments from my last post so as to not perpetuate the
confusion. I should have double checked my work.
The node file is perfect as is.
Thanks again
PS I am using v4
Good to hear. I've tested it with V3.0 - so there were some doubts.
Hi All
More pattern experiments: now stretcher pattern mapped to surface; remaining planar.
Hello James!
Actually I don't have time to follow the Project Elephant "saga" but from time to time, when I can take a look at this thread, I see that you and the other guys are creating amazing stuff!
My congrats!!
Very interesting James !
Hi Friends
Scrolling through the M_RectangularGrid
posted different time ago, I noticed
that everything could be greatly lightened,
in terms of weight of the resulting file ....
how many interested people find this link:
http://www.mediafire.com/file/fulg3v4ektwlp84/M-RectangularGrid.nod/file
the updated Macro
Good Work everyone
alberto
Hi Friends
I want to share this new macro
multiple radii Pipe ..
file at this link:
http://www.mediafire.com/file/56b5264atbkm8cp/M_mradiiPipe.zip/file
alberto
Hi All,
Batswing Gyroid wrapped with simple embossed grid
Hello James, Hello Al,
Looks like you're having fun. It makes me happy to see that you still use the NE and go to the limit of what is possible. Very impressive.
Have a nice day
Karsten
993-1012
1013-1032
1033-1052
1053-1072
1073-1092
1093-1112
1113-1132
1853-1859
