990-1009
1010-1029
1030-1049
1050-1069
1070-1089
1090-1109
1110-1129
1850-1859
James,
With this version (7) there is a deformation
see my screenshot
Also,
With V6 et V7 :
1• I apply the node on my model
2• i quit MoI
3• ropen the 3dm file
4• apply the node > Error
5• i must redraw my model (Revolve)
6• ican now apply the nodeV6 or V7
thanks
Hi Karsten,
I have attempted to create a node based on RemoveDuplicates script.
however without success. Below is my attempt:
// RemoveDup
function RemoveDup()
this.addInput("In","objectlist");
RemoveDup.title = "RemoveDup";
RemoveDup.desc = "RemoveDup";
RemoveDup.prototype.onExecute = function()
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
var output = moi.geometryDatabase.createObjectList();
if ( inObj.length> 0 ) output = factory ('removeduplicates', inObj);
LiteGraph.registerNodeType("Objects2/RemoveDup", RemoveDup);
Now, only if this would be a welcome distraction for you,
I would appreciate if you could steer me right.
I have so missed your contributions to NE in your long absence.
I know you have a lot on your plate, so if this is something that
you can't turn your mind towards right now, then no worries.
Hope you're well
Hello James,
After some problems in my life or with my wife, I had to find a new orientation - I think a well known problem. Now it's getting better and better and I see the light at the end of the tunnel - I hope it's not a train;-)
To your problem:
At first: I think removeduplicate needs a second input - a tolerance value, but that won't solve the problem alone. I suspect that this factory don't give a geometry list back - it works directly to the geometry database. So we have to use a workaround - 1. write the input to the database. 2 call the factory. 3 delete the input list (otherwise the database locks removing). 4. commit the factory 5. get the left objects (singletons) back and copy them in a list. 6 delete the singletons also from the database. 7 give the list to the output.
It's only a first idea - give me some days please and I will have a closer look.
I hope you are well and remain with kind regards!
Karsten
Hi Friends
I want to share with you my research in the field of "OpticalArt"
exploiting the potential of the Quartz node (truly amazing tool....
honor to Max)
A particular double propeller, as opposed moving creates the effect
looked for...
The propeller can be either a Polysurf or a Subdsurf
the file, for those interested at this link:
http://www.mediafire.com/file/3ply0jgng7xveb1/NewPropeller2.rar/file
Have a nice day to all
alberto
Message 7777.1054 was deleted
Hi All,
A new Node Editor derived pattern experiment: Equilateral Triangular grid with scale of individual triangles determined by 3 attractors.
Oh & Thanks Michael for the new update
Hi James
have you read my last message in this thread ?
Thanks a lot
Hi Finema,
>> have you read my last message in this thread ? <<.
Yes, but if I remember correctly an earlier version was working for you.
I'm sorry I didn't respond. I was developing a hopefully foolproof method
but am first awaiting for another's input. Stray tuned.
Have a great weekend
Hi James,
yes the V6 work correctly.
Thanks a lot and have a great WE too.
Hello James,
would you please check this code:
// RemoveDup
this.addInput("In", "objectlist");
this.addInput("Tolerance", "numarray");
this.addOutput("Out", "objectlist");
this.properties = {Tolerance: [0.005]};
RemoveDup.title = "RemoveDupCrv";
RemoveDup.desc = "RemoveDupCrv";
RemoveDup.prototype.onExecute = function ()
this.properties.Tolerance = this.getInputData(1, this.properties.Tolerance);
var temp = moi.geometryDatabase.createObjectList();
if (inObj.length > 0) {
var tempname = getUID(6);
for (var i = 0; i < inObj.length; i++)
inObj.item(i).name = tempname;
moi.geometryDatabase.addObjects(inObj);
var fac = moi.command.createFactory('removeduplicates');
fac.setInput(0, inObj);
fac.setInput(1, this.properties.Tolerance[0]);
inObj = moi.geometryDatabase.createObjectList();
fac.commit();
moi.geometryDatabase.selectNamed(tempname);
temp = moi.geometryDatabase.getSelectedObjects();
var originXYZ = moi.VectorMath.createPoint(0, 0, 0); //Helppoint for a identical copy
output = factory('copy', temp, originXYZ, originXYZ, true);
var delfac = moi.command.createFactory('delete');
delfac.setInput(0, temp);
delfac.commit();
LiteGraph.registerNodeType("Objects2/RemoveDupCrv", RemoveDup);
Have a nice day
Karsten
Hi Karsten, if you put that inside of a <code></code> block here in the forum it should preserve the spacing/tab/indenting.
Otherwise HTML has the tendency to collapse white space.
Hello Michael,
thank you for the tip! Done:-)
I'm not familar with this stuff (CCS, HTML, PHP, ...)!
Have a nice day
Karsten
Hi Karsten
Thank you for the code. It does exactly what I wanted it to do, so cheers.
I cannot express how grateful I am for your efforts on my behalf.
Forever in your debt,
Thanks James
Hello James,
the removeduplicates factory uses a tolerance value to check if a curve is identical. I set the default value to the limit, what for MoI is identical in general (threshold 0.005 - someone should disagree, if I'm wrong). If you set it to 0, the factory can't find identical objects and the node gives everything back. The factory works only for curves and not for points, faces .... -please try the attached node file. If you need something for points as well - we have to program it.
Have a nice day
Karsten
p.s.: In my installation your example shows 3 points as result independent from the tolerance? What version of MoI you use 4.0Beta?
remdupcrv.nod
Hi Karsten,
Sorry for the confusion, my last example was different than my intention.
I thought the 3 points were all at the origin, and so I have removed the
comments & attachments from my last post so as to not perpetuate the
confusion. I should have double checked my work.
The node file is perfect as is.
Thanks again
PS I am using v4
Good to hear. I've tested it with V3.0 - so there were some doubts.
Hi All
More pattern experiments: now stretcher pattern mapped to surface; remaining planar.
Hello James!
Actually I don't have time to follow the Project Elephant "saga" but from time to time, when I can take a look at this thread, I see that you and the other guys are creating amazing stuff!
My congrats!!
Very interesting James !
Hi Friends
Scrolling through the M_RectangularGrid
posted different time ago, I noticed
that everything could be greatly lightened,
in terms of weight of the resulting file ....
how many interested people find this link:
http://www.mediafire.com/file/fulg3v4ektwlp84/M-RectangularGrid.nod/file
the updated Macro
Good Work everyone
alberto
990-1009
1010-1029
1030-1049
1050-1069
1070-1089
1090-1109
1110-1129
1850-1859
