Show messages:  1-17  …  978-997  998-1017  1018-1037  1038-1057  1058-1077  1078-1097  1098-1117  …  1858-1859
1 Jun 2018   [#1038] In reply to [#1037]
Alberto,
yes it's clear but i don't know what i must exactly put the getbyname node
and also, what i must delete
I'm discovering node editor, sorry
1 Jun 2018   [#1039]
Hi James
I carefully reviewed your last file, and I allowed myself to add
some steps to get a scaling on the faces for the Flow ...
I think it can be useful ---
file to this link:
http://www.mediafire.com/file/rx36d7931u1iuvu/bottleWrap4.nod/file
In any case, I have to ask you some questions;
1- why the progression for isocurve input starts from 0.0001 and not from 0 ....
2- the value 0.0001 is accepted, as ever, in some situations in which I tried to insert it, for other nodes, I could not, the value
it is not accepted .... it depends perhaps on some settings that I do not know .......
3- I saw that the added (info box) to the surface object of the flow,
then splitting the input of the value z, which means .....
grateful for your explanations
Have a nice day and good work
alberto
1 Jun 2018   [#1040]
Hi Finema
a this link:
http://www.mediafire.com/file/kqm1csr5w6b2g0o/31-05-Bottle_SimPanelingTool.zip/file
new file with object referenced
and new Flow node
only run... Good Luck
alberto
1 Jun 2018   [#1041] In reply to [#1040]
Thanks Alberto
it's Ok now
I would like to use a solid instead an half surface
1 Jun 2018   [#1042] In reply to [#1041]
Thanks a lot James and Alberto
I know it's not as Paneling Tool Rhino but this node is usefull for my work
1 Jun 2018   [#1043] In reply to [#1039]
Hi Alberto,
In answer to your questions 1& 2. It seems it is no longer necessary to commence progression with 0.001.
This a hang over from an earlier version of isoCrvs, as you can see in image below it now does it automatically,
so that's good to know.
Question 3..the info box node ascertains whether the idxSelected surface has a z dimension.
An output of 0.00 for bottle base translates as boolean false and hence breaking the circuit,
while and other dimension translates as true.
It works better with inclusion of blue nodes in attached
I have only just awoken, so I have not had a look at your file. I'll do that now,
I've had a look: Yes your added nodes could be useful, thanks for that
Have a great weekend
1 Jun 2018   [#1044] In reply to [#1043]
Hi
Why the pattern isn't similar to the model (bottle)
See my screenshots
The pattern is not perfectly following the shape of the bottle.
Message 7777.1045 was deleted
2 Jun 2018   [#1046] In reply to [#1045]
OK
Thanks James :)
2 Jun 2018   [#1047] In reply to [#1046]
Finema
The reason "pattern is not perfectly following the shape" is due to the fact that the bottle surface has been rebuilt. It fidelity of the bottle is significant, then there are work arounds. I'll get back to you
See if the attached works for you. Instead of rebuilding the bottle; it has been sliced/diced.
2 Jun 2018   [#1048] In reply to [#1047]
It's perfect now !
the script running is slower but it's great !
thanks a lot
Message 7777.1049 was deleted
2 Jun 2018   [#1050] In reply to [#1049]
James,
With this version (7) there is a deformation
see my screenshot
Also,
With V6 et V7 :
1• I apply the node on my model
2• i quit MoI
3• ropen the 3dm file
4• apply the node > Error
5• i must redraw my model (Revolve)
6• ican now apply the nodeV6 or V7
thanks
3 Jun 2018   [#1051] In reply to [#1]
Hi Karsten,
I have attempted to create a node based on RemoveDuplicates script.
however without success. Below is my attempt:
// RemoveDup
function RemoveDup()
this.addInput("In","objectlist");
this.addOutput("Out","objectlist");
RemoveDup.title = "RemoveDup";
RemoveDup.desc = "RemoveDup";
RemoveDup.prototype.onExecute = function()
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
var output = moi.geometryDatabase.createObjectList();
if ( inObj.length> 0 ) output = factory ('removeduplicates', inObj);
this.setOutputData(0, output);
LiteGraph.registerNodeType("Objects2/RemoveDup", RemoveDup);
Now, only if this would be a welcome distraction for you,
I would appreciate if you could steer me right.
I have so missed your contributions to NE in your long absence.
I know you have a lot on your plate, so if this is something that
you can't turn your mind towards right now, then no worries.
Hope you're well
3 Jun 2018   [#1052] In reply to [#1051]
Hello James,
After some problems in my life or with my wife, I had to find a new orientation - I think a well known problem. Now it's getting better and better and I see the light at the end of the tunnel - I hope it's not a train;-)
To your problem:
At first: I think removeduplicate needs a second input - a tolerance value, but that won't solve the problem alone. I suspect that this factory don't give a geometry list back - it works directly to the geometry database. So we have to use a workaround - 1. write the input to the database. 2 call the factory. 3 delete the input list (otherwise the database locks removing). 4. commit the factory 5. get the left objects (singletons) back and copy them in a list. 6 delete the singletons also from the database. 7 give the list to the output.
It's only a first idea - give me some days please and I will have a closer look.
I hope you are well and remain with kind regards!
Karsten
6 Jun 2018   [#1053]
Hi Friends
I want to share with you my research in the field of "OpticalArt"
exploiting the potential of the Quartz node (truly amazing tool....
honor to Max)
A particular double propeller, as opposed moving creates the effect
looked for...
The propeller can be either a Polysurf or a Subdsurf
the file, for those interested at this link:
http://www.mediafire.com/file/3ply0jgng7xveb1/NewPropeller2.rar/file
Have a nice day to all
alberto
Message 7777.1054 was deleted
7 Jun 2018   [#1055]
Hi All,
A new Node Editor derived pattern experiment: Equilateral Triangular grid with scale of individual triangles determined by 3 attractors.
Oh & Thanks Michael for the new update
7 Jun 2018   [#1056] In reply to [#1055]
Hi James
have you read my last message in this thread ?
Thanks a lot
7 Jun 2018   [#1057] In reply to [#1056]
Hi Finema,
>> have you read my last message in this thread ? <<.
Yes, but if I remember correctly an earlier version was working for you.
I'm sorry I didn't respond. I was developing a hopefully foolproof method
but am first awaiting for another's input. Stray tuned.
