963-982
983-1002
1003-1022
1023-1042
1043-1062
1063-1082
1083-1102
1843-1859
Hi Finema and friends
at this link:
http://www.mediafire.com/file/kqm1csr5w6b2g0o/31-05-Bottle_SimPanelingTool.zip/file
you will find the file, to adapt the object to the surface,
as you will see the approach is different from the amount that you have
posted James ... I think this also has its validity
Certainly it is not the paneling that can be achieved with
Paneling Tools- or Rhino's Morph Box (Grasshopper)
but it's always a good start for Moi-
You just have to open the file and then run it,
you will see different parameters, rows, columns, etc etc ...
change them to see how they work-
Have a nice day to all
alberto
Hi Finema,
This is an alternative simpler approach:
Click RUN
If nothing happens, click "Surface Index" switch
The target surface should be index either 0 or 1.
In the event nothing still happens, try changing "const" node values to 2 & 3
& if you desire the bottle to be shown, click "switch" to reveal
for .3dm & .nod file see:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1043
Hi Alberto,
How i can use it ?
Must i name object ?
Thanks a lot.
Thanks a lot James
It's very good
But i have an error when i want to change the bottle.
UNSUPPORTED POLYGON TYPE 15
Hi Finema
you simply have to open the file
and run ... all the data is in the file, there are not any
referenced objects
best
al
Al,
You don't join a 3dm file
I think some .js are missing in my node editor
mflowObj is red
thanks
Hi Finema,
>> error when i want to change the bottle. UNSUPPORTED POLYGON TYPE 15 << .
The issue is the indexing of the surfaces of the bottle.
I have updated my previous post with new nod file
& instructions
Hi James
That don't work for me
Nothing happen when i modify the bottle or i have message error
I have change index , quit , reopen but no way
Thanks again for your time
Finema, is the modified bottle named " bottle"?
yes
i join the 3dm file with the new bottle
thanks
It works with "surface index" switch set to 0
Did you read instruction on my earlier post?
yes i've read it
but i've tested with 2 and 3
it works with 0
thanks a lot James , it's really usefull for me to design pattern on model !!!
Hi Finema
You can Replace the mFlow node that appears in red
with original Flow node, which you find under the Trasform Tool ( Max's Tool)
just make the connections in and out
with the other nodes, as well as for actual mFlow node ...
I hope I was clear, it's easy enough
Have a nice day
alberto
Thanks Alberto
it's OK with Flow node now
This node is usefull but i need to draw the module and bottle myself on the scene.
Thanks a lot
Hi Finema
As in the example posted by James you can create the references ,
in this case the bottle and the form you want to apply, then
you have to create two nodes (get by name) and then connect them
to the rest of the nodes of my file, (eliminating the bottle and the form
built with only the nodes ...)
All clear .... I hope so
best
alberto
Alberto,
yes it's clear but i don't know what i must exactly put the getbyname node
and also, what i must delete
I'm discovering node editor, sorry
Hi James
I carefully reviewed your last file, and I allowed myself to add
some steps to get a scaling on the faces for the Flow ...
I think it can be useful ---
file to this link:
http://www.mediafire.com/file/rx36d7931u1iuvu/bottleWrap4.nod/file
In any case, I have to ask you some questions;
1- why the progression for isocurve input starts from 0.0001 and not from 0 ....
2- the value 0.0001 is accepted, as ever, in some situations in which I tried to insert it, for other nodes, I could not, the value
it is not accepted .... it depends perhaps on some settings that I do not know .......
3- I saw that the added (info box) to the surface object of the flow,
then splitting the input of the value z, which means .....
grateful for your explanations
Have a nice day and good work
alberto
Hi Finema
a this link:
new file with object referenced
and new Flow node
only run... Good Luck
alberto
Thanks Alberto
it's Ok now
I would like to use a solid instead an half surface
Thanks a lot James and Alberto
I know it's not as Paneling Tool Rhino but this node is usefull for my work
963-982
983-1002
1003-1022
1023-1042
1043-1062
1063-1082
1083-1102
1843-1859
