Full Version: BOM script
Show messages:  1-15  16-35  36-41
9 Feb   [#36] In reply to [#33]
Hi MarK,
> Do you think the script could also assemble the parts according to dimensions (regardless of the
> orientation in the model) and round the dimensions to integers as I describe in the attached image?
It would help me understand better if you could make an example file with a small number of parts set up as you describe and an example of the desired output from that.
9 Feb   [#37] In reply to [#36]
Sending... Thank you very much. Marek
test.3dm
test.csv
9 Feb   [#38] In reply to [#37]
Hi Marek, thanks for the example files. Can you please give the english translation of these column names in the .csv :
Dílec;materiál;množství;tl.;šíøka;délka
9 Feb   [#39] In reply to [#38]
OK, I'd probably rather use Moi terminology:
Dílec - Objects
Material - Styles
Množství - Quantity
Tloušťka - Thickness
šířka - Width
délka - Length
10 Feb   [#40] In reply to [#33]
Hi Marek, please try the attached version. It should list the dimensions from smallest to largest and round to whole numbers.
cutlist_marek.js
11 Feb   [#41] In reply to [#40]
Thank you very much! I will test it and let you know. Mark
