7-26
27-41
Hi Pilou, do you only get the error with the script which you've edited? Please try the original script from above and see if that works ok. If so, please post your edited French version maybe there's something wrong with one of your changes.
So here the file saved as UTF-8
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/cutlistfr.js
and the 3Dm
https://3938813-177191628195407167.preview.editmysite.com/uploads/3/9/3/8/3938813/cutlistfr.3dm
Hi Pilou, for .js files to contain unicode in MoI v3 only UTF-16 with byte order mark is currently supported. This will be tuned up in v4 so that UTF-8 is supported too.
So I will try with Notepad ++ :)
so NotePad ++ codes as UTf16 LE (what is LE / BE ?)
So Js for Moi works!
then Notepad export csv as UTF 8 !:)
So accents will all taken in count for Excel (because accents UTF 16 don't works with excel! )
What a gymnastic! :)
Accents are a calamity! :)
Now success!
Version Vf
http://moiscript.weebly.com/cutlist.html
> (what is LE / BE ?)
That stands for "Little Endian" or "Big Endian", which are ways that different computers order bytes within longer integer values:
https://en.wikipedia.org/wiki/Endianness . You want the "Little Endian" one.
For MoI v4 I can add in an option for script text file creation to write the Byte Order Mark at the start of the .csv file so you wouldn't have to do the extra step there. You can also probably use the Data > From text file option in Excel which will let you tell it that it's a comma delimited UTF-8 file without having to send it through Notepad++ .
THx for the infos!
Amazing complexity!
Hi Michael, this is more than I expected... Do you think the script could also assemble the parts according to dimensions (regardless of the orientation in the model) and round the dimensions to integers as I describe in the attached image?
When you have even an image of your results! (like the above)
I believe you can ask anything you want to any Ai...
This free one is very cool for this sort of thing...just give it the good question(s) ! :)
That avoid some coding! :)
https://gemini.google.com/app
Yesterday I spent 4 hours testing her "final, absolutely perfect versions". :-) Then I gave up and wrote this post... :-(
Hi MarK,
It would help me understand better if you could make an example file with a small number of parts set up as you describe and an example of the desired output from that.
Sending... Thank you very much. Marek
test.3dm
test.csv
Hi Marek, thanks for the example files. Can you please give the english translation of these column names in the .csv :
Dílec;materiál;množství;tl.;šíøka;délka
OK, I'd probably rather use Moi terminology:
Dílec - Objects
Material - Styles
Množství - Quantity
Tloušťka - Thickness
šířka - Width
délka - Length
Hi Marek, please try the attached version. It should list the dimensions from smallest to largest and round to whole numbers.
cutlist_marek.js
Thank you very much! I will test it and let you know. Mark
7-26
27-41
