755-774
775-794
795-814
815-834
835-854
855-874
875-894
895-912
Hi Max,
How are you going with finalisation of NE v1.0 release?
I have a proposal for an extension to switch node
that you might consider including.
It is pretty self explanatory; allowing branching between 2 paths.
& would be useful for checking outputs and readings at various
critical points for debugging purposes.
I know that there is a work around with split + 0-1 knob,
or alternatively, split + switch + 2x const, but they're cumbersome.
All the best,
Keep up the good work
Hi James,
I didn't write a line of code since 1.0 rc3 release. Sorry, have no time at all.
Good idea. I'll add it to Switch node.
Hi Max,
Thanks for building this awesome tool!
I'm having a problem with node editor v 1.0 (rc3). It appears that Macros aren't working for me at all (either in MoI 3 or 4 beta). The following error pops up if I select Macro (the error looks identical in 3 and 4 beta, although I can only cut and paste the error in 4 beta):
Script error
TypeError: undefined is not an object (evaluating 'document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace')
moi://ui/nodeeditorv10rc3/core/main.js line 4404
4400: var entries = {};
4401: for(i=0; i<values.length; i++) { if ( values[i] ) entries[i] = { value: ">"+values[i], content: lang.getTranslation(values[i]), is_menu: false }; }
4402:
4403: var dir = (moi.filesystem.getAppDataDir)?moi.filesystem.getAppDataDir:moi.filesystem.getProcessDir;
4404: >> var path = dir()+document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace(/\//g,"\\")+"macros\\";
4405:
4406: if ( moi.filesystem.dirExists(path) )
4407: {
4408: var files = getFiles(path);
Any ideas on what I am doing wrong?
-FDP
Hi FDP,
I'll check it this weekend. I have no idea at the moment.
Hi Max,
Any chance to look into that error? I'm sorry to be bugging you with this - understand if you are super busy!
-FDP
Hello FDP,
could you make a zip of your nodeeditor Folder and post it - maybe something is wrong with it. As a Workaround I would Switch back to an older Version. Worth a try.
Have a nice day
Karsten
Thanks!
Attached the zip. This is from my: 'Program Files/MoI 4.0 beta Jun-6-2018/ui' folder (64bit).
nodeeditorv10rc3.zip
Hi FDP,
not sure if this is your problem but you are missing the basicfunctions.js
I have attached a copy that you need to put in the libs folder that is within the node extensions folder.
Hope this helps.
Barry
basicFunctions.js
Hello FDP,
it seems that an Installation und /ui/ Folder doesn't work. I think you have to install under appdata/Roaming/moi/.
Have a link to this post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.767
Maybe Max can help hopefully.
Have a nice day
Karsten
Hi Max/Karsten & others who may be interested.
There is a component (widget) in grasshopper called "GraphMapper" that remaps a numerical array to values under a user defined curve. see below
I imagine that coding for such a node would be quite difficult, however I propose a more limited node that may be more achievable (below image)
In essence it would take a linear progression of number (say point distances from an attractor) and shift them to ease in and out.
Your thoughts?
P.S. a NE widget equivalent of GraphMapper would nevertheless still be the ideal... one day; See attached image below
The FrenetKTCurve script scans a curve for values of x and y.
Hi James and Friends
it is strange and curious, as though distant miles of Kilometers
our thoughts are so close ....
Just a few days ago I thought about how it would be useful
to be able to insert something similar to Graph Mapper ...
of our beloved Grasshopper, in Elephant
For this purpose, I tried to use the available tools
to recreate something similar .......
The result I have to say was better than I thought ...
But it certainly would be very useful to be able to implement it
Our gurĂ¹ (max and Karsten) have material to focus on
I'd say....
We hope for good news
the file and some images at this link:
http://www.mediafire.com/file/ots3p0n6dboq42w/-Similar_Graph_Mapper.zip/file
Have a nice day to all
al
Message 7713.827 was deleted
Hi All,
I have knocked up a simple macro for applying easing to a num array.
It achieves the result by physically emulating what graph mapper does with code,
by actually projected on to a user defined curve, not elegant but it works.
To see easing in action, I have included in my latest .nod file:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1182
Hi All,
To better illustrate how easing macro works
please find attached animation.
In this example, the new array is input into x component of Point node,
but it could alternatively be circle/polygon radii, angles, star ratios etc.
See small image and multiEasing.nod attached
Hi Max
I had a look in the nodeeditor directory to see if there was a css file that I may alter so that the nodes showed input and output colours by default rather than only when being connected to. I believe it would be better if the nodes communicated what they "needed" from the outset. (perhaps when they were being connected to, they could high-light in white? OR alternatively dot coloured from the outset & labels coloured only when being connected)
Also in most cases it seems redundant to label outputs, but even more so, if they are coloured.
Maybe you are not in agreement with this proposal, but please give it some consideration.
Have a great weekend
PS I found css stuff, in index.html. I'll see if I can modify.
Hi James,
you can't change it with css.
NE have a hidden feature which highlights inputs and outputs titles. Alt+Left click on Info button (left upper corner).
In the next version I'll add an ability to switch it using a color scheme settings (colors.js)
I need to think about it. We can't hide all output titles.
UPD:
http://moi.maxsm.net/files/nodeeditor/ne.colored.dots.and.titles.zip
1. replace colors.js and main.js with this files
2. set "io_text_highlight" and "io_highlight" parameters in colors.js
Hi Max,
Thanks for getting back to me, & thanks for the update: it's perfect! Great Stuff.
>> 2. set "io_text_highlight" and "io_highlight" parameters in colors.js <<.
I think it is best with "io_text_highlight" set to "false"
Did you happen to see my earlier post regarding a graphical num array re-mapper:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.824
Is this something that would be capable to achieve in canvas?
I do think it would have wide ranging application.
But I don't want you to think I am not satisfied with your recent update;
I could not be more grateful
Thank you
P.S. Some thoughts on Remapper widget:
By input a new range as well as the array to be remapped will increase widgets utility, so curve may be a straight line if all that is desired is to remap an array to within new range with easing; replacing my macro:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1114
Hi James,
In my opinion it looks better with both "io_text_highlight" and "io_highlight" switched off :)
I'll try to write this node today evening. Thank you for a good idea!
Hi Max,
Wow, this is exciting, Thank you so much...I can't wait.
>> Some...[MORE]...thoughts on Remapper widget
Grasshopper's Graph mapper has 10+ curve types, however several would have limited application.
Instead of emulating their approach, it would IMHO be better to have an anchor point at each end
and a pulldown menu in info panel for the number of control points (0,1,2,3 or 4). In that way, 0 control
points would give a linear remapping of numArray to new range and 1 or 2 control points provide easing.
3 or 4 control points could be used for defining geometry: say you have a linear progression (0,1,2,3,4,5)
wired into z input of Point node (x=0, y=0), as well as into Remapper node with curve as shown below.
The new series output is wired into radius input of Circle node & the Point node is wired into the Center input.
Loft the circles and you have a parametrically defined lathed form. This is a very simple example, but
imagine if multiple Remapper nodes were used together, say affecting rails and profiles of sweeps & rail-revolves,
or multiple curves Lofted or Networked to surfaces.
I imagine you are too far down the track for taking on suggestions, and if the new node allows num array
remapping by S-curve only, it will still be a huge advance for NE
I look forward to seeing what you have done
P.S.
For future releases, then, have them both set to false and I will reset "io_highlight" to true myself.
755-774
775-794
795-814
815-834
835-854
855-874
875-894
895-912
