742-761
762-781
782-801
802-821
822-841
842-861
862-881
902-912
Perfect! Works like a charm!
Bravo!
Hi Barry
I fixed this bug. Here is updated version:
http://moi.maxsm.net/nodeeditor/nodeeditor.v.1.0.rc2b.2018.02.11.zip
About the "Second Window"
I am wrong or seems we can Open any number of new windows of the NE ?
Another small update:
Added: mac trackpad gestures support
Added: macros directory (put often-used macros to this directory)
http://moi.maxsm.net/nodeeditor/nodeeditor.v.1.0.rc2c.2018.02.11.zip
Hi Max,
thanks works great.
Barry
Hi Max
Thank you for the update:
Pinching to zoom works just as it should! Great work.
However double finger, double tap does not "zoom to extents" as expected.
Rather it zooms to mid-size, but does not centre on the canvas.
Nevertheless it is a vast improvement
Thanks again
Hi James
I'll change the double-tap zoom logic in the next release.
nodeeditor.v.1.0.rc3 (I hope this one will be last before v1.0 release)
http://moi.maxsm.net/files/nodeeditor/nodeeditor.v.1.0.rc3.2018.03.09.zip
Fixed a couple of bugs.
Also I clean all waste from NE files.
Updated translation file.
Pilou, I removed french translations of all obsolete and unofficial nodes. Later I will help you to make an extension for unofficial nodes.
Right now I need your help with translation. Could you check an attached file, and add translations for all words marked with "?"
sure! ;)
Hi Max.
This version works with V4 only or also with V3 ?
Thank you very much :)
Done ;)
Of course must be tested in action! :)
(i change the name of the file for avoid some erase on my rustic Web site)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodeeditortranslation_fr1_10_03_2018.xlsx
Some Lines are empty in column D ?
Marco,
I forgot to test this version with V3, but it should work fine.
Frenchy Pilou
Thank you!
You may leave it empty when French and English words are same.
@You : "...I forgot to test this version with V3, but it should work fine..."
Ok! Thanks.
Hi Max,
How are you going with finalisation of NE v1.0 release?
I have a proposal for an extension to switch node
that you might consider including.
It is pretty self explanatory; allowing branching between 2 paths.
& would be useful for checking outputs and readings at various
critical points for debugging purposes.
I know that there is a work around with split + 0-1 knob,
or alternatively, split + switch + 2x const, but they're cumbersome.
All the best,
Keep up the good work
Hi James,
I didn't write a line of code since 1.0 rc3 release. Sorry, have no time at all.
Good idea. I'll add it to Switch node.
Hi Max,
Thanks for building this awesome tool!
I'm having a problem with node editor v 1.0 (rc3). It appears that Macros aren't working for me at all (either in MoI 3 or 4 beta). The following error pops up if I select Macro (the error looks identical in 3 and 4 beta, although I can only cut and paste the error in 4 beta):
Script error
TypeError: undefined is not an object (evaluating 'document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace')
moi://ui/nodeeditorv10rc3/core/main.js line 4404
4400: var entries = {};
4401: for(i=0; i<values.length; i++) { if ( values[i] ) entries[i] = { value: ">"+values[i], content: lang.getTranslation(values[i]), is_menu: false }; }
4402:
4403: var dir = (moi.filesystem.getAppDataDir)?moi.filesystem.getAppDataDir:moi.filesystem.getProcessDir;
4404: >> var path = dir()+document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace(/\//g,"\\")+"macros\\";
4405:
4406: if ( moi.filesystem.dirExists(path) )
4407: {
4408: var files = getFiles(path);
Any ideas on what I am doing wrong?
-FDP
Hi FDP,
I'll check it this weekend. I have no idea at the moment.
Hi Max,
Any chance to look into that error? I'm sorry to be bugging you with this - understand if you are super busy!
-FDP
Hello FDP,
could you make a zip of your nodeeditor Folder and post it - maybe something is wrong with it. As a Workaround I would Switch back to an older Version. Worth a try.
Have a nice day
Karsten
Thanks!
Attached the zip. This is from my: 'Program Files/MoI 4.0 beta Jun-6-2018/ui' folder (64bit).
nodeeditorv10rc3.zip
742-761
762-781
782-801
802-821
822-841
842-861
862-881
902-912
