Full Version: Parametric design in MoI?
Show messages:  1-3  …  684-703  704-723  724-743  744-763  764-783  784-803  804-823  …  904-912
18 Dec 2017   [#744]
i don't use Node Editor but as understood you must create an icon for every node you like to have an icon in.
So if you look at Max's code example you see how it should be done, in case you like to put an icon in your
own node file.
18 Dec 2017   [#745] In reply to [#743]
Hi Pilou!
No tricky or headache at all if you are a little bit familiar with this kind of things :)
Just use the online tool I've reported (https://www.base64-image.de/) and follow this little example (pseudo code) :
// This is a js node definition file placed inside the "extensions" folder
function NameOfTheNode() {
	... js code of the constructor function of the node
// here is the section that is important for you
NameOfTheNode.title = "NodeTitle";
NameOfTheNode.desc = "Node description";
NameOfTheNode.icon = "data:image/png;base64,xxxxxxxxxxxxxxxx";
Where "xxxxxxxxxxx........" is the base 64 code generated by the online tool (https://www.base64-image.de/)
Nothing more than that :)
18 Dec 2017   [#746] In reply to [#745]
Ok I have made my own for be sure to understand what i made! :)
With SumpoPaint of course! :)
https://www.sumopaint.com/home/#app
Just curious logo is not centered on the Menu's Lines?...
Maybe the original is not exactly at the center...
Edit : even the original is centered result is bottom offseted! ?
18 Dec 2017   [#747] In reply to [#728]
Hello Max,
I made a first experiment with an icon. Is it true that we will lost the node state (green, orange,red).?
Have a nice evening
Karsten
19 Dec 2017   [#748]
I have been playing with adding Icons in the node editor to see if they can be recognised at the 64 x 64 size.
On my surface Pro even when zoomed in I don't think over detailed icons will be recognised.
Any idea's on best colour's ?
Barry
21 Dec 2017   [#749]
For Max and all nodes lovers! :D
Official nodes + Extensions!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_21_12_17_vf.zip
25 Dec 2017   [#750]
Hallo together,
where can I find the current instructions how to install the nodeeditor on V4.
25 Dec 2017   [#751] In reply to [#750]
Have a look here:
http://moi3d.com/wiki/Nodeeditor
25 Dec 2017   [#752]
Ralf, thank you, it functioned well. Had to replace just the name of the folder.
Now I need a nodeeditor beginner tutorial.
Rudl
25 Dec 2017   [#753] In reply to [#752]
Hi Rudi,
unfortunally there is no tutorial about the nodeeditor... its still a project in development.
But a good point to start is this forum ore the thread http://moi3d.com/forum/messages.php?webtag=MOI&msg=7777.1
You will find a lot of examples for whats possible to do with the nodeeditor.
An other thing are the extensions - a lot of people write special plugins for nodeeditor.
I will attach my extensions folder - i think its mostly complete. It goes into the nodeeditor folder
Have fun with nodeling!
extensions.zip
25 Dec 2017   [#754]
Hi Ralf,
thank“s for the extensions. Integrated it in the extension folder. Now I must find out, what to do with them.
3 Jan 2018   [#755]
Because i think that this is the first of my Node creations which i think is USEFULL i post it in this thread...
THE DOVETAIL TRAY MAKER
HOW TO USE IT
Open the attached dovetailcase5.nod in MoI > hit run... and you see this:
Change the dovetails to your needs. And hit APPLY
NOW SWITCH BOTH SWITCHES ("Left/Right" and "Boards") and you can design a different Dovetail for the opposite side...
HIT APPLY AND CLOSE THE NODEEDITOR...
You will see the tray with the dove maker tools
Now select the upper and lower board and DO A BOOLEAN DIFFERENCE with the correspondending (the outer ones) tools to cut the dovetails:
Do the same with the other two boards:
You have the dovetail tray!
Do some small chamfer...
You can also make a small gab between the two parts - VERY USEFULL IF YOU 3D PRINT IT - and it brings a snuggly fit...
As a joiner i would be proud of it!
And there are NO SPECIAL EXTENSIONS used..
HAVE FUN !
dovetailcase5.nod
Ohne Titel 2.png  Ohne Titel 3.png  Ohne Titel 4.png  Ohne Titel 5.png  Ohne Titel 7.png  Ohne Titel 8.png  Ohne Titel 9.png  Ohne Titel 9.png  Ohne Titel.png
3 Jan 2018   [#756] In reply to [#755]
@r2d3
Will be fine if any 2 intersected volumes can be used! ;)
French version is in Progress!
4 Jan 2018   [#757] In reply to [#756]
"Open the attached dovetailcase5.nod in MoI > hit run... and you see this:"
Hi
When i load dovetailcase5.nod i can't hit run (show screenshot)
and a part of nodes are red..
4 Jan 2018   [#758] In reply to [#757]
Your node extensions are not up to date...
Look here for a actual one...
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.753
Have fun
4 Jan 2018   [#759] In reply to [#758]
Thanks Ralf ! it's great !
4 Jan 2018   [#760] In reply to [#756]
Let the Dove-tools jump over a FLOW-command and you can do also round edges...
4 Jan 2018   [#761] In reply to [#760]
Forgotten this tricky trick! ;)
4 Jan 2018   [#762] In reply to [#761]
With this extended Tool you get also the Polylines to make it easier for FLOW operations...
The cyan line is for the dove cutting the blue for the tinnes and the magenta (selected on pict) is the baseline.
dovetailcase6.nod
4 Jan 2018   [#763]
French Version of DoveTails by r2d3 : http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.js
