 466-485
 486-505
 506-525
 526-545
 546-565
 566-585
 586-605
 906-912
Hi Marco,
"ArrayBoolean" sounds interesting. What a shame it has been lost.
Hopefully it or something similar will be resurrected in the future.
I'm always excited by your node contributions.
-James
Hi everyone,
Thanks a lot James for your appreciation.
Damn "recycle bin" and "overwrite" !!
I tried also to use some recovery tools but without success...it's been too long....
Anyway, here's just some info in the case of someone wants to write something similar.
I was writing these nodes :
"ArrayDistinct" node :
Input : A PointArray[], a DELTA (a javascript float number) and a PRECISION (a javascript int number)
Output : a new PointArray[] containing all the "DISTINCT" PointArray elements found in the source PointArray[].
All the PointArray elements of the source, far from each other, NOT MORE THAN DELTA (considering the required PRECISION)
are WELDED into a SINGLE PointArray element, that is, the element currently investigated (simple "For loop" with some flags to mark already processed elements).
"ArrayBoolean" node that did exactly what its name means : Basic boolean operations between two PointArray[] objects.
More in depth, it provided these operations :
1) Array Union :
Input : Two PointArray[] (named "A" and "B") also with different amount of elements, a DELTA (a javascript float number) and a PRECISION (a javascript int number)
Output : a new PointArray[] containing all the "DISTINCT" PointArray elements of both arrays.
All the PointArray elements of "A" and "B" far from each other, NOT MORE THAN DELTA (considering the required PRECISION)
are WELDED into a SINGLE PointArray element.
2) Array Difference :
Output : a new PointArray[] containing all the PointArray elements of "A" that are NOT PRESENT in "B".
All the PointArray elements of "A" that are far from each "B" elements, for AT LEAST DELTA (considering the required PRECISION)
are returned into the output PointArray[].
I don't know if I made myself clear..
It's really too bad that "ArrayDistinct" and "ArrayBoolean" node that I was writing were lost because they were at and advanced alpha stage,
and from many tests I did they seemed to be very powerful for interesting elaborations in order to create some "exotic" nurbs objects.
Anyway, I must also say that they have been written with a very coarse businnes logic, and crunching more than some hundreds of PointArray elements,
produced very poor performances.
Have a nice day,
Hello Marco, James, wastzzz ...
I thought about randomly place geometry again and was reminded ArrayShuffle made by Marco. So I have updated the file for v0.85. I have made some test as an alternative to the node I have written (randomObj). Two different ways with different advantages:-)
Have a nice day
Karsten
@James: I'm indeed not interested in patterns or more precisely ornaments (my focus is smooth geometry), but it's not possible for me to ignore them and I think not useful also:-)
 ashuffle.nod
ashuffle.nod
Hi Karsten
Ornament is a crime :-)
I think there may have been some semantic confusion.
I meant pattern as order not ornament; designation not decoration.
Thanks for updating these nodes, I greatly appreciate it.
-James
Hello Friends
a new little exercise to test some Karsten's nodes
best
al
 CP-Tennis Ball.nod
CP-Tennis Ball.nod
Hello James,
I agree with you about ornaments and the different interpretation of "pattern". But I'm not an artist and haven't the creativity like some others here, so there are many different points of view about the aesthetics of ornaments, that I can accept.
Have a nice day
Karsten
p.s.: Please, don't let us start a dicussion about that here - I'm afraid about that!
Hi Kartsen and good morning.
Thank you for updating my old arraysExt.js and litegraphExt.js.
N.B. I will begin by saying that I'running latest Max's verison "nodeeditor.v.0.85_mod.zip" at
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.485
Well...I'm sorry but it seems that your updates doesn't works for me.
I think that I'm doing something wrong or I'm getting a little bit confused among various versions (mine and yours).
When I run your last experiment "ashuffle.nod" (
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.528)
I get this error :
http://take.ms/R2l59
Also if I run this simple .nod file (
http://take.ms/mGHP8) I get this error :
http://take.ms/LnRgz.
I'm running your arraysExt.js that you uploaded (
and this is my litegraphExt.js that has your modifications :
// litegraphExt.js v.0.1 - Marco Di Mario (mkdm), 2016
// based on :
// 		Max Smirnov's Node Editor, v.0.65 - 2016
// 		litegraph.js library (c) Javi Agenjo http://tamats.com
pointArray.prototype.getElement = function(n)
	var idx = (n || 0);
	var shift = idx * this.recordLength;
	var element = {"pt":this.getPoint(idx),
		"AngleX":this.data[shift+3],
		"AngleY":this.data[shift+4],
		"AngleZ":this.data[shift+5],
		"Size":this.data[shift+6]};
	return element;
pointArray.prototype.copyElementDataTo = function(source_elem, n)
	var idx = (n || 0);
	if (source_elem) {
		this.data[shift+0] = source_elem.data[0];
		this.data[shift+1] = source_elem.data[1];
		this.data[shift+2] = source_elem.data[2];
		this.data[shift+3] = source_elem.data[3];
		this.data[shift+4] = source_elem.data[4];
		this.data[shift+5] = source_elem.data[5];
		this.data[shift+6] = source_elem.data[6];
What I'm doing wrong ?
P.S : Would you like to rewrite my lost :( experimental nodes ArrayDistinct and ArrayBoolean that I mentioned in my previous post ?
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.527)
Have a nice day ?
Hello Marco,
sorry that I forgot to say that you don't need the litegraphExt.js and so I didn't posted an updated here. Max has integrated the getElement in the last version. The copyElement -Stuff I have integrated inline. So try to remove litegraphExt.js from index.html.
Have a nice day
Karsten
Ahhhh....Ok Kartsen,
I did what you said and now all works fine. Thanks a lot!
What do you think about my proposal to rewrite my lost :( experimental nodes ArrayDistinct and ArrayBoolean that I mentioned in my previous post ?
Unfortunately, for the time being I can't deal that effort.
Maybe when Max's will release 1.0 version of Elephant...
Have a nice day.
Hello Max and Friends
  Someone is willing to post some examples
  illustrating the use of the node length .........
  for me it's difficult to figure out how to function
  thank you
al
Hello Al,
the length node evaluates the number of elements in a given array. With the RMB you can change the type of the input (numarray - default, pointarray or geometrical
objects). The output is type of numarray (number) with only one element.
Now it's up to you - but I saw that you have already used it!
Have a nice day
and thanks for sharing your examples
Karsten
Hi Karsten
thanks for your  reply, I have many other questions to ask ,
but let's degrees.....
1-Blend
   attached a file that contains two surfaces, you get with your Node Swep,
   how do I use the Blend Node?
   Swept gives me a single input, the surface, how do I
   to extract the edge you want to use for the blend?
2-Blend
   I also used two simple curves, I thought
   that blend so it worked, I was wrong ....
   Can you please show me the use of this Feature ...
   Needless to say ... thank you very much
have a nice day,friend
best
al
 CP-Swept_ versus Blend.3dm
 CP-Swept_ versus Blend.nod
Hello Al,
I will try to explain the attached file and the workflow. First you have to create your surfaces. I have used here sweep with a circle placed to the startframe (getCrvSFrame). Important: Switch of CapEnds in the sweeps!. The created sweeps are connected to the nodes BRepNameSubObj. This node takes the sweep and gives edges and faces a name. If the elephant runs, it creates also a tempobject with the same names. Now you can preselect both edges. Do not clone the BRepNameSubObj node, because the clone would have the same basename for the subelements. When you now create the blend the names of the edges will be evaluated and stored in the blend node. Connect the wires and switch of the tempobjects in the BRepNameSubObj nodes.
It's a little bit complicated, but at the moment I can't find a better solution for the function.
Have a nice day
Karsten
 sweep-blend.nod
sweep-blend.nod
And your file with a blend:-)
Hi Karsten,
Thank you for your clarification of the application of BRepNameSubObj node together with Blend node. I know I asked about this earlier:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.499
but this a prime example of where inputs into a alt version of const node (called say Num node) would be very useful. In this way a short series could be constructed with variable inputs as shown.
-James
Hello  Karsten
First of all thank you for the explanations....
I would like to ask you some things that are not
very clear
 1-  theBlend object surfaces are sweep, loft etc etc
       must always be closed (solid) ???
       Name BrepSubObj   Node-   does not recognize the surfaces
        as Brep? ........
2-  I need to clarify if, once connected my
      Surf with BrepNameSubObj- Node, run Elephant, I have to selected
       the edges which appear to me to video ,before or after
       It made the final connection with the final Blend -Node ......
3- Blend curves, Curves Joint , Rebuild Curve, I think they are Nodes
    absolutely essential for the growth  of  Our Elephant,
    and given the Your ability to create Scripts, I think you should give it a thought
Have a Nice Day and many .. many .. Thanks
al
Hello Al,
1. the sweep, loft, ... has to be a surface not a solid - the loft works only for egdes of surfaces.
2. Select the edges before you create the blend node - very important, because the blend node evaluates the names of the edges with the selection.
3. I have already thought about that, but time is limited and it is useful to think about which functionallies have to included in which node. Max has made a great job regarding to intelligent data handling with a small amount of nodes - very flexible. As well as the internal structure regarding to the programming. Every time I have a look in his code I'm surprised and impressed, but most of the time - first shocked and then confused, until I understand the concept. So are all my nodes are only studies to help developing and it's not clear if there are better solutions for some functionallity. So I hope they are useful, If not, we should disscus and find better solutions. Important! Play with them!
Have a nice day
Karsten
p.s.: @James: I try to make a node based on Max Concat, with the length node functionallity (flexible input types)
Does not a good idea to make a little general diagram by the creator of new nodes because text is not very catching in a wink!
between Original Max Elephant / external...new nodes...place where that must be placed...what download...
because now we are totally over passed! :)
Message 7713.544 was deleted
Hi everyone,
I totally agree with you Pilou.
I think that, until Max will not release his 1.0 official version of Project Elephant,
it would be really helpful for everyone if we create a new thread dedicated to all the experiments that most of us are doing
with brand new nodes and/or with the improvement of the existing ones.
What do you think about ?
Best,
 466-485
 486-505
 506-525
 526-545
 546-565
 566-585
 586-605
 906-912
